Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Racing a Tuono 1100 Factory
    Jun 2015
    Seattle, WA
    thanks everyone for your input! really appreciate it. I'm headed to texas for 5 weeks and am scheduled to check out a Factory in Houston. When I get back I'll be wrapping up the AFM season then hopefully get some actual hands on time with a Tuono.
    May 2015
    Nor-cal
    Quote Originally Posted by alleycatdad View Post
    More info on the shaft support?
    http://www.oppracing.com/product_dis...iftholder-kit/
    http://shift-tech-carbon.com/onlines...roducts_id=497
    i had a miss-shift in 3rd, it engaged 3rd for 3secs then dropped to neutral, built up revs and slipped back in and wheelied like a monster lol
    now im looking at these as well,
    Jun 2015
    Seattle, WA
    so Toohomo you mentioned upgrading the shock and forks; does that mean the Factory Ohlins kit is not that good or are you going from an RR and upgrading the suspension? If you're suggesting upgrading the Factory Ohlins kit, then doesn't it make sense to just buy the RR and get better suspension parts and save the money that way? The only difference are the rims, shock, and fork right?
    apriliaforum expert Toohomo's Avatar
    Feb 2013
    Mandlebar HQ UK
    I had a stock 2012 Tuono not an RSV4 mate, ohlins front and rear is more than capable
    Sep 2007
    Minneapolis, MN
    Quote Originally Posted by FXCLM5 View Post
    why not just an rsv4?
    ^^THIS^^
    Why would you race a Tuono vs an RSV4? Since displacement is the same, you will be racing in the same class. In my neck of the woods (CRA) you would be competing with 200rwhp decked and cammed ZX10's, R1's and CBR1000's, and 1199 Panigale's. Racing a Tuono would not be competitive. Better to stick with riding track days.
    May 2015
    Nor-cal
    fyi factory ohlins on the factory bikes are never as good as ohlins aftermarket
    they are a big step up from the oem sachs though
    apriliaforum expert vfr1200's Avatar
    Jun 2011
    Azle, Texas
    stock gearing is 15 42 I believe
    2017 Sherco 300 SER Factory
    2016 Tuono 1100 Factory
    2015 TREK 7.3
    https://www.amazon.com/s/ref=nb_sb_n...alan+golightly
    apriliaforum expert derbybrit1's Avatar
    Feb 2005
    San Dimas, CA
    Quote Originally Posted by drvacation View Post
    arthritis, and come out to a trackxperiance or mwgp event and see how much the handle bars are holding me back, you just got to motard your style a little, I can carve right inside most guys in the tight corners, It's not as big a handicap as you'd think
    Are you a MWGP Novice or Expert? What was your number? I don't remember seeing an T4's in 2015.
    Team Punisher/AF1 Racing:
    World's Fastest Aprilia RSV 200.8mph
    Texas Mile Record Holder - Fastest Twin
    2014/2015 Moto West Grand Prix Formula Singles Champion
    2016 WERA West Clubman Expert and D Superbike Champion
    apriliaforum expert drvacation's Avatar
    Aug 2013
    las vegas
    Quote Originally Posted by derbybrit1 View Post
    Got my mwgp license the first time they came to Vegas, was going to race senior and novice, then they bailed on Vegas, So sticking with trackxperiance he'll I get 22trackdays 6plus tracks 14 layouts 2200.00 bucks and always someone to chase or pass
    Feb 2005
    San Dimas, CA
    You must have been at the Pahrump MWGP Round 1 in 2015. David Price would have been your New Riders School instructor. They cancelled the September 2015 round, probably due to the heat and expected low turnout. MWGP doesn't have a Senior class, per se, but has Formula 40 and Formula 50 middleweight and heavyweight (your Tuono would be heavyweight). You can run those classes after you graduate from Novice, should you decide to come back and try your hand at racing.
    TrackExperience organization runs a good trackday event org. Can't go wrong with that plan either. Better get on good terms with your tire guy.
