Thread: Vespa GTS250 - installation of ABS
    Feb 2015
    Moscow, Russia
    Hi guys!
    I am installing ABS on my 2010 Vespa GTS250.
    Here are my threads on modernvespa:
    http://modernvespa.com/forum/topic136163
    and on Moscow Vespa Club forum:
    http://forum.vespaclub.ru/viewtopic.php?id=3847
    I have got and already installed these spare parts:
    ABS wiring
    ABS modulator
    brake lines kit
    digital Clock with ABS warning light
    speed sensor
    speed sensor disk
    front brake cylinder
    And now I face some problems.
    Tha main questions are:
    - is it necessary to change ECU for a possibility to function of the ABS modulator?
    - is it possible to test the modulator pump (is it broken or not) separately (without connection to Vespa wiring)?
    - what is the purpose of these sockets:
    I hope that I will find answrs on this forum
    Thanks,
    Ivan
    Honest always, feared often Micah / AF1 Racing's Avatar
    Jun 2003
    37 miles E. of ATX, TX USA.
    From part numbers it appears to me the ECU for the motor is different between the ABS and non ABS bikes. This makes sense as data from both wheel speed encoder rings would have to be fed to a location? I know of nobody that has tried such a conversion and I surely have never tried such a job, you are a pioneer in the field.
    Diminished expectations is the key to happiness in life.
    Micah Shoemaker
    AF1 Racing
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Feb 2015
    Moscow, Russia
    Hi, Micah!
    Thank you for your reply.
    According to parts list, ECU are the same
    The question is: when Vespa is started for the first time (brand new from the shop I mean) with new ECU, ECU automatically checks, whether Vespa has ABS modulator or no and saves this setup in its internal memory and then works by this scheme.
    Can this decision be a true?
    on GTS250ABS only one ring speed ring is installed.
    If I unplug ECU socket and connect Diagnosis tester to ABS, it also shows the diagnostic info... So it shows that ABS modulator have to function without ECU.
  1. Installation of EVO Fuel Pressure regulator
    By RSVMIllenian in forum SL1000 Falco Forum (all years)
    Last Post: 03-09-2007, 12:32 AM
  2. Install of Motovation Rear Mount sliders?
    By ursusmajor in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 12-17-2006, 05:11 PM
  3. slower after install of chip/airbox??
    By mysubaruimp in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-01-2004, 08:08 AM
  4. Installation of PC111 - a question or two
    By geoff in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 04-10-2004, 10:39 AM
  5. Installation of anodized products......
    By DIRTDOG in forum RST1000 Futura (all years)
    Last Post: 03-17-2003, 04:38 AM
