Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 121
Thread: Gabro's IGen Tuning Kit (collector mod + airkit): almost ready
  1. #76
    apriliaforum expert flossy's Avatar
    Jan 2012
    Seq/Qld Auzzieland
    I know you like to play but with the chance of crap getting into an airy box modded, I don't think they need it unless its restricting air flow, you have bigger boots now I think and she is finally running spot on, great to see, be happy, swill wine and play on your weapon till your jaw aches, but if you modd the box we want before and after dyno shots or trex and co will disown ya,
  2. #77
    Aug 2012
    Redwood City CA USA
    Any update on this mod? Availability, price etc?
  3. #78
    Dec 2012
    Paimio, Finland
    Quote Originally Posted by RonJon View Post
    Gab, I threw the switch onto the lean map and its now not running rich at all, VERY smooth power delivery! Surprisingly smooth! No dips, lots of power and torque through the rpm range.. Power just rolls on! So happy with this new chip! Serious congratulations on an amazing setup!
    Now I have to mod my airbox so its an open one. (haven't had time yet) I may do that this weekend after buying a dremel to do the work.
    Mille Grazi my friend! So happy with the result!
    You'll hardly improve it noticeably with the open box... induction noice will increase (some like the roarrr) and you may or may not get dirt on the wrong side of the filter. Ányway, if you do it, please make sure it really seals tight.
    Mille Aarrr -02 (1060 BB, Gen2 heads, 2-2 Akra, timed cams, bespoke Gabro chip + TSS slipper) & KTM 625 SXC -05
  4. #79
    apriliaforum expert madart's Avatar
    Aug 2011
    Australia
    The airbox mod I did using the dremel and car boot pinchweld rubber has been operating for about three months now, Had the tank up quite a few times and it's sealing very well (to the point that I have to press the tank down quite hard to get it to sit in place, and the front bolts are a little harder to get in) . No sign of any dust or debris.
    Getting the engine breather out has worked well too- no more oil in there.
    It's very cheap to do and much more robust than the 'evo' seal. Takes a few hours.
    see here
    http://www.apriliaforum.com/forums/s...ght=airbox+mod
  5. #80
    Mar 2015
    Bainbridge Is., WA
    Bump - any closer to offering this kit? Sounds pretty awesome.
  6. #81
    Roma, Caput Mundi
    Quote Originally Posted by Doc B. View Post
    i do sell those kits from some time now... PM me for infoes
  7. #82
    Roma, Caput Mundi
    yesterday i've tested a new header mod, based on the '98-'00 header (and '01-US). it has only one crossover pipe in the rear header.
    tests has been performed with a '99 RSV, stock motor, stock TB's and airbox, Akrapovich exhaust can
  8. #83
    What were the results?
  9. #84
    Oct 2009
    Been doing these for years .. hopefully you’ll prove to the disbelievers it works
  10. #85
    We know it can be done. But how does it compare to the later pipe with the double?
  11. #86
    Sep 2007
    Looking forward to seeing these results.
  12. #87
    Roma, Caput Mundi
    '00 header set does very little midrange dip in torque, and at highter rpm's (primary tubes are shorter).
    The single crossover mod tested is pictured here:
Name:	WhatsApp Image 2018-04-02 at 11.27.14.jpeg
    the dyno-results comparing the 2 headers above is that:
Name:	comp singolo_1.jpg
    crossover makes toque figure almost electric: softening a lot it at low rpm, filling the midrange dip, castrating the torque peak, and giving almost the same topend of std
  13. #88
    Roma, Caput Mundi
    than, i've tested a "normal" '01+ header with my double crossover mod:
Name:	WhatsApp Image 2018-04-02 at 11.50.54.jpeg
    it perform globally better than the single mod '00 header: with stronger low rpm, a little dip at midrange, stronger torque peak, and a better topend:
Name:	comp doppio vs singolo_1.jpg
  14. #89
    Roma, Caput Mundi
    finally, a graph comparing std '98-'00 header to my tuning kit, '01+ modded exhaust header with double crossover and matched eprom:
    Attachment 354757
Name:	comp doppio_1.jpg
  15. #90
    Jul 2009
    Gab I would love to go single can on the Falco with the 98-00 modded headers for weight loss and power/torque gains. Aprilia did their own mod on the Falco... but I am worried about the front cylinder header being longer than the rear cylinder header if you mod like Aprilia did in this picture of this very sorted Falco. Any opinions on this?
    Oh and I want to keep the Falco oil tank/cooler...
  1. Adjusting engine variables due to collector mod + Gabro chip
    By MooMoo46 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 08-06-2014, 06:21 PM
  2. F255 Gabro chip, collector mod and intermittent stalling!
    By pratapchandar in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-01-2014, 06:35 PM
  3. does tuning kits fits betwen RS50/RS50 TOUONO
    By Steffman in forum RS50 Technical
    Last Post: 02-14-2006, 08:36 AM
  4. Evo airbox kit and Mods!
    By CCEMN1 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-15-2004, 08:58 AM
  5. motorrad-fiedler.de basci tuning kit
    By Dutchie_in_Dubl in forum RS250
    Last Post: 07-18-2003, 05:15 PM
