Results 1 to 15 of 28
Thread: EFI light flashes for a short period when riding then normal again
    apriliaforum Junkie bigaprilia's Avatar
    Essex
    Hi all,
    Another EFI thread, I know! I've recently a few issues with the futura, mainly another rectifier failing and blowing the 30 amp main fuse. I've replaced the rectifier and also have fixed soldered joints rather than the brown plug, and all seemed fine. About a week ago I started getting my EFI light flashing when riding the bike shortly after I'd left my house. The flashing lasted for a for 20 to 30 seconds before it went off again, however no fault code when I plugged in the diagnostic. I decided to ride the bike in diagnostic mode the next day for a short period and saw nothing reported other than the stand '1' indicated for the TPS. The strange thing is it only seems to hapen infrequently when started from cold, and doesn't seem to happen when the bike is started from warm.
    I've also not noticed any significant drop off in power or fuel consumption. Most threads appear to be related to a faulty coil, however I replaced all the coils with the aftermarket ones (set-up within the forum) approx 18 months back. Any ideas?
    Cheers,
    Alan
    2003 Futura with Quill EVOII end cans, H-pipe, Power Commander III 108bhp @wheel
    2001 RSVR with Aprilia shotgun II exhaust, Aprilia race chip, Power Commander III 128bhp @wheel
    1985 GSXR1100 with 1109 weisco oversized pistons and liners, dyna coils, k-tech race CDI, Stage III dynojet, Ohlins rear shock, GSXR1100 WT front forks, GSXR1100 M front and rear wheels, 134bhp @wheel
    http://barnfindmotorcycle.com
    Sweden, Linköping
    If you have TuneEcu check the historic faults.
    Otherwise I recommend to disconnect the coils one by one with a running engine and check that they are all working.
    I have written the procedure so many times so search for it with my sig.
    PA USA
    You might also want to check the standing battery voltage and volatge right after the cold start-up.. If your battery has a weak cell, the current draw from the starter will leave the voltage a bit low and this might kick up the warning. After the bike runs for a min or so and the battery gets a good charge from your new R/R, it stops flashing. The hot start ups are done before the battery's voltage drops back down from sitting
    apriliaforum prov-nov Industrialex's Avatar
    Feb 2009
    Lanarkshire, Scotland.
    I've had similar problems twice with the EFI light coming on. On both occasions, replacing the battery rectified it.
    Flame Red Futura
    Bike: Factory Standard
    Rider: Too many modifications to list
    apriliaforum Junkie DanRomani's Avatar
    May 2012
    Dunoon, Argyll & Bute
    Quote Originally Posted by Industrialex View Post
    totally unrelated but I love your profile picture alex
    Essex
    Thanks for all the comments.
    It's a bit strange but hasn't happend recently, however I've decided to buy the ECU cable to use TuneECU so I can review the fault code log. I'm also wondering if the issue could be related to a bad earth connection? I've seen the earth connection to the left hand frame rail above the rectifier, however I don't know where the earth strap is located on the engine, does anyone have a pic showing it?
    Cheers,
    Alan
    PA USA
    the engine grounds are on the sides towards the back. I can never remember which is for the battery and which is for the R/R. The right side one is easier to see. It hides behind the overflow tank for the radiator. You have to loosen it's mounts to see it. There are 2 wires on this bolt. The one on the left is a bit tougher to find. You have to look straight in between the frame and (iirc the upper edge of)the horizontal portion of the oil fill tube. That one will take a long extension with a 5mm(?) hex socket on a 1/4 drive wrench to reach.
    I had a hard time getting mine good and tight until I backed the screws out a bit and sprayed some contact cleaner with a lubricant on them. Seems the threads or lugs were binding a bit. That was a few years ago and have had no electrical issues since.
    Quote Originally Posted by bigaprilia View Post
    Cheers,
    Alan
    apriliaforum expert Powerful Pierre's Avatar
    Nottingham, UK
    I've had this happen on odd occasions over the years and I've put it down to being too impatient with the start procedure and not letting the bike do its cycle before hitting the start button....every time I've stopped the bike and gone thro' the start process again and its been fine.
    Jun 2006
    Columbus, GA
    I've had this happen on both my Fut's and both were shorts on rear thermistor right at the connector.
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Mar 2013
    london
    Quote Originally Posted by Powerful Pierre View Post
    Hi, Im new to Aprilia, just bought a Falco, had SV650s before. Having the flashing EFI issue for few moments after starting it. What is the correct procedure of starting an Aprilia?
    Regards
    Roland
    apriliaforum expert Robert Borchert's Avatar
    Feb 2013
    California
    Turn on the ignition, then wait for the self-test to complete. Once the lights go out, it's party time.
    Bob
    PA USA
    Quote Originally Posted by Robert Borchert View Post
    Bob
    10 years later, always wondered why that would matter. Never do it in the car. That said, I have always waited (cue chickens)
    Never even seen a Falco up close. Completely different EFI system though.
    Feb 2013
    California
    Interesting. Have a look at the Falco photos, very clean lines. From the viewpoint of riding the Futura, the instruments of the Falco are, well, shall we say, Spartan? Aprilia made some major revisions with the Marelli cluster.
    Starting should be quite similar, give the fuel system a moment to prime. Now my curiosity is piqued, have to look around a bit.
    Bob
    Mar 2013
    london
    Great! I always leave it in gear, so while I'm looking for neutral it has time to do the checks..
    BTW, got home tonight and found the ignition lock set was fallen out, lost the screws somehow. Luckily the keys kept it in place more-or-less. So tomorrow will have to get part number 8150349 and a normal M8x30 screw. Anybody knows if i can just use 2 screws or have to have the original weird looking bolt?
    picture of bolt: http://procycles.com.au/proddetail.p...150349&cat=842
    Many thanks
    PA USA
    Quote Originally Posted by Rolcsibacsi View Post
    Many thanks
    The weird looking bolt is a security bolt. The top portion snaps off when you get the bolt nice and tight making it near impossible for even you to remove it w/o removing the triple clamp and drilling. Unless, of course, like in your case, the screws just fall out. LOL.
    No reason why you could just use 2 normal bolts. Maybe some blue Loctite wouldn't hurt.
  1. efi light flashing and wont start
    By bullit in head in forum RST1000 Futura (all years)
    Last Post: 11-15-2005, 08:18 AM
  2. EFI light flashes....sometimes
    By McRide in forum RST1000 Futura (all years)
    Last Post: 07-26-2005, 05:04 PM
  3. EFI light flashing
    By dave in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-22-2005, 06:49 AM
  4. EFI light blinks for no reason?
    By timcob in forum ETV1000 CapoNord (2001-2007)
    Last Post: 08-20-2004, 06:34 AM
  5. EFI light flashing
    By BBQ Chef in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-04-2004, 10:02 AM
