Results 1 to 15 of 19
Thread: Updated valve cover gaskets and valve cover part #s to fix leaky valve covers
    Austin, TX
    new part #s
    898410 x qty 6 seal washer
    897443 x 2 valve cover gaskets
    857074 x 4 spark plug galley gaskets
    898407 x 2 updated valve covers for R model, the Fac is a different # 898467 since they are magneisum
    3bond sealer is recommended too
    apriliaforum newb kevie88's Avatar
    Jul 2013
    Calgary AB
    Are Factory and R valve covers interchangable? Don't really care about the Magnesium weight savings, wouldn't mind saving the 50$ difference for other needed stuff..
    Austin, TX
    Quote Originally Posted by kevie88 View Post
    yes they swap
    Sep 2014
    Scotland
    My 2010 R has developed this problem, I can source all updated gaskets and seals through aprilia uk website . I can't however find the update valve covers . Do I need to change the value covers to solve this issue? Or will replacing all gaskets and seals be enough?
    Austin, TX
    Quote Originally Posted by ryan-rsv4r View Post
    The new gaskets “should” fix the problem, but if you continue to have issues, then get the updated covers.
    They are not terribly expensive, and you’d know you have the 100% fix done
    http://www.af1racing.com/store/Scrip...dproduct=40427
    I’d probably go with new covers on my bike.
    Feb 2018
    Maitland NSW Australia
    Good info fellas, is there a base model Tuono RSV4 APRC as I recently purchased a 2012 TY model but nowhere is R or RR displayed, I know its not a Factory, reason Im asking is it has developed an oil leak from the spark plug moisture drain hole on the LHS rear cylinder, I see other threads mention it could be the valve cover seal leaking or cam bridge Orings, if Im going to buy the seals and there are updated valve covers then I need to know if they will suit my machine so I can fit them at the same time, any feedback would be appreciated.
    Austin, TX
    Quote Originally Posted by Zac2018 View Post
    you have an R base model that already has the updated covers (only 2010 RSV4 had them)....get some new gaskets and you should be set
    Feb 2018
    Thanks Ed, bike has 14000kms, probably a good idea to do a valve set at the same time, whats your thoughts on timing chain replacement? some of the forums here mention updated tensioners, how far do I go if required?? Not getting a lot of info out of the local dealer here, been waiting for a parts list and price just for the gaskets and seals for over a week now.
    Jan 2018
    Florida
    How can you tell updates covers ? My 2010 RSV4 is leaking/seeping . Is there a part number for a gasket kit or all individual parts?
    Jan 2018
    Florida
    How can you tell which covers you have? My 10 RSV4 has a leak/seep on both covers . Not sure if its the gaskets or covers . I havenít had them off as itís a new to me bike and supposed to have valves checked just before purchase.
    Also is there a gasket kit or just individual parts ?
    Thanks !
    Jan 2018
    Florida
    Valve covers
    How can you tell the difference between the updated and old covers ? My 2010 has developed a leak/seep from the covers .
    Jan 2018
    Florida
    How can you tell the difference between the two?
    Jan 2018
    Florida
    Sorry for the multiple post . iPhone was on the Fritzís this morning.
    Maybe a mod can clean this up for me ? I didnít see a delete option , just edit
    apriliaforum prov-nov kneepux's Avatar
    Mar 2018
    PRK
    when did the "updated covers" release? I have a slight oil weep from my 2016 factory as well.
    Jan 2018
    Florida
    Anybody ?
  1. Valve cover gaskets
    By Rsv0702 in forum 2010-2019 RSV4 - All Variants
    Last Post: 06-09-2012, 08:56 AM
  2. Looking for a bike to buy, and i have parts to sell
    By Law in forum RS125 Euro-archive
    Last Post: 12-11-2005, 12:48 PM
  3. RS250 and other bike parts for cheap sale
    By TZR250_3MA in forum RS250
    Last Post: 08-30-2004, 12:11 PM
  4. engine longevity and ease of parts replacement?
    By Darien Long in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-11-2004, 11:41 AM
  5. Head-gasket and o-ring
    By madcatDK in forum RS250
    Last Post: 04-03-2004, 11:38 AM
