Page 3 of 8 FirstFirst 12345 ... LastLast
Results 31 to 45 of 109
Thread: Saying goodbye to the F255 and hello to the A2BF, or how I went from 51s to 57s.
  1. #31
    apriliaforum Junkie GavGrim's Avatar
    Jul 2012
    Alberton, South Africa
    I think this is just yet another damn good tip on this brilliant forum!
    Well done Gab and Dan, I shall be doing this mod to my bike as well soon enough.
    Gav
    It's hard to beat man or machine that just won't give up...
    '02 RSV Mille - Tornado custom can, Tornado dual collector mod, Gabro F255 chip, Evo style open air box, SBK shorty levers, 17/44 gearing, ProGrip grips, ODI donuts, LED Indicators, Blue Matrix screen - 132 whp and 100nm
  2. #32
    apriliaforum Member Belden's Avatar
    May 2011
    Norway
    Great thread! Learned a bit more about the mysterious pneumatic clutch!
    Does anyone know the size of the vacuum hoses, and the size of the check valves and T's needed to make the double valve modification?
    I am away from home for a couple of weeks now, but the parts are easy to get a hold of here in this area.
    2000 RSV Mille (R-ish)
    -Öhlins radial front
    -Öhlins rear shock
    -O.Z Wheels
    -Arrow exhaust
    -Collectormod
  3. #33
    NE, PA
    Quote Originally Posted by Belden View Post
    I used 1/4" SAE 30R6 fuel hose and a 1/4" T
    1985 Honda VF500F Interceptor Red
    1985 Honda VF500F Interceptor Blue
    1992 BMW K1100RS ABS
    1993 Honda CBR600 F2
    1995 Ducati 916 Monoposto
    1999 Aprilia RSV Mille
  4. #34
    Apr 2010
    california
    57mm Siemens Injectors chip
    Just received our chip for the Tuono Racing which we've fitted with late 57 TB's. Fuel pump activates - But it appears we don't have an injector signal. Nomenclature on the chip is puzzling and I've e-mailed Gab - but in the meantime has anyone done one of these and does this prom look familiar?
Name:	57mm Conversion 011.JPG
Name:	57mm Conversion 001.JPG
    -doc
  5. #35
    NE, PA
    I did it but the EPROM I got was labeled A2BF instead of AE40. I'm wondering if the nomenclature has to do with a checksum or other value from the EPROM's .bin file. It looks like it could be hexadecimal code. A2BF converted from Hex to Dec is 41663 and AE40 is 44608.
    Are you using a test light on the injector wires or are the injectors hooked up and not squirting fuel? Could the injectors be clogged? What injector plug adapters are you using to go from the Denso harness to the Siemens injectors?
  6. #36
    Apr 2010
    california
    Whatever the nomenclature is, there's no injector drive. We have 4 ECU''s - a quick swap shows LED noids firing with any of the other ECU's. Swapped the prom over as well and no pulse. Interesting the fuel pump activates and we have ignition, there just isn't anything on the injector side.
    I sent Gab an e-mail with the same photos and results.
    -doc
  7. #37
    NE, PA
    What did you use to cap the IAC holes? Set screws? Looks very tidy.
  8. #38
    Apr 2010
    california
    10x10mm (fine pitch) set screws
  9. #39
    Roma, Caput Mundi
    Dan's chip is a special version of the Fiona chip. instead of 2 different injection tables Dan's chip has 2 different ignition.
    the code is the .bin file checksum (that's the faster way to search for bin file in the hard-drive )
    @Boris:
    sometimes chips get damaged during shipping. starting from about 1 year ago the number of chip damaged increased a lot... i suppose the post service now inspect the evelope with some sort of ray machinery that sometime kill or partially damage the chip.
    gonna ship a new one
    www.gabroracingteam.it
    Visit my FB page and like it!
  10. #40
    Apr 2010
    california
    And there's the answer.
    -doc
  11. #41
    Apr 2010
    california
    installed
Name:	57mm Conversion 013.JPG
Name:	57mm Conversion 014.JPG
    -doc
  12. #42
    apriliaforum Junkie dnol04's Avatar
    Sep 2008
    Kerry, Ireland
    little tip:
    you can put 2 check valves in parallel (or keep one check valve and add a T and 2 hoses) and connect that second suction leg of the PPC the other throttle body.
    slipping funcion of the clutch will be greatly improved, and cluch lever will be effortless
    Just wondering how does fitting a second check valve make the clutch action lighter, is this the same with the gen 1 throttle bodies ?
    ROAD RACING IRELAND...DO IT BETWEEN THE HEDGES
  13. #43
    apriliaforum expert flossy's Avatar
    Jan 2012
    Seq/Qld Auzzieland
    Quote Originally Posted by dnol04 View Post
    love to know that one 2, my clutch is heavy as is but to make it easier as said with this mod without slipping would be nice to know what's needed, any further pics on how to achieve this, for a lay mans guide, cheers,
  14. #44
    Sydney, Australia
    Sorry to say but how do all you guys find this clutch so heavy on this bike?? It's an hydraulic clutch for fook sake!!
    If you want a heavy clutch go and use an old bevel ducati cable clutch for a change....now that's heavy but not insurmountable! Seriously I reckon computers, ipads, iphones, have made all you young blokes wimps!!
    As an after thought of the above maybe wank a bit more to build the strength in your wrists, as the Ape clutch is not HEAVY at all!!!
  15. #45
    Roma, Caput Mundi
    it doubles the number of vacoum pulsation, so the average pressure is less.
    yes, the mod can be done on Igen too, but only from '00 onwards... first production TB's had no front cylinder plugged connection.
  1. Saying goodbye to the RSV and headed over to the '02-05 Tuono crowd
    By jmardy in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-27-2012, 06:15 AM
  2. Time To Say Goodbye (to the Mana)
    By mt682 in forum 2008-2014 Mana 850 and Mana 850 GT-ABS
    Last Post: 09-09-2011, 12:20 AM
