Results 1 to 10 of 10
Thread: bike won't rev past 6 or 7 k
    indy
    i havn't had the bike running since last november. filled the tank and added the proper amount of fuel stabilizer, then turned off the fuel petock.
    the other day i removed my arrow exhaust and added a jolly moto exhaust.
    started up the bike and it seemed to run fine. take it around the neighborhood and it won't pull past 6 or 7 k in any gear. in first it revved to about 7 k after i had the throttle pinned for 20 seconds.
    i went back home and removed the spark plug, which only has a few hundred miles on it, and it looks fine. put the plug back in and went back out for another try.
    i thought maybe the engine was just cold but it was actually warmed up to almost out of the blue on the temp gauge.
    it was 80 F. outside also, so it's not that the outside air is to cold.
    the bike runs fine untill it hits 6 k then it just starts sputtering.
    i'm thinking it's not bad gas because if it was it wouldn't even start.
    any clues?
    apriliaforum Junkie 748rsvr999r's Avatar
    Paxton, MA
    Happened to me while I was riding. The choke lever fell off and went way rich, would only do about 15-20 mph, and not rev.
    Fran
    apriliaforum Member FrigidRS50's Avatar
    Mar 2004
    NY
    could be the choke or just flooded carb
    this happened to me similar to 748rsvr999r i had to lean the mixture screw and burn the excess oil out of the i pushed it and ran it downhill up and down a few times pushing way passed 15mph to get a good roll after about three pushes the amount of smoke was crazy but it burned off the excess and ran decent.
    by the way this happened when my bike was brand new the dealer had put extra oil in the carb.
    Don't take life so seriously, you'll never make it out alive.
    Ride Hard, Die Fast
    indy
    bump.
    apriliaforum Junkie frantic_2003's Avatar
    Mar 2004
    woking, surrey
    this has happed to me, i didnt use it for about 3 days, and it just worked after that
    MK SP 70 kit
    Del'Orto 21mm carb
    giannelli full race system exhuast
    pics If the link doesnt work, press refresh
    Oct 2003
    North of Pheonix Arizona
    Mine was a jetting problem with the carberatuer I leaned out my jets and it reved just fine.
    apriliaforum expert luke's Avatar
    May 2004
    birmingham
    my mates wont either
    ________
    Aire Vaporizer Review
    apriliaforum expert JakeRS125's Avatar
    Feb 2004
    Folkestone, Kent
    have u tried cleaning the shite outta ure exhaust system and can?
    thats what happened to my dt50 and this sorted it
    SV650S 2000 X-Reg Blue
    Never Ride Faster Than Your Angels Can Fly
    (believe me, I tried once, and it hurt)
    apriliaforum expert matt2301's Avatar
    Feb 2004
    Left flanking,bags of smoke, on auto lobbin' 'nades
    same happened to me on my TS50. i cleaned the whole lot out and it was fine after that.
    Today when people talk of "living through hell", it usually means that their appeal against unfair dismissal has been delayed, or the builders next door have been very noisy for several weeks. For the millions of soldiers in the trenches of the First World War, their experiences of Hell on Earth were beyond anything those of us born into Britain's most blessed generation can possibly imagine.
    indy
    yeah, i fixed it. needed needle jet adjustment.
