Results 1 to 15 of 16
Thread: Found: Starter Relay Alternative
    apriliaforum expert shannon's Avatar
    Aug 2005
    Knoxville,TN
    For those of you wanting to do the starter relay replacement but want a direct plug and play I found this:
    http://www.ebay.com/itm/270495118448...WAX:IT&vxp=mtr
    I haven't used one personally but it is rated at 100 amps. It is more expensive but offers direct replacement with no effort.
    Current:
    02' Futura: Staintunes, H-pipe, Firebolter air kit, Corbin w/backrest, Mille forks, mille rotors, mille calipers, ss braided brake & clutch lines, MPL clutch slave cylinder, brembo radial master cylinders, license plate bracket chop, charcoal cannister removed, fork sliders, R&G frame sliders, throttlemeister, smoke windscreen, air box derestricted, mille air boot, stomp grip tank pads, anodized gas cap bolts, Ford starter relay, Ballistics lithium battery, helmet lock, carbon rear mud guard, Marsee corona tank bag, filler cap mod
    04' RSVR Track - In part out mode
    Carthage, NC
    Just go to the local Yamaha shop and get one...
    Ron
    MSgt USMC (Retired!)
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    Sep 2005
    Minnesota
    $43 for that one. I paid $16 for the Ford relay and it took me 30 minutes to put it in, and I was really taking my time. The Ford install is kind of "plug-n-play" as you're using the OEM plug. You just have to crimp some different connectors on it.
    2002 Aprilia RST Futura
    2006 Ducati 999s
    1986 Honda VFR700
    apriliaforum prov-nov Whitestar's Avatar
    Feb 2012
    Bridgend S. Wales.
    I also bought the Ford relay $26.22US delivered to the UK, it's sitting on a shelf now until I'm ready to install.
    2002 - Aprilia Futura - In Hospital
    1995 - Honda CBR600 - Sold!
    1989 - Suzuki GSX750 - Sold!
    2000 - Yamaha XT600 - Stolen!!!
    apriliaforum Member selong's Avatar
    Jun 2005
    Sacramento, CA
    I was having issues that turned out to be the battery. I went ahead and replaced the relay with this unit on amazon anyhow. It's a aftermarket for the Yamaha unit. For $10 it seemed worth a try. It plugs right in and works great. The same seller offers them in eBay too.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Nov 2012
    AL, USA
    I also ended up with Motorcraft (F-150, 500A rating I think) after putting in Echlin first then thinking twice. Still, about $40.00 total and I have a spare if need be, the minor mod was easy. That said, if plug and play is important...
    apriliaforum Member kurts's Avatar
    Aug 2012
    Roseville, CA
    Damn, I paid like $72 at the Yamaha dealer for mine! Guess they saw me coming. Oh well, it works much better than the old one and I don't have have to think about it any more.
    Kurt
    03 Futura
    May 2013
    Phx, AZ
    Quote Originally Posted by selong View Post
    My starter solenoid has become questionable lately so seeing this deal is perfect timing. Just ordered one now and Amazon says I should be getting it by the 29th. SWEET! Thanks for posting.
    Nov 2012
    AL, USA
    Not to be a wet blanket, but I'd be cautious about aftermarket stuff. I took off the Echlin (from NAPA) because I saw after the fact that it was China. There had been reports here of solenoids sticking closed, a bad thing. That's why I bit the bullet and went with Motorcraft. It wasn't worth saving literally a few bucks to me to risk substantially more expensive damage.
    May 2013
    Phx, AZ
    Oh, I thought it was Yamaha OEM. Lol Oh well, $10 for 100 amp unit, I'll give it a try. At least I know what a stuck on starter motor sounds like if that ever happens.
    Oct 2012
    SW Idaho, USA
    its sounds like a bunch of hopping around and sreetching, trying to remove the seat and get a battery lug disconnected!
    Nov 2012
    AL, USA
    ^^^^^ That's why I pulled the Echlin. Ironically it was actually a few $'s more than the Motorcraft. I hate hopping and screeching, at least with the Futura.
    Jun 2006
    Columbus, GA
    Got one of the shelf like 4-5 years ago. All is still good.
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    May 2013
    Phx, AZ
    Got the solenoid today. Perfect timing, my bike wouldn't start 2 different times today. Had to put it in gear and roll it to get the pistons to decompress. Working on install so we'll see how it performs out of the box.
    Mar 2012
    On the road between ID & OR
    Ford relay in mine.
    JD
    Futura
    Bunch of dirtbikes
  1. Alternative Starter Relay
    By gman-1970 in forum RST1000 Futura (all years)
    Last Post: 07-05-2011, 02:50 PM
  2. Alternative Starter Relay
    By Kingbud815 in forum RST1000 Futura (all years)
    Last Post: 10-28-2009, 03:08 PM
  3. Battery? Starter Relay? Alternator issue???
    By samrev3 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 06-05-2009, 05:36 PM
  4. Alternative Starter Relays / Solenoids?
    By mich in forum ETV1000 CapoNord (2001-2007)
    Last Post: 05-09-2009, 01:42 PM
  5. starter relay
    By apriliaman in forum RS125 Euro-archive
    Last Post: 06-02-2003, 01:46 PM
