Results 1 to 15 of 29
Thread: Futura chain adjustment
    Sep 2005
    Minnesota
    Is there a state secret on how to adjust the Futura chain? I read the manual and used the pin wrench (developed by a pin head BTW) and I can't move the adjusting wheel, not that the wrench helps at all. The two bolts are completely loose.
    I tried moving it with a drift, and even that doesn't move it much, plus I am concerned it will deform the detents on the adjusting wheel.
    2002 Aprilia RST Futura
    2006 Ducati 999s
    1986 Honda VFR700
    apriliaforum expert Dr_Jakob's Avatar
    Apr 2007
    Mengeš, Slovenia
    Put the bike on the centerstand and in neutral. Loosen the two No.13 bolts at the back, then use the chain tensioner to adjust the chain. Rotate the wheel as you adjust the chain. Don't forget, it has to be around 2,5cm free play on the chain. That's it.
    I am not here. What is "here"? Isn't "here" just "there" without a "t" ?
    apriliaforum expert Powerful Pierre's Avatar
    Nottingham, UK
    Sounds like its seized, might need to let some penetrating oil soak in there before you try again....then tap it back & forth and apply a bit of patience, soak it some more if it won't go at the first attempt.
    Aug 2006
    Santa Cruz, CA
    You're right, that adjusting wrench is useless. Try some lube and a long screwdriver with a hammer.
    Nov 2012
    AL, USA
    It took a lot of penetrating oil, patience, gentle prying, tapping, patience, oil, etc to free mine up. If it works as designed, the wrench actually does work.
    apriliaforum expert Robert Borchert's Avatar
    Feb 2013
    California
    KD Tools, I believe, makes an alternator tweaking tool. I have one in the toolbox for those older V-belt installations. It is much bigger than the basic one in the tool bag, and it has a cut for your basic square-drive SAE breaker bar. I'll have to dig it up for a photo for you.
    With something like that, you can break the cylinder free. The best penetrating oil is ATF diluted with some acetone. Be careful twacking the teeth with a hammer and drift!
    I was lucky, I guess. Mine rotated easily using the supplied one.
    I'll be running some errands this afternoon, so making a quick run by the workshop fits into the day's schedule. I'll make it quick before they try to give me a problem to look at...day off today.
    I found a pin spanner listed on eBay here. Scroll down to the sizes available. Still, I'll locate mine and will look for a mfg. part number for you.
    Bob
    Sep 2005
    Minnesota
    Argh Oh - what penetrating oil did you use?
    Bob - by ATF, I assume you mean automatic transmission fluid. Any concerns about the ATF/acetone mixture getting on parts? Any other suggestions for penetrating oil as I don't have easy access to acetone (or is that readily available)?
    2006 Ducati 999s
    1986 Honda VFR700
    Feb 2013
    California
    I learned about automatic transmission fluid from hanging out with machinists. ATF is something like, 3wt, but a bit of acetone is a brilliant solvent to thin it for "nut busting".
    I've had good luck with "PB Blaster" over the years as well. With the swingarm, there isn't any paintwork to worry about unless you drool onto the rear wheel, but that's remedied with some handy shop towels.
    Speaking of machinists, I have a diesel cylinder head to pick up as well. Plenty of honey-dos today. Even located a donor car for a new block for a second engine that grenaded last week. Still can't believe that one. I'll get photos of the melee.
    Bob
    apriliaforum expert MartDude's Avatar
    Nov 2008
    Shropshire, UK
    This just prompted a stray thought. If they were available, would you fit a fully-enclosed chain-guard, to keep the road crud off the chain? You know, like we used to have in the 'Good Old Days'?
    It flies sideways through time
    It's an electric line
    To your zodiac sign
    I've got a Yellow Machine
    2002 Futura, Silver - now sold
    1996 Moto Guzzi California 1100i
    2005 Moto Guzzi California EV
    Calis are Cool!
    Feb 2013
    California
    Nah, the 525 chain is an O-ring type, with the pins' primary lubrication sealed within. If you use a proper chain lube, like Bel-Ray's Super Clean, for example, the exterior is relatively dry and remains quite clean.
    The key is to adjust your chain properly so that it rides smoothly.
    If your chain was gooped up with heavy lube in the past, take the time to pull the fairing lower and remove the drive sprocket cover, and clean up the interior. With a properly maintained drive chain, it will stay clean for some time.
    Bob
    Sweden, Linköping
    I greased my excenter at installation 4 years ago and it turns easy for chain adjustments.
    Aug 2006
    Santa Cruz, CA
    Also, it's easier to lube/service/adjust with spanner tool when wheel is off.
    Sep 2005
    Minnesota
    Wheel is off. I'm going the penetrating oil route, as it still doesn't move.
    BTW, what do I lube on the drive side of the rear bearing assembly, once I get the cush cover off?
    2006 Ducati 999s
    1986 Honda VFR700
    Feb 2013
    California
    Motech has a good thought there, as I just confirmed at the shop. The rear cog bolts interfere with the alternator tool, as does the tire when using a longer (Kowa Seiki) pin spanner.
    Remove the two pinch bolts completely, and spread the rear pinch a little bit using either a large screwdriver blade or a properly-sized chisel blade. Only expand the pinch enough that you see the tab move a little bit. Apply the penetrant at the crack, and at the left side teeth, have a beer, and see if the assembly will break free after it's soaked for a few.
    To lube the cush side splines, a little grease should do the trick. I've always favored a dab of anti-seize on spline teeth as well.
    Bob
    Nov 2012
    AL, USA
    What Bob et al have said. I gently spread the pinch, squirted PB Blaster, tapped, revisited. Tapped the cog slightly to turn, eventually it freed up enough to do than any adjustment using spanner.
  1. Chain adjuster tool
    By RPB in forum RST1000 Futura (all years)
    Last Post: 12-16-2011, 03:30 PM
  2. More chain adjustment woes
    By lotus7 in forum RS250
    Last Post: 10-25-2004, 07:32 AM
  3. chain adjustment impacting brakes?
    Last Post: 10-10-2004, 09:30 PM
  4. Chain adjustment tip and tricks
    By guised in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 04-14-2004, 01:30 PM
  5. Chain adjustment
    By edo in forum RST1000 Futura (all years)
    Last Post: 11-10-2003, 01:31 PM
