Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 206
Thread: XV Tuner : Map Editing SXV/RXV maps
  1. #46
    apriliaforum expert Markee's Avatar
    Feb 2008
    Melbourne, Australia
    It's temp related I believe so once the temp says it's warm enough it switches to a running map.
    '09 MXV450
    Quote Originally Posted by Alice Racing View Post
    The motor and maps are race orientated, and want gunning !!
  2. #47
    Feb 2009
    Tri-Cities, Washington
    While cranking, a fixed 12 degrees of advance is used and the fuel uses an enrichening table that I think is based on the values from the main warmup / run tables, whichever is currently in use.
    Once the engine is started, the ECU will use the warmup tables for a period of time determined by engine temp as mentioned. The minimum time that warmup tables are used is ten seconds. The colder the engine, the longer it will use the warmup tables before switching over to the run tables.
  3. #48
    apriliaforum Junkie nez_fer's Avatar
    May 2012
    Ucluelet BC
    Cold start fuel mixture
    Quote Originally Posted by SXVINWA View Post
    This is what I was wondering. So if this is correct, enriching the warmup table should do the same for the "cranking" table.
    The reason I'm asking these questions is in preparation for the dreaded winter season when it's below 10 Celsius. Historically my bike has been a bitch to start below 10 Celsius. I haven't seen those temps since Amauri rebuilt the motor, but if I do experience issues this winter I'd like to test different "cranking/cold start" fuel mixtures.
  4. #49
    Nov 2008
    Western Australia
    A question...
    This came to mind because I was reading the post Stu at Alice racing did sometime back about tuning the SXV...
    In ROMRaider the maps have a limited number of throttle positions two of those positions being 0% and 2%...
    Now if the bike is having idle set at 4%, then how will those points being used?
    Can you set the TPS to 0% at your idle adjustment, and then just modify your map to make use of the two extra throttle positions?
  5. #50
    Feb 2009
    I can't think of any reason that wouldn't work, but if you adjust the idle setting down after setting the min value, the ECU wouldn't recognize it as being lower and couldn't adjust the fueling. Not a big deal, but that should be what would happen.
    Do you really feel the need for a couple more rows of data table around a near closed throttle position?
  6. #51
    Jan 2006
    Ohio
    Change cranking value to 8, yes it helps.
  7. #52
    May 2012
    Ucluelet BC
    I believe KWest stated that some maps don't inject fuel until after 6 engine revolutions and others only 2 revolutions. What is the reason for 6 vs 2? Does anyone know if there is an editable RXV550 (no solenoid) map that has the 2 revolution delay?
  8. #53
    Feb 2009
    The number of revolutions before injecting changes with coolant temp. The colder it is, the more revolutions it delays. I think all of the factory maps use the same delay, but the Alice maps have been altered to much lower values.
  9. #54
    May 2012
    Ucluelet BC
    Little hesitation - need help
    EDIT: Figured it out. I didn't advance the timing enough in the problem area. I advanced the timing by 3 points from 10-22 degrees and 4500-5000 RPM. Should have known. I found my answer in one of my previous posts.
    I have edited a map for my RXV550. I've made it smoother/softer below 6000 RPM for off road single track and fixed a hesitation just off idle. It's almost perfect for my bike, but it still has a hesitation in a specific area. The hesitation happens right after shifting up a gear, RPM between 4500-5000 (at least that's what the display reads) and throttle up to around 1/4. Once I open the throttle more it quickly picks up and it's normal. I'm not exactly sure, but it seems to only happen after closing the throttle for the shift then opening and only in that RPM range and throttle position.
    I've attached images of the Fuel and Ignition. The grey highlighted areas seem to be where the problem is.
    I'm hoping to get some pointers from those who have first hand experience with fuel and ignition mapping.
    Thanks in advance.
ID:	278674Click image for larger version.
    Used to own 2007 Aprilia RXV550 Dirt and SUMO.
    2014 Beta 498RR.
  10. #55
    Jun 2015
    Sweden
    How did you get the RomRaider program to work?
    I only get an error message about not finding the right ECU something when starting the program!?
  11. #56
    May 2008
    GREECE
    You need to locate the .xml file though romraider options, Then it can recognize the .bin files
    I am not at my pc now and i canno remember which menu is that.
    Think it is under the ECU-DEFINITIONS menu on the top bar.
  12. #57
    Nov 2008
    Western Australia
    Do you have the maps and definition?
  13. #58
    Jun 2015
    Sweden
    Quote Originally Posted by S4R View Post
    I have all the maps but no definition only the standard RomRaider xml. thing downloaded and pointed (in settings) out according to the installation instruction.
    Only Subaru ECU in the .xml file
  14. #59
    Nov 2008
    Western Australia
    Yep, you need the definitions and the maps that come with it...
  15. #60
    Jun 2015
    Sweden
    Ok now I understand, I have the program and definitions installed like the instruction explain but still got the error message, same message for .bin or map!?
    RomRaider 0.5.9 Release Candidate 2 +
    ROMRAIDER ECU DEFINITIONS UPDATE version 0.8.3.1b Oct. 7th, 2009
    To install ECU defs:
    • Download the file of the units (metric or standard) you would most likely use from the bottom of this post.
    • Unzip the ecu_defs.xml file into your main RomRaider directory replacing the existing file (if applicable) or in another directory of your choice where it is unlikely to be moved or deleted.
    • Run Romraider and select "ECU Definitions" -> "ECU Definition Manager" from the menu bar.
    • If any definitions files are listed, select each file and click "Remove".
    • Click "Add" and select the location of the new unzipped ecu_defs.xml file.
    • Click "Save".
  1. XV Tuner Cable for SXV/RXV
    By ShaunH101 in forum Other Stuff For Sale
    Last Post: 05-09-2013, 03:37 AM
  2. XV Tuner maps ??
    By Carontespeed in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 03-10-2013, 04:21 AM
  3. For Sale KWEST tuner Cable for SXV/RXV 4.5/5.5
    By kennygene in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 01-30-2013, 08:06 AM
  4. 2008 SXV and RXV maps
    By Ed / AF1 Racing in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 12-22-2007, 12:24 PM
  5. Tuneboy Maps for SXV & RXV
    By yellow.speedy in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 03-26-2007, 10:46 AM
