Page 65 of 66 FirstFirst ... 155563646566 LastLast
Results 961 to 975 of 977
Thread: Wiring Mod for charging issues.
  1. #961
    37 miles E. of ATX, TX USA.
    Wanted to run this by you guys, please respond ASAP as this is a bike I’m currently working on. Replacing stator on 03 RST despite it not being bad, bike has been tested on dyno and road, charging system rock solid.
    The version here of the wiring mod i have id I have not seen before? Out of the regulator both positive wires are cut and terminated to a heavy gauge brown wire running direct to battery positive terminal, however instead of T-ing into red/blue pair the red blue pair from the harness side is simply terminated?
    obviously it works but I want to only do this job once...seriously it’s been a rough freaking few weeks. Does this seem OK or would it be a very wise time to make a 5 way T connection, both red/blue wire sets plus heavy brown direct to battery or leave alone?
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
  2. #962
    Sweden, Linköping
    The solid blue wires must be the new ground wires for the R/R and as long as they have a good ground point, it should work.
    If the positives goes to the battery directly without a fuse, its risky.
  3. #963
    Sep 2016
    Varhaug Norway
    Hi guys just unwrapped my fut from it's winter baggy, started first time , checked oil which still looked virginal ,took it it for a small run before a strip and clean . Where I found the dreaded melted brown plug problem , so went to the store bought some crimps and cable ,cut out molten plug and and about 3 inches of molten wire goo! Crimped in new cable to regain the length . Put things back together and she doesn't fire up , all I got was a healthy starter solenoid click ! What have I done wrong ?
  4. #964
    Sweden, Linköping
    If the lights doesnt dim much its the starter solenoid not making electrical contact.
  5. #965
    Sep 2016
    Varhaug Norway
    Ok lights don't dim too much , starter solenoid was replaced last summer for an upgraded one could it have conked out so soon . It worked and started for first start up after winter and started first time ,been on an optimate over winter , I noticed the broken molten plug after a short ride out and decided to swap it out ,I was wondering if resistance through the crimps was stopping things starting ?
  6. #966
    Sweden, Linköping
    The brown connector has nothing to do with the starter circuit once the solenoid is energized.
    Check the resistance over the starter relay when it's energized " clicked". Should be zero.
  7. #967
    Sep 2016
    Varhaug Norway
    Thumbs up
    I left it for a couple of days ,then squirted some lecky contact cleaner over starter switch and starter solenoid and hey presto , we have life . Thanks for your help Deefred.
  8. #968
    Sweden, Linköping
    Unless you do more maintenance it can happen again.
    I would at least remove the cable at the starter and fully clean it. Its a known area for corrosion. If it looks very corroded report back here before removing it. Starter can be damaged if the stud spins.
  9. #969
    Dec 2016
    NH
    Finally swapped the brown connector for 3 crimps even though there was no sign of trouble . 13.8-14v at idle now and I feel better even though she went 16666 miles issue free.
  10. #970
    apriliaforum Member StreetCred's Avatar
    Jun 2006
    Wisconsin
    Years ago I did a mod to the regulator/rectifier where I mounted a terminal block to the aluminum plate that the regulator mounts to. Then I cut the connectors off, soldered on ring terminals to all the wires and connected them through the terminal block. I would still get charging issues and would have put the battery on a trickle charger several times throughout the riding season.
    Flash forward a bunch of years and I now have one of Ricks regulators. My problem(s) is/are:
    1. I have to cut the connectors off the new regulator. I don't have the mating connectors anymore.
    2. I don't know what to do with the 3 yellow wires. I know they go to the stator.
    a. Do they need to be in any certain order?
    b. If so, how to figure out which lead is which?
    StreetCred
    2003 Silver, wiring mod, fuel line mod, de-restricted airbox, HoMade exhaust.
  11. #971
    Sweden, Linköping
    The yeĺllow wires have no order, that's why they have the same colour.
  12. #972
    Jun 2006
    Wisconsin
    Thanks for the input!
    I was thinking that. I just wasn't sure if the wires needed to be in some sort of sequence. From what I can tell they go to 3 sets of windings on stator.
    StreetCred
  13. #973
    May 2015
    The Netherlands
    Dear Futura friends, I recently bought a second Aprilia Futura. Mainly as a back-up for spareparts. Even in the EU it is getting harder
    to find specific parts for our beloved Aprilia. Parts that Aprilia does'nt make any more or are costing a fortune on the used market.
    During the inspection of the bike I came across this. I just wanted to share this with you guys.
    Name:  Aprilia RST 1000 Futura.jpg
    When I had taken off all of the black tape, I got to this.
Name:	Aprilia RST 1000 Futura 2.jpg
    Looks like some one did'nt pay attention to the basic of electronics.
    Rest of the bike looks OK. So far.....
  14. #974
    apriliaforum Member Ollie B's Avatar
    Apr 2015
    Newcastle-Upon-Tyne, UK
    So a while ago I replaced the R/R with an FH 020 AA and re-wired to and from the R/R.
    R/R to battery is 12 AWG and stator wires to R/R (red arrow on photo) is 14 AWG.
    I connected the Aprilia stator wires (blue arrow on photo) to the new R/R wires with crimps and push fit connectors and heat shrinked (shrunk?) them individually instead of using a 3 pin connector. No sure if this was a good idea or not but my thinking was I could easily have a look and see if they're overheating instead of having to extract them from a connector block.
    Anyway, I checked them tonight as I'd noticed my charge volts have dropped from around 14.2 to 14.0, and they are indeed overheating.
    When the bike is running they are too hot to handle.
    My question is what's the best way to stop the pesky things overheating?
    I presume they're heating up due to the resistance of the connector (you can see in the photo that the heat damage is only around the connnector from the small original wire) and soldering is the way to fix this.
    I'd originally avoided soldering them together as the different gauges made it awkward to do but I could persevere and do that.
    Thanks in advance.
    2003 Futura, blue.
    Mods: metal fuel QD, FH020AA R/R, K&N, airbox mod, GPR exhausts, R&G, starter solenoid upgraded, FPR mod, top box rack, side stand cutout, 05 map, fuel tank drains plugged, ignition coils and leads, Oxford heated grips, 12V socket, Hagon shock.
    Previously: ZX6R 636, Firestorm VTR 1000, ZZR600, KR-1.
  15. #975
    It is highly possible the resistance is in the blade connection. Eliminate it. Use adequately sized but connectors. Avoid ones with a split barrel.
