Page 1 of 5 123 ... LastLast
Results 1 to 15 of 73
Thread: YES I DID! Siemens ECU read&write :)
    Roma, Caput Mundi
    finally, after 8 years, last night i've downloaded my first modded map in a Siemes ECU... i was almost crying
    I've got some (a lot) of panic when my tool hanged-up by the end of the process, but it did a correct job anyway (i've re-loaded the map to check)
    I've just street tested my '07 T-Factory (evo6 exhaust, BMC filter) and my RVC5L982 map modded with a new ignition timing: very nice gains in the 4000-8000rpm region.
    I'll do more in the w.e. , tunerpro XDF file is almost done (al least for the ignition, TPS and MAP table definitions)
    By next week i'll have some dyno printout
    I'll be soon in the business
    Stay tuned!
    Gab
    apriliaforum Member adelaideaprilia's Avatar
    Oct 2009
    Australia
    Hi Gabro I am very interested in the great progress you have made as I have a 1102 built by Amauri with EVO 6 and more gains in ingintion timing and ECU advances will be welcome.
    Keep me posted cheers,
    Mark.
    Roma, Caput Mundi
    Ciao Mark, i've never worked on a 1102cc motor, but usually rising the compression (and big-boring +5mm compression rise a lot) ignition timing needs to be retarded. Being the stock ignition timing on the "safe side" (i.e. not much advanced) maybe it's already spot-on to your motor
    Jun 2004
    Richmond, Tx
    CONGRATS!
    so you basically wrote over the factory map w/ your own map, then reloaded the fcatory map just to check it was done properly?
    '15 Ducati Monster 1200S
    Roma, Caput Mundi
    Quote Originally Posted by Racer X View Post
    .. no.. i read the factory map, modified it, downloaded my modified file in the ECU, read the ECU again and found my modified file that was correctly written on.
    Jul 2007
    Netherlands
    Great! Well done m8! What was the raeson it took so long? Are you that slow??
    Let me know if you are looking for more test subjects....
    Feb 2009
    Do you need to actually open up the ecu to 'overwrite' it?
    Roma, Caput Mundi
    No, used the bike diagnostic plug!
    Feb 2009
    EXCELLENT!
    You Sir are a genius.....!!!
    Roma, Caput Mundi
    some more testing today!
    crappy mobile pics and video
    37 miles E. of ATX, TX USA.
    This has much potential, I have noticed in Axone Menus there are options for "anti-lag", "water injection", "boost control" and such, can you activate and control these outputs in any way? I know, I am thrilled too that you finally just "got in the door" BUT you of course realize the power potential you are playing with and the way my sick mind works! Maybe a PM explaining a bit of the process if you do not wish to throw it up publicly. I would love to have unfettered access...love it! I agree about the ignition timing for a 1102cc motor, compression is way up and dynamic compression is way-way up so added spark time is not required.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Roma, Caput Mundi
    actually i'm still de-coding the binary file... i'm still at a very basic step. yet to find wich tables are for the rear/front cylinder. and I have no disassembly skills, so i've to work in a very empirical mode.
    You will figure it out, I have much faith in this!
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Jul 2007
    Netherlands
    Cant you just make one map really lean and one really rich? Header temps or checking sparkplugs should tell you which map is which...
    So about ignition timing, are there any gains to be made changing ignition timing on a stock engine with an Akra evo hex full system?
    Roma, Caput Mundi
    That exhactly how i,ll do it, put a fuel spyke says at 5000rpm ad see using a lambda probe wich cylinder react enrichng.
    More than power gains we're talking about "character" of the motor. APRILIA/ROTAX guys did a wonderfull job linearizating throttle response and power delivery, shaving the excess. I'm gonna destroy theyr job, reveiling those motor as they really are
  1. Did my ECU just get derestricted?
    By cheezweezl in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-23-2011, 07:11 PM
  2. Japanese Ducati - yes, they did it!
    By Short Shifter in forum General Motorcycle Talk
    Last Post: 08-12-2010, 10:47 PM
  3. Jackets (yes I did a search)
    By veloracermike in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-08-2008, 09:31 AM
  4. Tank bags (yes, I did a search!)
    By Smithmeister in forum SL1000 Falco Forum (all years)
    Last Post: 03-15-2008, 07:18 AM
  5. read a bike review...or write your own
    By Richard fssnoc# in forum Aprilia and Piaggio 500cc
    Last Post: 12-20-2005, 03:21 PM
