Page 34 of 34 FirstFirst ... 24323334
Results 496 to 509 of 509
Thread: What did you do with your Falco today?
  1. #496
    Jul 2005
    B-More, MD
    Quote Originally Posted by Yzf600r View Post
    It appears the boot of your radial master is damaged. They're an original Aprilia part and not that expensive I believe. Would definitely put on a new boot to avoid grit entering the master cylinder and scoring the bore.
    On second thought it might be a KTM part.
    Good eye. I know both of them are trashed, hadn't been able to find replacements yet. Thanks for the heads up.
    Sent from my XT1254 using Tapatalk
    Bill
  2. #497
    Oct 2004
    San Marcos, California, USA
    Not to spam but I have a radial clutch and brake pump w/ good levers that I'll let go very reasonably. I'm selling because they get fouled on the Tuoldo fairing and mount I'm using.
    Thanks for the answer on the bolts, Bill. I already had an order with these guys. They came in and I guess they look ok.
    Dogs are the best people.
  3. #498
    Oct 2009
    My answer to the issue adjustable lockstopsClick image for larger version.
ID:	382755Click image for larger version.
    Quote Originally Posted by SoulDaddy View Post
  4. #499
    Oct 2004
    Interesting approach, but I don't think those will still allow a full lock to lock turn without having some contact with the fairing mount's outboard edges.
  5. #500
    Jun 2012
    CLT, NC, US
    Quote Originally Posted by redratbike View Post
    Those look great!
    Stuart
    2001 Falco
  6. #501
    Oct 2003
    NUNYA, USA
    Whilst having my water pump rebuilt, I took the time to take out the starter motor and clean up the main terminal.
    Wow! That thing has NEVER started SO fast after some much needed maintenance!!
    Don't forget to lube the oRing on the shafted end.
    gr
    It's not the years, it's the MILEAGE!
  7. #502
    Oct 2004
    Did you disassemble the starter and clean up the insides?
  8. #503
    Oct 2003
    NUNYA, USA
    Quote Originally Posted by ghostrider71 View Post
    gr
    Nope. Is that even POSSIBLE???
  9. #504
    Oct 2004
    Why, yes it is. Yes it is indeed.
    click, if you must.
  10. #505
    apriliaforum Member GREYOZ's Avatar
    Jul 2005
    Australia Melb out in da hills
    Not today but back in January(Summer in Oz) A few of us did a quick over nighter up and over the mountains. Camped one night at Omeo. Click image for larger version.
    Slippin an a sliden
  11. #506
    Jan 2009
    adjacent the twisty roads of the Adelaide Hills
    Looks like a great spot & good mix of bikes ☺
  12. #507
    Jun 2012
    CLT, NC, US
    Love that blue!
    Stuart
    2001 Falco
  13. #508
    Oct 2003
    NUNYA, USA
    How do you keep the front wheel on the ground with that HUGE tailbag???
  14. #509
    Feb 2016
    Denmark
    There was a slight vibration in the clutch lever when engaging and disengaging the clutch. Not when either engaged or disengaged.
    It was the clutch thrust bearing as described here https://www.apriliaforum.com/forums/...-bearing-noise
    It was an easy fix to replace. The vibration is gone now. But I mention.it because there were small metal fragments in and around the bearing and I expect it would lead to more serious problems if ignored.
    So if your clutch vibrates slightly when pulling it in do not wait to find out what it is, just make the quick easy repair and sleep better...
  1. What did you do to your RSV Mille today? (Version 1)
    By doracle1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-17-2019, 11:59 PM
  2. What did you do on your Shiver OR Dorsoduro today ??
    By mh_dorso750 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 09-17-2019, 10:59 PM
  3. What did you do to your Caponord today..!!!!
    By BigSteve in forum ETV1000 CapoNord (2001-2007)
    Last Post: 09-09-2019, 07:05 AM
  4. What did you do to your bike today?
    By Sign Guy in forum RST1000 Futura (all years)
    Last Post: 03-21-2012, 10:37 PM
  5. What did you do on your CBT?
    By King Vegeta IV in forum RS125 Euro-archive
    Last Post: 07-05-2006, 02:39 PM
