Results 16 to 30 of 54
Thread: Futura Information/Repairs
    Nov 2012
    AL, USA
    There are a number of threads about the King Bearing, though sadly it seems this last "Batman" is the most hideous and there have been a lot of good hints given. The usual suspects that are always helpful with their insight and experience. When it's finally all done I'll do kind of a recap.
    Dec 2012
    uk
    Hi All
    Just wondering if here is a post for the headlight mod to keep all lights on in high beam would like to do that
    Oct 2013
    United States
    Added the high/low beam switch mod.
    Added the helmet locks/hooks mod.
    Oct 2013
    United States
    Added Evoluzione clutch slave fix.
    Added a link to the Futura fork servicing article.
    Added emperorluigi's Givi MonoKey custom mount.
    Oct 2013
    United States
    Added vacuum line check valve part numbers
    Added vacuum line check valve repair
    Added rear bag mount rubber attachment repair
    Nov 2012
    AL, USA
    Thank you!
    Oct 2013
    United States
    Added ground connection repair (with pictures!)
    apriliaforum newb Chawkster's Avatar
    Nov 2010
    Hampshire
    Is there a cam timing "how to"?
    2003 Aprilia RST1000 Futura, rebuilt & repainted BMW Imola Red. De-restricted, wiring mod, metal QD, FPR mod with silicone vac lines, home-made H-Pipe, R1 end cans, CBR coils + Magnecore leads, timing set to 103/106, flywheel weight removed, '05 map, RSV forks, RSVR 320mm front discs, Brembo radial clutch and brake master cylinders, custom HEL brake lines, RSV mirrors, heated grips, GIPRO gear indicator & sparkbright battery monitor integrated in dashboard, HID headlight with lightswitch mod, LED sidelight, hazard lights, Audi horn, powedercoated wheels and side castings
    KTM 453EXC enduro/supermoto
    May 2007
    Durham U.K.
    Cam timing, plenty on here. Do a search for cam timing.
    There are lots of threads and discussions, read it all twice or more till it sinks in. It takes a bit of getting your head around and doesnt all make full sense untill you dive in.
    It takes me a good week of 3hrs per night do time up a motor.
    You need to be methodical. If it goes wrong!!!!!!!!!!!!!! ouch.
    Slotting the cam wheels is the hardest part.
    For a futura 103/106 is the accepted setting.
    Nov 2012
    AL, USA
    ^^^^^^ A slotted gear kit is available from AF1.
    Nov 2010
    Hampshire
    Thanks, just struggling to find info and method all in one thread!
    I'm prepared for the time and awkwardness of the task, have timed cams in before but not on a bike. Its just small things like can i trust the TDC notches to be accurate? I have now bought a TDC tool to get it 100% accurate. And its a v engine...
    Slotting cam wheels is easy for me - luckily i work in engineering and have a supplier who can machine them for me.
    Biggest concern is the cam cover bolts, plenty of corrosion on the cam cover so i think i may have problems removing them...
    103/106 is interesting as the RSV boys seem to go for 106/106. I guess this gives better mid-range more suited to the character of the Fut
    Wish me luck and thanks for your help
    Nov 2012
    AL, USA
    Keep us posted. I chickened out on this one.
    Jun 2006
    Columbus, GA
    Quote Originally Posted by Argh Oh View Post
    Mine was TALLER than stock but fits. Mostly.
    Check that. The YTZ14S is shorter than the OE ytx12-bs
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Nov 2012
    AL, USA
    Honest, it's taller. Sorry, YTX 14-BS. ​My bad.
    Aug 2006
    Santa Cruz, CA
    Thank you. A very useful thread.
  1. Futura and Caponord dash repair
    By meanstrk in forum RST1000 Futura (all years)
    Last Post: Yesterday, 03:47 AM
  2. Futura H pipe order information
    By Honeybadger in forum RST1000 Futura (all years)
    Last Post: 04-08-2018, 09:22 AM
  3. Futura Mirror Repair
    By ffraz in forum RST1000 Futura (all years)
    Last Post: 10-19-2010, 10:14 AM
  4. 2001 Futura spares or repair
    By jezfest in forum RST1000 Futura (all years)
    Last Post: 10-11-2010, 08:58 AM
