Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: tank expansion
    apriliaforum prov-nov u00bgg2's Avatar
    Mar 2012
    upstate sc
    tank expansion
    Any body have a tank expand on them? I have heard of this happening on the 750 but not a 1200. Pulled the seat off to do some work and noticed the side panel bolt hole was broken out. Got to looking a little more and the gap between the panel and the tank (where they butt together) is much larger on the right side than the left leading me to believe the tank has swelled at some point.
    Just checking
    Oct 2012
    Jax, FL
    I have not noticed any tank swelling, but only had the bike for about 3 months. I have used non-ethanol gas almost for every tankful. I have read about Ducati tank problems and the use of ethanol was implicated in the swelling. Have you been using pump gas with ethanol?
    apriliaforum expert lanter's Avatar
    May 2009
    Guilford CT
    Where did you find non-ethanol in U.S. ? Wish I could find it here in Connecticut.
    2011 Dorsoduro 1200
    Mar 2012
    upstate sc
    From reading about the ethanol affects over on the 750 board but because I had not picked up on it on this board I was hoping it would not be an issue on the 1200. I am in an area where there is no none ethanol fuel so I have to live with it one way or the other, I have tried to stay away from the 15% as they do mark this on the pump. I have not ridden the bike in about a month and I put it up with about a half a tank of fuel. Typically after a hard ride, regardless of fuel level, when I put it up I can hear the tank hissing shortly after I put it up and I usually crack the gas cap as a precaution but I did not do it this time.
    Brain
    Oct 2012
    Jax, FL
    I'm in Jacksonville, FL and we have a local retailer that has a few stations around town that have the non-ethanol gas for boats, bikes and small engines. I did an internet search for non-ethanol gas stations in my city. You may try to find a marina or facility that services the marine community, they may have it but it is more expensive than the ethanol treated gas.
    There is a check valve in the charcoal canister system that vents the tank. I believe that it lets air in as the fuel in the tank is used so as not to allow a vacuum to be created. I believe that it may also relieve pressure that is created as the gas is heated from the engine running.
    Jan 2012
    Houston-Downtown
    Quote Originally Posted by jpduc View Post
    The check valve only relieves pressure..it doesnt let air into the tank....the charcoal canister is to filter out any gasoline fumes before it goes out into the atmosphere....
    The DD1200 is affected too...Mine and a buddy of mines have the issue....it usually results in the broken side fairing mount like in the first post. Kind of a PIA but Ive grown to live with it.
    Mar 2012
    upstate sc
    That is a good idea regarding the search for none ethanol fuel, had not thought of that. As for the venting, i have the canister removed and the vent hose piped down the side of frame so i dont believe vapor pressure in the tank was the probable cause. The side shield it self has a huge mounting hole which tells me that there were some long term tolerance issues in manufacturing from the start. It is feasible that the a tolerance stack up along with some minor tank swell caused the side panel hole to break out. I am going to post some photos when i have some time this week end.
    Oct 2012
    nowhere
    I have a 2011 (production 4/11) dorso 1200 with about 450 miles and have yet to see any signs of tank swelling. I confess to having been using an additive made by Sta-Bil since I gassed it up the day I rode it home. It is called Ethanol Treatment and performance improver. Comes in a 10 oz. bottle for about $5. The dilution ratio is 1 oz/2.5 gallons. I know the owners manual says no fuel additives, but I'm just not convinced Aprilia have any clue about the negative effects ethanol has on their machines. After all most of their sales are to customers whom don't have it forced down their tanks.
    May 2009
    Guilford CT
    I've been using Star Tron with no problems, after 7k miles.
    2011 Dorsoduro 1200
    Mar 2012
    upstate sc
    I guess I will be looking into an additive before this issue morphs it self. Here are a couple pictures for reference:
Size:  120.0 KBName:  2012-12-21_20-50-22_637.jpg
Size:  105.4 KBName:  2012-12-21_20-50-32_511.jpg
    Sep 2012
    washington
    Your pics reflect the exact same thing that happened on my 750-about a 1/2 inch increase in the length of the tank, broke both fairing mounts.-The tank and covers were replaced under warranty; although the immobilizer antenna was damaged as well, so I need to source one of those as it doesnt appear to be an item you can purchase by itself. If you could take a pic of that antenna that would be helpful-apparently you can get it for the 1200.
    May 2009
    Guilford CT
    I spoke to soon : my tank has swollen and snapped both plastic covers. Hopefully covered under warranty.
    2011 Dorsoduro 1200
    Oct 2012
    Melbourne, Australia
    Has anyones dealer told them if the new tanks have rectified the issue? Have they changed the tank at all to avoid this happening again?
    Hope mine does it before warranty is up, sounds like all of them will be prone to it sooner or later...
    apriliaforum expert Brinks_2's Avatar
    Oct 2007
    Perth Western Australia
    Mr D, we don't have the ethonal issues they do have in the states. We started to, but the gov backed out and capped the % added.
    2 eyes,2ears,2hands,2feet----TWO CYLINDERS
    Falco Mods-K&N Filter,EVO airbox & stacks,SL Carbons ,Penske 8983, carbon front mudguard, dash,top yoke, swingarm covers and sprocket cover, bellypan, billet bar ends and levers, tinted screen & headlight cover, braided brake/clutch lines, Evoluzione clutch slave, Mille oil tank, Sargeant seat, tail tidy, Gilles vario bars, Mille swinger, Rad-cooler guards, Gabro chip. SOLD
    DD 1200 - Gel seat, Arrows & map, shock tube, EVO Tail tidy, rad and oil guard, DNA Stage 2, Lightech bolt kit, Rizoma resouvoirs, Lux grips, Renthal bars, CRG levers, Carbon body work.
    2006 SR50 - Morini motor - My $100 dollar resto project, underway currently.
    Mar 2012
    upstate sc
    The first bike I saw this on was the HD XR1200, was thinking about buying one and found this out during my research. The issue they had was much more severe to the point that the sides would not even fit. My question is that once the tank expands "X" amount does it stabilize, or does it continue to expand and expand........... If it expands to a point and stabilizes the fix would be to modify the side panel tooling to take this into consideration, not the tank. If it continues to expand there is no way to fix it. I have to take the bike in for a recall, been putting it off, and I was going to have this addressed at that point.
  1. Expansion tank
    By zipppster in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-12-2008, 12:54 PM
  2. Where does the other pipe from the expansion tank go?
    By men8ifr in forum Pegaso 650 Cube and IE
    Last Post: 01-24-2008, 06:25 PM
  3. Expansion tank : my 5 month old son did help me!
    By Hansie in forum SL1000 Falco Forum (all years)
    Last Post: 04-09-2007, 11:46 AM
  4. Expansion tank.
    By motogp in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 11-09-2005, 11:12 AM
  5. expansion tank ??
    By beanarillo in forum RS250
    Last Post: 07-09-2004, 03:04 AM
