Results 1 to 15 of 27
Thread: project finished soon
    Jan 2013
    hertfordshire
    ok so im new here ive basicly finished my project but to fit in wanted add pictures :P
    may need help seting up the carb ill see when i start it up and running properly
    anyway heres some pictures
    http://imageshack.us/photo/my-images...010500084.jpg/
    http://imageshack.us/photo/my-images...010500085.jpg/
    http://imageshack.us/photo/my-images...301091526.jpg/
    heres before i crashed
    http://imageshack.us/photo/my-images...eenimaget.jpg/
    now i have to just get mot when one more part comes
    jobs done small bit of wiring
    helicoil in gearbox draining thread
    fork serviced
    visual inspect through everything cleaning and you know what im getting to
    Dec 2012
    Leeds, England
    Coming on well. What performance upgrades have you got on?
    Jan 2013
    hertfordshire
    fuck all mate not enough money just crashed really badly any nearly done heyho maybe when moneys one of the better thing might go for a new racing crank and top end so right now just want to make legal
    Dec 2012
    Leeds, England
    Well if you have no upgrades you should be fine with the stock carb, however if you do put on, for example, a performance exhaust, make sure you upjet the carb to about 92. If you don't your bike will run lean causing friction all over (between piston and bore especially)
    Jan 2013
    hertfordshire
    yeah well i didnt have it for long on the road :L so i mean i was struggling to idle at 1500 revs before thats the case im getting to the exhaust is standard and the thing pulls about 60 on the speedoi mean like what a matter of 3-4weeks
    apriliaforum Junkie nicketynoo's Avatar
    Oct 2011
    scunthorpe
    Ash Dont forget to post what carb you've got on there! Will help you get a correct reply to what main jet you need in there.
    1999 rs50
    Top performance 70cc black cast iron bbk 2 rings
    stage6 dellorto 21mm phbg #95 main jet
    standard airbox
    conti racing clutch+uprated springs
    exhaust- Gianelli with carbon end can
    reeds- malossi VL 6
    bank account-empty
    Dec 2012
    Leeds, England
    Yes Nick is right, I was just assuming you had the standard one on there!
    apriliaforum expert RS_Roadrage's Avatar
    Aug 2012
    United Kingdom
    Easy way to tell what carbs also i may add, on the Sha carb you DO NOT have a rubber manifold(into reed side NOT airbox) with the new PHBN 16 carbs it HAS a rubber manifold and the size of the external where the carb fits onto is about 35mm and the SHA carb is around 60mm! Ther do also say on the carb body just above the bowl on a little flat piece! Assuming every things standard that is, and USUALLY , SHA carbs 1999-2003 PHBN 2004/3-2005/6
    RS 50 2004
    new stainless steel brake lines
    Giannelli race exhaust
    0.30 reeds
    stock air box
    polished Cylinder
    (BR9EIX)
    (82 main jet)
    tinted screen
    Jan 2013
    hertfordshire
    yeah not good with carbs at all ill get a picture and stuff tomorrow when im out there just got back from work so didnt have time today and also i dont have a rubber manifold rs_roadrage but just thing it needs maybe jets or somthing as it has a shity airfilter struggled to get the airbox but hey well see tomorrow
    Sep 2011
    warrington uk
    sounds like you have the dellorto sha 1412 carb, no need for pics just have a look on the side of the carb and it will tell you
    if your running it with a open/cone/k&n style filter then you NEED to upjet a fair bit to match the increase of air. if you run it with stock size jets and run a open filter its going to run really lean and cause damage to crank bearings, cylinder, piston internally
    we cannot tell you the exact size jet to fit because its always different even if someone had the same set up as you because it also depends on climate and see level ect ect. however we can give you a good starting point if you give us full details of your set up (top end (cylinder) / airbox or filter / current jet size / carb / exhaust and so on)
    stock jet size for the dellorto sha carb is 63
    you need to upjet around 10% give or take a couple of sizes when derestricting it or fitting a race exhaust
    if you have a decent carb you will also have mixture screw, needle clip settings ect
    Engine Always Screaming!
    Jan 2013
    hertfordshire
    so i would need a pack of jet size range from 80 to 110 or somthing
    Sep 2011
    warrington uk
    with a open/k&n/cone/pod style air filter then yes your on the right sort of lines there..
    with the airbox fitted, stock derestricted then merely 65 - 72 would be on the right sort of lines.
    that is the effect of a cone/pod/foam filter because they increase airflow so much so you need lots more fuel (no real performance gain with the RS50 though)
    Jan 2013
    hertfordshire
    i didnt want the k and n filter only thing i had could somone show me a pack of jets i would need for under 10 ?
    thanks i appreciate the help
    Sep 2011
    warrington uk
    it may be worth you hanging on and buying a second hand airbox off ebay, easier to re-jet to a airbox and more reliable with the UKs weather
    Jan 2013
    hertfordshire
    hmm money just really tight rejetting will be easier atm and dont know how long im keeping her for should i take the jet out tomorrow check whats in there first its had 12 bad owners
  1. 2001 Mille R Project Finished!
    By Jack_Attack in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-11-2009, 01:27 PM
  2. My Project Finished
    By Cheesy in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 04-28-2009, 06:17 PM
  3. Project finished and immediately crashed!!!!!
    By NUTTA in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-22-2008, 03:35 PM
  4. tuono 125 on ebay finishing soon
    By tuono 125 in forum RS50 Technical
    Last Post: 11-18-2006, 10:20 AM
  5. tuono 125 on ebay finishing soon
    By tuono 125 in forum RS125 Euro-archive
    Last Post: 11-18-2006, 10:17 AM
