Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 117
Thread: Fun with mapping.
  1. #46
    Who cares? I must have the fastest goddamned Griso on the planet!
    Pete
    Professional Goat Burster.
  2. #47
    apriliaforum expert pokeyjoe's Avatar
    May 2013
    Long Beach, CA
    Who cares?
    Good question. If it's a hobby and no more, then have at it. It sounds like its a bit unhealthy, though. Especially when it moves from forum to forum (like that would make a difference in the outcome). Chin up, enjoy yourselves and agree to disagree, I guess.
    ___________________
    John
  3. #48
    Roma, Caput Mundi
    Quote Originally Posted by GuzziOrDeath View Post
    Yes & no. The PCV does as you say, time it's injector pulses based in signals from the ECU, but it uses it own map to calculate the pulse width and it ignores the pulse width times from the ECU.
    totally wrong.
    PC map is only a "correction map". Let me try explain with an exhample:
    Suppose that at given RPM and TPS the ECU fuel map says "10ms opening for the left injector" and "8ms opening for the right injector".
    Says the PC correction map value is "+5" at that RPM/TPS, it will add roughly 5% in injector squirting time in both cylinders.
    That means 10ms+5% for the left injector and 8ms+5% for the right one... So the balancing in fueling for the 2 cylinders is still the one that the ECU says, but proportionally altered by the PC map.
  4. #49
    Nov 2013
    Earth
    Ahh. Thanks. ka-ching. That explains a niggling thought I had. It also re-inforces why the PCV I had grossly overfuelled my Griso. The map in the ECU has been modified to add more fuel by the vendor, and the correction map can only be trimmed by the autotune that samples from a single sensor. Perhaps if the map in the ECU had been better thought out, and then Griso's exhaust allowed for sampling with a dual channel autotune, the result may have been better.
    It's a moot point now. GuzziDiag allows for easy (free) adjustment of the map, and the PCV is not required.
  5. #50
    Roma, Caput Mundi
    PCV overflued your griso maybe becouse you've been not able to proper set and/or use the autotune module.
  6. #51
    Roma, Caput Mundi
    Guzzidiag like TuneEcu are powerfull tools, but needs an experienced user to be effective.
    Any person not understaing what's going on should just flash known working maps. After that, a PC is still the better tool for the medium user in order to get a spot-on fueling.
  7. #52
    May 2013
    Long Beach, CA
    ad nauseam...
    ___________________
    John
  8. #53
    Nov 2013
    Earth
    Totally wrong.
  9. #54
    Nov 2013
    Earth
    Couldn't agree more re GuzziDiag, but disagree re Powercommander, especially with the 8V engine.
  10. #55
    May 2007
    Hesperia, CA
    Quote Originally Posted by Hellgate View Post
    For what it's worth I'm interested as there are so many hours in a day to read forums.
    Besides, if I joined a Guzzi forum it would take years for me to build any respect at all. I mean look how long it took me to garner any respect at all here. Geez..
    yeah right.
    hush up and ride your Guzzi. (That's what I'm doing Saturday - Mulholland)
    #1 Forum Magic Missile Caster
    1972 Laverda SF 750
    2007 Moto Guzzi Griso 1100
  11. #56
    Well, today I rode up to Sydney, prior to Goulburn, at least at the time I set off, I was unlikely to meet the wallopers or any kangaroos so the first sevent Km was a good hard flog travelling between 140-160 for a lot of it. From Goulburn to the warehouse in Millperra its all boring freeway where you can't go more than 120 kph but its virtualy to the door of the importer. Despite the harder riding that I usually would do in the earlier part of the ride the bike returned fuel economy about 12% better over the distance. Impressive. It also fuels up damn near perfectly throughout the range.
    Sorry, I've never seen an 8V do that with a PCV/AT set-up. Just sayin'
    Pete
  12. #57
    May 2012
    Cherryville, NC
    This place is fun! Interesting reading Pete.
  13. #58
    Feb 2013
    Wollongong/NSW
    " I rode up to Sydney, prior to Goulburn,"
    Peter if that is from Bungendore through Tarago it is a really great ride.
    I even saw 150 on the Griso on the way down to have the Cark replaced.
    Scenery is beautiful, and on a weekday no other vehicles.
    Harry
  14. #59
    Yup, that's the road. You have to be a bit careful after you leave Lake George because of the 'roos and there is that 8km straight stretch just before Wakefield Park raceway where the wallopers like to lurk in the trees but most of the rest of it is real 'Guzzi Country' with good visibility for both wildlife and wallopers. Its part of my 'Test Track C' I use after major rebuilds.
    Pete
  15. #60
    Oct 2013
    Gettysburg
    Having spent my entire life in the states I did a search for the definition of the word "Waloper". I found a few. The first : Uniformed cops are generally known as 'wallopers' or the second : A Scots word meaning a penis, usually large and floppy. I am guessing it was the first. At least I hope.........
  1. The most fun with your clothes on!!
    By jimmylegan in forum RS125 Euro-archive
    Last Post: 11-30-2005, 04:30 PM
  2. Fun with PCIII - Help
    By Waxerdog in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 06-06-2004, 04:52 AM
  3. Confused with maps..........
    By krisstiffer in forum RST1000 Futura (all years)
    Last Post: 04-23-2004, 03:57 PM
  4. You Guys should have fun with this
    By Dveloped in forum RS250
    Last Post: 01-31-2004, 06:52 AM
  5. Fun with toe pieces
    Last Post: 08-06-2003, 08:23 PM
