Page 4 of 21 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 314
Thread: GuzziDiag step by step throttle and handle learning procedure for RSV4 and Tuono V4
  1. #46
    apriliaforum expert the todd's Avatar
    Jun 2014
    Ball Ground
    The cables I have came from OBD Innovations San Jose CA. They are good cables if you want them fast.
  2. #47
    Jun 2011
    Central Cali.
    Those are the ones I have. Pretty much next day delivery lol
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  3. #48
    apriliaforum expert skabarbro's Avatar
    Mar 2014
    Harrisburg, PA
    7SM also worked for me. California 1400 wasn't an available option
    2012 Tuono V4 (Golden Ape for sale)
    2012 Tuono V4 (Sold)
    2010 RSV4 R (wrecked)
    2008 YZ450F Sumo (traded)
    2006 YZF R6 (Sold)
  4. #49
    Jun 2014
    Ball Ground
    Are you using Guzzidiag or IWAdiag?
  5. #50
    Mar 2014
    Harrisburg, PA
    I downloaded the Guzzidiag V0.47 and selected 7SM. However, on my computer the program is labeled as IAW_V0.47. I attached a photo of what I clicked to download. (Windows version)
    2006 YZF R6 (Sold)
  6. #51
    Oct 2015
    Tasmania
    I downloaded both & GuzziDiag has California 1400 available. IAW does not.
  7. #52
    apriliaforum expert Danfinarch's Avatar
    Dec 2013
    Hampshire
    IAW is for Aprilia bikes only. Aprilia call the ECU 7SM. Guzzidiag is for more bikes from the Piaggio group and list the 7AM under the California 1400
    Same ECU just named differently in the two programmes
    2009 R
    Race ECU. Domino XM2, Shorty Akrapovic. Retro Fit APRC Qs. RCS 19 and RCS clutch perch
    HEL lines throughout. GiaMoto Rearsets, Puig, Pipercross Air filter. SC1 for road and Superbike Slick SC1/SC2 track
  8. #53
    Jun 2014
    Ball Ground
    I made this tutorial on Guzzidiag because it is the more well-known name of the program but you get the idea, you can use either one to get the same result.
  9. #54
    Jun 2011
    Central Cali.
    Waiting on new cable so I can fix my issue,at least I hope its the cable. lol
  10. #55
    apriliaforum newb Shroom Turkey's Avatar
    Dec 2015
    Palm Coast, FL
    I just completed this process on my RSV4 tonight.
    I was having issues as well with not being able to connect it, at first.
    If you are having the same issue, try this before sending your cables back.
    Remove everything from the usb ports. Mouse dongle and all.
    Open Device Manager and find the Ports (COM & LPT)
    Click the drop down and then plug in your Purple cable.
    It should show the COM # now, Mine was COM 6.
    Now reference your COM# in the Guzzidag picklist and you should be able to connect.
    I was referencing COM 3 since that's what this thread said to do before I learned what COM actually was.
    My laptop has 3 Usb ports and I was telling it to look at the Mouse dongle....duh.
    Turned the ignition on once again and boom connected!
    Bike is running like a raped ape and spitting fire like a flame thrower on decel....Loving it!
    Also, OP I think you forgot to mention in your steps to reconnect the Battery Cable. Other then that it's perfect.
    Thanks for writing this, very helpful.
    Good luck
  11. #56
    Jun 2011
    Central Cali.
    I did match the com but for some reason on the bottom of the screen it still says disconnected. Ordered a new cable and that still doesn't work I'll take it to the dealer. Hopefully don't have a bad ecu.
  12. #57
    apriliaforum expert Eppy's Avatar
    Dec 2007
    Westminster, MD
    Everything worked for me!
    Ordered cables off Amazon, sent ECU to AF1 for updated APRC mapping with QC enabled, installed ECU today.
    Guzzi fired right up and performed throttle learning with no issues.
    Factory QC is buttery smooth compared to the Dynojet I have on my track bike!
    Mark~
    2010 - RSV4 - Street
    2016 - Multistrada - Street
    2004 - GSX-R 750 - Track
  13. #58
    Austin, TX
    Quote Originally Posted by Eppy View Post
    Ordered cables of Amazon, sent ECU to AF1 for updated APRC mapping with QC enabled, installed ECU today.
    cool, glad you got it going......and you got an updated map too... I did it
  14. #59
    Dec 2007
    Westminster, MD
    Thanks Ed!
    Saved me a 6 hour round trip to the closest dealer. The same dealer that had to call you for help years ago in the middle of a map update.
    Mark~
  15. #60
    Austin, TX
    Thanks Ed!
    we sadly get those kinds of calls all day long from dealers......"come on, its been the same handle/throttle learning process since the 2007 Shiver..." RTFM
  1. Installing new rear end gears-STEP BY STEP w/PICS, and performance results!
    Last Post: 04-06-2018, 03:42 PM
  2. Learn how to DE-RESTRICT here!! step by step w/PICS!!
    Last Post: 04-25-2017, 11:51 AM
  3. Race ECU and handle learning Procedure
    By Bassgt3 in forum 2010-2019 RSV4 - All Variants
    Last Post: 09-19-2012, 03:31 AM
  4. Replies: 38
    Last Post: 06-03-2012, 09:16 AM
  5. step by step in cleaning the powervalve?
    By sniperx25 in forum RS125 Euro-archive
    Last Post: 06-16-2003, 02:15 PM