    Aug 2013
    las vegas
    Right you are on all counts and yea I'm on a first name basis with the Pirelli guy, I call him dale and he calls me his bitch,lol
    Apr 2016
    socal
    yes any specific questions? and as an 1100 what class do you plan on running? first things I'd do is a radial master cylinder, but I stayed with the stock calipers, to me they work great and I'm known on the track to be wickedly good on the brakes, also 1100 frame/ swing arm set up/angles and measurements slightly different than 1000's so your going to need to feel out our advise set up wise. 2nd recommendation a real steering dampener, and how many lines showing on your forks? 3rd race map and can with cat delete a.s.a.p. not available yet, and 15 tooth front sprocket, A must for racing, I like a 520 chain set up, better throttle response/feel) and depending on track any ware from 42-45 rear sprocket, also what weight are you for shock fork advise. Also how much track/race experience do you have? Are you in the fast group on track days? be honest with telling us your riding level and we can help more, you also need tire warmers and a generator or you'll tear up race tires, and what percentage of time will be spent on track, this bikes so hooligan I'm going 90% track with mine now
    drvacation, how many lines are showing on fork? how did you determine fork lines, best setup? I have a 2013 Tuono, that i just installed andreani fork kit and 2016.5 RF ohlins rear shock. what tires are you using at track? I when through a set of RS10 in two trackdays (100 miles total).
    thanks
  13. #28
    Jun 2015
    Seattle, WA
    Alright gentlemen - it literally took 4 years and moving to NYC then Seattle but Iím picking up a 2019 Tuono Factory on Monday! XD
    signed up for first trackday with it on July 21. Iím hoping that the new suspension will be pretty good on track! Going to run her completely stock and make adjustments as necessary.
  14. #29
    apriliaforum prov-nov equinity's Avatar
    Oct 2017
    Puyallup, WA
    Quote Originally Posted by carotte View Post
    Alright gentlemen - it literally took 4 years and moving to NYC then Seattle but I’m picking up a 2019 Tuono Factory on Monday! XD
    signed up for first trackday with it on July 21. I’m hoping that the new suspension will be pretty good on track! Going to run her completely stock and make adjustments as necessary.
    You gonna race it with WMRRA next year? Did you get it from OPM?
  15. #30
    Jun 2015
    Seattle, WA
    Quote Originally Posted by equinity View Post
    hihi, so I've done two trackdays with the bike so far. takeaways are that it can definitely hang with the fast group and is a total blast, but the handlebar/ergonomics don't provide the same level of front end feel as a proper sport bike and there is zero chance the way the Tuono's power is generated can hang with superbikes (unless you do some insane mods like Gabro's Tuono). Regardless, the Tuono Factory has reignited my love for the track and sport after being away for the last few years.
    I'm planning on doing a few mods:
    1) Graves exhaust + tune
    2) SRJL-XX pads (I *might* eventually upgrade the MC to a Galespeed for better feel over the Brembos)
    3) Forged wheels
    4) Sprockets?? or at least 520 chain conversion kit
    No plans to compete with the Tuono thus far, going to spend the rest of the season dialing her in. I like the idea of keeping up/thrashing sportbikes while riding handlebars. It's definitely entertaining.
    did not get from OPM - private party sale in Boulder, CO. Had it shipped to Montana and drove out there and picked it up. 2019 Tuono Factory with 123 miles, bought for $15,100 - couldn't beat the price.
  1. Question for the Tuono 1100 Factory owners in the USA...
    By Great Scott in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 07-01-2015, 07:02 PM
  2. 2016 RSV4 RF and 2016 Tuono 1100 Factory Being launched at Daytona Bikes week
    By Ed / AF1 Racing in forum 2010-2019 RSV4 - All Variants
    Last Post: 05-26-2015, 11:57 AM
  3. Guy enters a stock Tuono 1100 Factory in the KTM TNT Cup
    By Shaman666 in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 05-12-2015, 09:04 AM
  4. 2016 RSV4 RF and 2016 Tuono 1100 Factory Being Launched at Daytona Bike Week
    By Ed / AF1 Racing in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 03-10-2015, 05:30 AM
  5. Tuono Racing and Tuono Factory
    By MaKuono in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 11-25-2005, 06:29 AM
