Results 1 to 15 of 23
Thread: SR50 Factroy hard to start
    Mar 2013
    Sweden
    Hello! I have a 07 SR50 Factory piaggio engine, and when i want to start it iam forced to twist the throttle mybe 1/3 of WOT, and then its starts, idles to about 1k RPM, then dies. I do the procedure maybe 2-3 times and then its starts and idles to 2k RPM and its like normal. I have a polini airfilter and its fully derestricted. Does somebody know why it does this?
    Aprilia SR50 Factory 2007
    Derestricted
    Malossi drivebelt
    Polini airfilter
    Sep 2008
    I reject your reality, and substitute my own. CANADA
    Try a TPS re-set and see if that helps. Instructions can be found in the Sticky "Read Me First!"
    Tempus Fugit
    Mar 2013
    Sweden
    Tried that today but it didnt work, got any other ideas? Do you want some more info?
    Derestricted
    Malossi drivebelt
    Polini airfilter
    Sep 2008
    Do a soapy water test/check of the air line from the compressor to the Fuel Rail. If that shows that you have no leaks (even tiny leaks), then, check Fuel and Air Pressure and report your numbers. You can use a home made gauge like in the picture below.
    Tempus Fugit
    Mar 2013
    Sweden
    But the problem now is that it doesnt start at all, the fuelpump is priming and the startmotor runs, but she doesnt even cough. Can it be the fuelpump? I accidentally drove maybe 500 meters without the fuelcap completely on.
    Derestricted
    Malossi drivebelt
    Polini airfilter
    apriliaforum Junkie Ales's Avatar
    Sep 2011
    Sweden, Kalmar
    test petrol pump pressure, I usually use air gauges for it. Check the spark plugs. Use the tester and not the spark plug to the engine, you can enlarge the ht coil otherwise.
    Aprilia sr50 factory 08 ppj Europa Bought new 08.2010 - 0 km, now 4600 km (not mil)- Leovince H.m.zx-r,Filter Sponge Malossi ,Reed Ventil Malossi Vl 11 , pr. 2,80 ,water Separator, Ales Fuel Regulator (HGT system) speed 84km/h
    Derbi GPR50 Racing 2005 speed 96km/h
    Peugeot sf3 speed 67km/h
    apriliaforum expert NoNameForEver's Avatar
    Sep 2008
    Northern Europe
    Fuel cap doesn't enter into your issues... I would do as Grenadiers suggests..
    Sep 2011
    Sweden, Kalmar
    I had a bad check valve in the pump, then it was difficult starts. You can blow it, sometimes it helps.
    Sep 2008
    Northern Europe
    Quote Originally Posted by Ales View Post
    This makes no sense.. You could damage..... however..
    Mar 2013
    Sweden
    I have spark, and she starts sometimes, i did ride to a friend yesterday and back home, but this morning she didnt start again. So me and my father started checking everything, and when we pulled the fuelhoses from the injectors and put them back in she started, but only once :S And its seems i have water in the aircompressor, we are going to clean all the injectors tomorrow.
    Derestricted
    Malossi drivebelt
    Polini airfilter
    Sep 2008
    Install a Water Trap in the Air line... That will take care of the water on the air side.
    Tempus Fugit
    Mar 2013
    Sweden
    I dont know where to but one as the translation to swedish is crap :P But we cleaned the injectors and she runs now
    Derestricted
    Malossi drivebelt
    Polini airfilter
    Sep 2008
    Quote Originally Posted by SwedenFactory View Post
    Glad to hear, but it won't last long... "goo" (a mixture of water and T-2 oil) will once again build up and clog the injector. This "goo" does NOT burn and can and does cause all kinds of starting and running issues. The only way to prevent that is by installing a Water Trap.
    A Water Trap (see the Sticky: "Read Me First!" and run a search for more info) is placed in the Air Compressor line between the Air Compressor pump and the Fuel Rail.
    You will need to replace the Air line with new Fuel Injector hose of the same or close size and it will need to be long enough so that you can mount the Water Trap in a convenient location so that you can clean it out from time to time.
    Also, use Fuel Injector Hose Clamps and NOT the standard worm-screw style. That style tends to bite into the hose and cause leaks.
    Did you do a soapy water test to the air line on your bike?
    Tempus Fugit
    Mar 2013
    Sweden
    She did run pretty good until this morning, when she just died and didnt start again. Iam trying to find a watertrap here in sweden but its not easy. I havent tried the soapy water test to the airline, but there was some white-ish water/fuel(?) mixture in the airline, what is that?
    Derestricted
    Malossi drivebelt
    Polini airfilter
    Sep 2011
    Sweden, Kalmar
    Bauhouse water trap 249 sek. CraftOmat 1,4`
    what is that? Condens+oil.
  1. 08 rxv5.5 hard to start
    By mountainfever in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 03-04-2009, 03:16 PM
  2. hard to start? check your sparkplug
    By Richard fssnoc# in forum Aprilia and Piaggio 500cc
    Last Post: 10-27-2008, 08:27 PM
  3. Hard to start after sitting a day in the rain
    By johnalex in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-06-2008, 11:25 PM
  4. Hard to start cold,but....
    By JohnG. in forum 1000cc f.a.q
    Last Post: 08-07-2007, 10:22 PM
  5. Bike is hard to start if left more than 1 week, ideas?
    By snipe12 in forum RS125 Euro-archive
    Last Post: 07-25-2007, 06:43 AM
