Results 16 to 30 of 31
Thread: A good reason to get new RSV mirrors...
    Nov 2012
    AL, USA
    Pulling the dash panel isn't all that awful. The trim comes out first, then 4 bolts for the dash itself. I've found long standard screw driver works well to push on the locking tabs on the two plugs and giving a little twist while applying pressure to the back side of plugs makes removal of plugs much easier. The loom has a little slack too. As anything on this, once you've done it it's much easier. It's WAY easier than puling the whole front fairing. BTW, really, really avoid dropping little screws into the black hole that is Futura fairing. Unplugging and removing dash panel makes life much easier in there. I've removed mine more times than I care to admit. This is what it looks like with everything removed, hopefully yours is cleaner!
    Name:  DSC00195 - Copy.JPG
    apriliaforum prov-nov rst1k's Avatar
    Jan 2014
    Stanwood, WA
    heres the new mirrors, excited to put them on today!
Name:	RSV Mirror 1.jpg
Name:	RSV Mirror 2.jpg
    2011 Aprilia Dorsoduro 1200 (non-ABS/ATC) - #86 - 5100 Miles - Tail Tidy from AF - FatDuc
    SOLD: 2001 RST 1000 Futura - #298 - Unrestricted - Charging Mod with all solder joints - Mosfet @ 14.2VDC w/ dash mount indicator - Ford Starter Mod - Nano-Tech Dry Battery - RSV4 Mirrors - 31K miles - Michelin Pilot Road 4's
    Jan 2014
    Stanwood, WA
    Replacing the mirrors went flawless. I thought I would have a few hiccups (especially on the air temp sensor) but it went smooth.
    Removed the dash, left it plugged in and moved it side to side for access. The Aprilia tool kit is perfect for this. But here are some pictures for you guys.
    Note: the duct tape was a quick fix on the ferry (when I broke it), but the funny thing is that it was more stable and less jiggly to see through.
Name:	duct tape fix 1.jpg
    Jan 2014
    Stanwood, WA
    The insides weren't super dirty like your picture was, but I gave it a nice wipe down. Also, my view through the mirrors as you can see is a little 'elbowie'. I think I may be extending my elbow outward to see instead of tucking in like before. This was expected and the looks trump the usability. Even on the OEM mirrors I still couldn't see everything I had wanted to. I'm very used to not being able to use mirrors anyhow since my Harley vibrated mirrors too badly.
Name:	broken mirror 2.jpg
Name:	remove dash 3.jpg
Name:	dirty insides 4.jpg
Name:	new hardware 5.jpg
Name:	air temp sensor 6.jpg
Name:	job complete 7.jpg
Name:	blinker demo 8.jpg
Name:	my view 9.jpg
Name:	view through mirror 10.jpg
    Nov 2012
    AL, USA
    Nice! There are some posts about mirror mounts/spacers that fit between talk and body thus raising it and moving out too. Something to consider if you choose. Yours look really good on the Fut. BTW mine is cleaner under the front now LOL.
    Jan 2014
    Stanwood, WA
    It just started raining after a week of gorgeous sunny awesomeness. I was going to test out the new mirrors to see if I need to silicone caulk them to stay put and not vibrate but I would rather not mess around with a super slick road. (first day of rain is always the worst after the oil has been baked out of asphalt). So maybe tomorrow if it gets better.
    Jun 2010
    Netherlands & TŁrkiye
    Gixxer K5 and up mirrors will also fit !
    01 Futura [infinity blue]
    May 2007
    Durham U.K.
    But do need an angled spacer.
    Nov 2012
    AL, USA
    Might thin plastic shims help the shaking? It helped my stock mirrors a lot.
    Oct 2012
    SW Idaho, USA
    sorry for the delay, just had internet turned back on at home. they may seem a bit wide, but with all the gear I'm hauling I really like to see what is behind me clearly at all times. to each their own.
    here is Folded in,
    extended,
    driver position
    Nov 2012
    AL, USA
    They take a little getting used to, but look very effective as actual rear view mirrors. The large signals and folding like that is a plus. Did you mount the temp sensor?
    apriliaforum Member BadMiker's Avatar
    Feb 2013
    Southend on Sea - UK
    With them folded in are they as narrow as the stock folded in or a bit wider? It is kinda hard to tell from your folded picture.
    I think they look great though! I am sick of not knowing what is exactly behind me. It can be hard to see other riders who follow in your tyre tracks.
    Thanks!
    "A good traveler has no fixed plans and is not intent on arriving." - Lao Tzu
    2001 Futura
    Mods: HEL Front and Rear SS Brake Lines, Rear Hugger, Scott Oiler, Oxford HotGrips with eBay LED Dimmer Control, Garmin GPS and RAM Mount, Moko Frame Protection, Elextrex World MOSFeT RR with Wiring Mod, Tom Parker Metal QDís, Loud Ass Ford Transit Horn, Silicone Vacuum Lines, FPR Mod, De-Restricted Intake, 05 Map, Datatool System3 Immobiliser, Yamaha Starter Relay, BagLux Tank Cover and Alpha Bag With Power, Perelli Angel GTs, 25mm 170 Amp Power and Ground Cables, LED AUX Lights, LED Turn signals Converted to Running Lights, 3-Beam Main Beam Mod, Dash LEDs, HID Low Beam, Fuel Filler Neck Chop.
    To Come: Exhaust, Rear Shock, Forks and Brakes.
    Oct 2012
    SW Idaho, USA
    I have the temp sensor mounted on the left mirror stalk, I'll get a pic when I get home today.
    When folded, I believe the mirrors are more narrow than the footpegs, as I push this bike into the house the pegs catch but not the mirrors. I'll get some measurements too if you like.
    Oct 2012
    SW Idaho, USA
    temp sensor
    folded in they are 29" wide. the handlebar weights are 30" wide
    Nov 2012
    AL, USA
    Nice.
  1. Good place to get Tuono mirrors ? UK please.
    By Jollyjeweller in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 04-25-2012, 03:56 PM
  2. Capo to get new 1200 V-Twin?
    By Sye in forum ETV1000 CapoNord (2001-2007)
    Last Post: 06-03-2006, 10:51 AM
  3. A good way to get fast...er?
    By rsvmilleR1 in forum Aprilia Privateer / Club Racing
    Last Post: 06-07-2005, 06:33 PM
  4. Reasons To Get A Scoot Instead Of A Car!!!
    By mojito manini in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 02-13-2004, 03:47 AM
  5. Good Place to get Custom leathers?
    By Italibikefreak in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 02-05-2004, 04:03 AM
