Page 157 of 160 FirstFirst ... 57107147155156157158159 ... LastLast
Results 2,341 to 2,355 of 2388
Thread: What did you do today on your aprilia RXV,SXV or MXV ?
  1. #2341
    Feb 2015
    Springfield, MO.
    Finally got my track bikes out of storage from the long winter. Fresh fluids and they are ready to rip.
  2. #2342
    Sep 2009
    Moscow, Russia
    Quote Originally Posted by SXVINWA View Post
    Your issue is most likely due to setting up the rear throttle body correctly. When using the asym linkage, the stop on the rear throttle body is supposed to be replaced with a longer unit with a jam nut. It gets adjusted to provide balanced vacuum at idle and holds the rear throttle body open the correct amount with a closed throttle. Without this being done correctly, the rear throttle body will be fully closed for the first 10% of throttle preventing any air from entering with the injected fuel. There is a good write up on this site somewhere.
    Thanks, that's exactly the issue. it's been a while since I was doing this procedure last time))))
  3. #2343
    apriliaforum expert daws's Avatar
    May 2009
    Sunshine Coast, Aus
    Quote Originally Posted by Yascher View Post
    was trying to switch from std TB linkage to VDB linkage, however the motor will run mostly on front cylinder, which makes sense, as rear one will remain basically closed at idle, however will plenty of gas pouring in, therefore spark get fouled immediately. map 15026 VDB assym
    with usual link and Alice SXV map engine runs fine
    with 15026 map and std link it also runs stable at idle and revs, but not smooth, which is expected. I know that it was running fine with VDB link before with 15026, however that was different set of TBs I think...
    will try tomorrow to figure it out....
    Correct procedure is to sync the TB with the stock linkage and note the TPS value with the idle set correctly.
    - Remove the rear throttle stop screw and fit a longer one with a locknut on the top,
    - Adjust the screw until it just touches the rear throttle arm,
    - Tighten the locknut,
    - Make sure that the TPS value has not changed,
    - Remove the stock link and fit the VDB link.
    - Try not to loose little parts in the airbox
    The popular misconception with fitting the link is that the rear throttle body is closed until 10%, it is at idle until 10%.
    #314 - Aprilia SMXV450
    Snap Fitness Caloundra - www.snapfitness.com.au/caloundra
    Übermoto Custom Graphics - www.uber-moto.com
    M2R helmets - www.made2race.com.au/
    Duke Racing Represent!
  4. #2344
    Sep 2009
    Moscow, Russia
    Quote Originally Posted by daws View Post
    that's all making sense as in my case I completely forgot the rear screw and therefore was running only on front cylinder at idle and filling the rear with fuel)))
    now everything is back to normal
    thanks everyone for the help!!!
  5. #2345
    apriliaforum expert Britt's Avatar
    Westmont, IL. USA
    I made it about 2 miles from my house when my 450 stalled, was hard to restart, and ran horribly as I turned around and went home. Looking around the motor at obvious items it took me a few minutes to find the culprit. Glad it didn't happen farther away.
    And now I wait for an Amazon delivery of two NGK VD05EMH caps.
    2009 Aprilia RXV 450
    2014 Yamaha Super Tenere ES
    Previous Aprilia's: 2002 Caponord : 2001 Falco
  6. #2346
    Sep 2009
    Moscow, Russia
    one 550 engine (first gen) got main shredded keys on crank replaced and should be back in the race bike this week,
    the second 550 engine (2008 weak cases) got heads lapped and reinstalled, though I have no clue where I've put one of the cam sprockets Z22 , it was attached with the tie to the chain before head installation, but was removed to ease the gasket and head installation and disappeared(((
    once new clutch basked and missing Z22 sprocket will arrive, then 2nd bike will be also put together as a spare or rain one.
  7. #2347
    apriliaforum Junkie SXV_Jack's Avatar
    Jul 2018
    germania magna
    Quote Originally Posted by Britt View Post
    drive with a sxv never further away than you can shove her at home :-)
  8. #2348
    Oct 2013
    Good old Germany
  9. #2349
    Jul 2018
    germania magna
    Whats happend LRP ?
    Cracked engine ?
  10. #2350
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    replaced cases bushings in my friends bike. Those are nasty ones - I just don't understand policy of Aprilia, which makes those bushings.
    I used
    AP9150324 (green) bushings, as cases are A and crank is B. Took bushings out, part number on them was the same, but coloured dot was not that obvious. It was something between green and blue. I just have to have hope. that this bushing is right, as on plastic bag, were written correct part number and colour...
    Btw, from my observation, 1 ton is enough to push out old bushings.
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
  11. #2351
    Feb 2009
    Tri-Cities, Washington
    Printed part numbers on the bearings are all the same because the number is for the unfinished shell. Colors get assigned after finishing and measuring.
  12. #2352
    apriliaforum Member SaltyBill's Avatar
    Nov 2018
    Italy
    New decals arrived.....Click image for larger version.
Name:	new decals.jpg
  13. #2353
    Sep 2009
    Moscow, Russia
    finished the engine, it started prom the first push of a button and purrs like a kitten)))
    need to finish all body parts installation tomorrow and back to the track!
  14. #2354
    apriliaforum prov-nov Mekis's Avatar
    Nov 2017
    Sweden
    Freshly build SXV550.
    Use the old plastic/graphics on track.
    Skickat från min FRD-L09 via Tapatalk
  15. #2355
    Nov 2017
    Sweden
    Cerakote on the tripples for the RXV
  1. What did you do to your RSV Mille today? (Version 1)
    By doracle1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-17-2019, 11:59 PM
  2. What did you do on your Shiver OR Dorsoduro today ??
    By mh_dorso750 in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 09-17-2019, 10:59 PM
  3. What did you do to your bike today?
    By Sign Guy in forum RST1000 Futura (all years)
    Last Post: 03-21-2012, 10:37 PM
  4. What did you do on your CBT?
    By King Vegeta IV in forum RS125 Euro-archive
    Last Post: 07-05-2006, 02:39 PM
  5. Would you do this on your Aprilia?
    By Exdukenut in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-10-2003, 07:04 PM
