Results 1 to 7 of 7
Thread: Engine RPM sensor
    apriliaforum Member zviadi's Avatar
    May 2013
    St. Petersburg, Russia
    Engine RPM sensor
    The other day, checked the engine RPM sensor - a diagnostic computer shows a logical error P0336. The resistance of this sensor is in the lower limit of the tolerance - 110.9 ohms.
    Checked the connectors 20 and 35 in ECU - all right. That is to blame Engine RPM sensor. Need to change it.
    Began to look microfishes and found that these sensors are of two types - for motorcycles without ABS (№ 896062, the price of AF1 is 71$) and for motorcycles with ABS (№ 859792, the price of AF1 is 25$). These data are taken from microfishes of dealer, for official use.
    This sensor is located on the left side of the generator cover and reads from the rotor. What does the ABS? Why is three-fold difference in the price of sensors?
    Maybe I'm wrong looked microfishes?
    Sensor position 19 in the picture:
    EBR1190RX
    May 2013
    Strange thing - numbered 859792 in microfishes set the ABS sensor, mounted on the wheel, and in microfishes of dealer - engine speed-sensor...
    Sensor position 26 in the picture:
    Error in microfishes of dealer? No one knows?
    EBR1190RX
    May 2013
    It looks like everything is much more serious than I expected ...
    It seems to me that the engine RPM sensor has a total cable alternator, respectively I have to buy an alternator assembly, which is 182$
    EBR1190RX
    apriliaforum expert lanter's Avatar
    May 2009
    Guilford CT
    Isn't your bike under warranty ? You shouldn't have to buy anything.
    2011 Dorsoduro 1200
    May 2013
    If I do not buy this sensor for my money, the dealer will take it to me in Italy for three months. And in November here (in the Russia) motorcycle season ends and winter sets. I'd rather pay out of pocket money than three months will walk.
    The question is not about the money, the question - what partnamber of this sensor. I could not find it, the dealer too.
    EBR1190RX
    May 2013
    Apprised of the microfiche, together with the dealer!
    Turns out I was right - the engine RPM sensor comes with the alternator, it is a single assembly. A similar device have snowmobiles and Japanese motorcycles, such as Intruder 1500.
    Thank you all.
    EBR1190RX
    May 2009
    Guilford CT
    Glad you got it worked out zviadi!
    2011 Dorsoduro 1200
  1. RPM Sensor
    By lotto2k7 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 06-28-2009, 05:01 AM
  2. RPM Sensor
    By lotto2k7 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-17-2009, 03:20 PM
  3. engine temperature sensors/excessive fuel consumtion?
    By Caponerd in forum ETV1000 CapoNord (2001-2007)
    Last Post: 07-10-2007, 11:23 AM
  4. Engine Temp Sensor???
    By skip in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-30-2006, 03:20 PM
  5. Cornering (engine RPM)
    By kaplano1 in forum RS125 Euro-archive
    Last Post: 04-03-2004, 03:09 AM
