Results 1 to 5 of 5
Thread: Aprillia RS 125 - Starting problem (Not sure where to post)
    Feb 2013
    Ireland
    Hey,
    I have a friend who recently bought an Aprillia RS 125.
    The problem is it's failing to start almost every time. I recorded a video of what's happening below. Basically the bike will start and everything is fine then if I switch it off and attempt to start it again you will what happens in the video. The bike is basically new with only 200KM on it.
    Also this is his first bike so we aren't experts with them.
    What we were doing was... key in the ignition, choke is on and hit the starter with a little bit of throttle.
    Also the petcock is on.
    Thanks for the help!
    Jul 2009
    AUS
    Sounds like ( if the battery is in good nick) it's chocka block full of fuel pull out the plug and try to turn it over.
    Aug 2013
    sydney australia
    Sounds like your starter motor is sticking check it out it may need replacement .
    Nov 2012
    Doncaster
    Good way i have found to start is all swichted on choke on no throttle, if it fires then turn choke off, then give it a bit of throttle, this is way i have always done it and worked good, each person have there own ways. I would also remove tanks and remove carb and give it a good clean out see if owt is blocked.
    Aug 2019
    Ireland
    Cant find were topmost this I bought an aprilia atlantic 125 will turn over with plug out but not with plug in any advice please
  1. Not sure where to post this? Im going to gp in austin in april help with seats??
    By speedtoyz1 in forum Professional Racing Discussion
    Last Post: 01-28-2013, 07:36 AM
  2. Rs 50 start problems
    By Zac753 in forum RS50 Technical
    Last Post: 02-18-2008, 04:52 PM
  3. aprillia rs 125 overheating please help ???
    By 111cooper in forum RS125 Euro-archive
    Last Post: 01-18-2007, 10:35 AM
  4. odd starting issue , not sure if its a problem or not
    By gsxr600james in forum RS125 Euro-archive
    Last Post: 09-03-2006, 03:56 PM
  5. Aprilia S 125 starting problems
    By Mack187 in forum Other Aprilia Models
    Last Post: 04-08-2005, 01:55 PM
