Results 1 to 15 of 18
Thread: Need help installation a RSV4 belly pan on a tuono
    apriliaforum Member Maser's Avatar
    Apr 2013
    TORONTO
    Can you post pictures of the mounting points? I got the front grill, the two lower sides and 2 brackets (I believe, I am missing one)
    Any help would be greatly appreciated.
    thank you
    apriliaforum expert Toohomo's Avatar
    Feb 2013
    Mandlebar HQ UK
    Have you looked at page 23:
    http://www.af1racing.com/store/ProdI.../rsv4rAPRC.pdf
    Not fitted one myself, but if you put brackets on you should see where they need to go.
    Apr 2013
    TORONTO
    Very helpful. I am new to the brand; I was not aware of this PDF. Thanks
    do you have the link for the Tuono V4R doc?
    Feb 2013
    Mandlebar HQ UK
    Not with my PC anymore go on af1 site and click on tuono v4 the parts pdf's are in there.
    apriliaforum Member srleadjb's Avatar
    Jul 2008
    LA LA Land
    There are three brackets. The PDF doesn't really show you where they go. I mounted the brackets on the belly pan and then held it up in position and that helped me identify where they connect. The side ones are fairly obvious. The rear one is a little strange as there is a hole in the bracket that doesnt get used. It faces back towards the rear wheel.
    SOLD ****** 2012 Tuono V4 - ARPC "FACTORY"- Leo Vince SBK Exhaust (removed muffler hanger) Race ECU, Aprilia OEM Carbon (Rear Hugger, Front Fender,) 15 tooth front sprocket, Brembo radial master cylinder, CRG mirror, Evo tail tidy, Spider grips, Rizoma rear-sets, Austin racing levers, Galfer custom brake lines, R&G radiator guards, alcantara seat, Rizoma brake fluid tank, Evotech gas cap, Rizoma oil bolt, Rizoma 42mm risers and Rizoma Handlebars, Rizoma brake lever guard.
    Ohlins forks, Ohlins shock, Forged wheels, Brembo monobloc calipers. EBC extreme pads, RSV4 Factory rear tail and belly pan fairing.
    apriliaforum Member silky22's Avatar
    Apr 2012
    stoke on trent
    That's on the exhaust PDF buddy
    Jul 2008
    LA LA Land
    Sorry I don't see the back bracket.
    Apr 2013
    TORONTO
    thank you all for the info...waiting on yellow stickers to replace the red ones the part came with from factory.
    Apr 2012
    stoke on trent
    Quote Originally Posted by srleadjb View Post
    Like I say mate it's on the exhaust PDF not the fairing PDF
    Jul 2008
    LA LA Land
    Quote Originally Posted by silky22 View Post
    Lol, yes you did, missed the "exhaust" part. Thanks.
    Apr 2012
    stoke on trent
    no probs buddy
    Jun 2009
    Tokyo Japan
    I have all three required brackets, fitting up the two side ones is pretty simple but the rear bracket has got me beaten.
    Just cannot see how or where it attaches to the bike. Any advice would be greatly appreciated
    Rodger
    2012 Tuono APRC, Benelli TNT 1130, Moto Guzzi 1200 Sport 4V
    Jul 2011
    Honiton
    Hi Rodger,
    The rear bracket bolts to the frame around where the suspension 'dog bone' mounts to the frame :-)
    Cheers,
    Mark
    Yellow Tuono V4
    Austin Racing full system, Power Commander 5, Ohlins shock, Pazzo levers, Rizoma bar end mirror, HID headlamps, LED rear light/indicators, Evo Tech tail tidy/Front spindle/swing arm protection, Austin Racing rear sets/race pattern, AFAM 520 conversion 16/45, OZ forged wheels, SRS crash protection, Pirelli Diablo Supercorsa tyres, RSV4 bellyPan, Ohlins RSV4 forks, Brembo M4 calipers, full Aprilia carbon fibre set, Ohlins steering damper, GB Racing engine covers, BMC air filter, Rizoma front sprocket cover, Gilles gear lever support, SCM quick action throttle, Brembo HPK discs with SBS pads, HEL brake lines, Luimoto seat, Techspec tank pads.
    Jun 2009
    Tokyo Japan
    Thanks Mark, I will have a good look there, appreciate the help
    R
    Rodger
    Oct 2012
    Horsham, UK
    I have the same problem, although I forgot to order the bracket! A photo would be good if anyone could be kind enough to take a quick snap?
  1. RSV4 belly pan fairing on Tuono v4
    By srleadjb in forum 2012-2019 Tuono V4 - All Variants
    Last Post: 09-20-2015, 07:53 AM
  2. Carbon Fiber Belly Pan on the Home Stretch
    By SoulDaddy in forum SL1000 Falco Forum (all years)
    Last Post: 04-26-2007, 06:27 PM
  3. Need Help installing Third brake light
    By motojoe in forum Aprilia and Piaggio 500cc
    Last Post: 11-13-2005, 02:00 PM
  4. Carbon Fiber Belly pan on ebay
    By orangeokie in forum SL1000 Falco Forum (all years)
    Last Post: 03-26-2005, 11:47 PM
  5. need help installing tail lights from scooter center
    By boyaani in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 11-14-2004, 08:58 AM
