Results 1 to 4 of 4
Thread: Wobbly Rear Sprocket 1999 RS125...
    Sweden
    Hi All,
    I hope someone out there can assist me with this query please. I just bought a 1999 RS125 and after 3 months of riding I noticed the rear sprocket has a little bit of side play in it. The sprocket is firmly secured to the four bolts that hold it on but still has the movement. I have seen a few other messages relating to this but I couldnt find anyone that had sorted it. I am just a bit worried about the chain giving way at high revs.
    Any help or experience of this would be much appreciated.
    Thanks,
    Gup
    Oct 2009
    Investigate the sprocket carrier and Cush drive...wheel out job
    Oct 2009
    Clearwater, Fl
    You need to service the rubber coupling which may need replacing. The crown holder may simply be loose due to the the rear axle not being set tightened properly so that needs to be checked out before you ride it any more.
  1. Wobbly rear sprocket
    By ExtremaPete in forum RS125 Euro-archive
    Last Post: 01-27-2005, 06:46 AM
  2. Rear Sprocket!
    By thetoecutter in forum SL1000 Falco Forum (all years)
    Last Post: 06-25-2003, 07:45 AM
  3. Alloy rear sprockets
    By redlionfalco in forum SL1000 Falco Forum (all years)
    Last Post: 06-23-2003, 01:00 AM
  4. Rear sprocket runout
    By tireshred in forum SL1000 Falco Forum (all years)
    Last Post: 12-05-2002, 11:59 AM
  5. Changing rear sprocket - help!
    By tino in forum 1000cc f.a.q
    Last Post: 07-23-2002, 06:32 PM
