Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 85
Thread: FYI: RSV4 valve adj w/engine in the chassis
  1. #31
    apriliaforum expert vtrandall's Avatar
    NorCal
    Even though I don't have an V4, I think that this is one of the most interesting and educational threads here on the forum. I love reading about the little 'tricks' that end up making a seemingly uber-difficult job a little bit easier.
    If I ever pick up a Tuono V4, it truly seems like it would be more than worth it to truck it down to Amauri to work on....and I'm up in NorCal!
    -Randall
    .....Sed quis custodiet ipsos custodes?
    Three great forces rule the world: ignorance, fear and greed
  2. #32
    apriliaforum Member duc73's Avatar
    Jul 2011
    fl
    Quote Originally Posted by vtrandall View Post
    AGREE
  3. #33
    NorCal
    and.....props to Amauri for taking the time to type all this info out.
    god damn....how the hell were motorcycles kept running before the internet?
    -Randall
  4. #34
    apriliaforum expert zgriders's Avatar
    RPV
    We are very lucky to have Amauri, who just recently performed the valve adjustment (and the complete maintenance work, including the Ohlins fork oil/oil-seal change) on my Factory...I'm not sure how he does his magic, but the bike now seems so much smoother in power delivery with less vibration.
    Thanks again Amauri!
  5. #35
    Auckland, New Zealand
    Hey Amauri.
    Very very helpful thread. This was going to be a job for next month so Im gald I didnt tackle it without the Aprilia tools... and your advice
    How have you found the timing to be on the v4?
    Any suggestions on timing to get the best from the motor?
  6. #36
    May 2011
    england
    Question rsv4 valve clearances
    Some more FYI,
    Worked on two more bikes this week with valve adjustments due.
    -2010 R model with 20k miles, found 8 valves a little out of specs but one Intake was so tight that a .001" feeler gauge would not go in.
    -2010 Factory with 11k miles all but two EX valves were right on spec.
    Important:
    Bellow is a photo of the o-ring on the cam bearing towers that must be replaced to prevent an oil leak thru the spark plug holes (the parts book calls it a dust seal BTW).
    The list of gaskets needed for a proper valve adj:
    2-) 897442 v/c gasket
    6-) 898410 bolt gasket
    4-) 857074 plug hole to cover gasket
    4-) 857043 cam tower o-ring
    Hi Amauri
    got my covers off at the moment and have got 4 clearances that need adjustment (all tight)
    My question is having read the manual is it absolutely necessary to use the sprocket carrier tool? Havent got access to them and cant borrow any, so can i suspend the chain and sprocket to keep it tight on the drive sprocket below while i remove the cams. Once clearances are done id obviously use the timing pins to set all in the correct position
    many thanks in advance
    Best wishes
    Phil Carson
  7. #37
    Westminster, CA - USA
    Phil,
    Not trying to be arrogant but if you have enough experience with the insides of m/c engines, you should be able to answer that yourself.
    The first thing that you will have difficulty with is the hydraulic timing chain tensioner on each bank of cylinders.
    The Aprilia sprocket carrier tool holds the tension on the chain so you don't have to deal with re-tensioning.
    If you don't use that carrier tool, the tensioner will pop out to maximum extension as soon as the chain is loosened.
    I've not tried it this way, but it is possible to use a steel rod and pry/compress the tensioner while you place the chain wheels in position.
    Another option is to remove the tensioner and lock it in the fully compressed position, that should make re-assembly easier. Aprilia makes another special tool for installing the locked tensioner back in place way down inside the chain well, see photo.
  8. #38
    May 2011
    england
    Phil,
    Hi Amauri
    thanks for your comments - I suppose if the tensioner pops out then its a head off job - Ill make a gear carrying tool this weekend and be safe
    regards
    Phil
  9. #39
    Dec 2012
    Sweden
    Amauri, great tip!
    I've at the moment a RSV4 Factory 2009 at my shop, it's been running 1450km (as new)
    But I've decided that's a good idea to check valve clearance.
    1 in valve was at 0 space! totally 4 was out of specs, to the minus side.
    Thinking of setting the gap to the max specs...
    Is it usuall that the gap goes bigger or getting tighter as it runs? Whats your opinion on this?
    Thanks for doing a great job.
  10. #40
    Dec 2008
    Toronto, ON, Canada
    Note - Kokusan
    Just a note:
    If you have Kokusan flywheel, there is no way to insert crankshaft pin (even modified) without removing the flywheel first.
    You'll need Flywheel extractor 020913Y to adjust front valves on these engines
  11. #41
    May 2013
    SE Michigan aka pothole central
    I am attempting to fab a cam gear holder tool. Anyone care to take some measurements of theirs?
    Also, does the wire harness running between the rear head and frame need to come out in your experience?
    Thanks in advance.
    2013 Aprilia RSV4 Factory ABS SE
  12. #42
    May 2013
    Amauri, if i am successful i will post a drawing for those to make their own.
  13. #43
    May 2013
    Finished making a cam gear holding tool! Should work on my 13 ABS. Have yet to use it tho due to this issue:
    On the flywheel side, the threads on the block look messed up. The aprilia supplied crank timing pin only goes so far, not far enough to lock crank. Has anyone experienced this? Should i turn some threads off my crank timing pin to make the "pin portion" longer? The clutch side goes in just fine. I know i am in the right spot due to my angle and that i can see the crank timing pin receiver coming into view:
  14. #44
    apriliaforum Junkie ZAWA's Avatar
    Ocala
    Look forward to updates on your tools, will be starting mine this month.
  15. #45
    May 2013
    Update on the tools and also a new idea. My cam gear holder is complete, see picture below of it broken down. I can make more of these, not sure on price but PM me if ur interested. I plan on using a clamp or zip tie to hold the gear once i slide it over. It looks like it should work on my 13 ABS in frame.
    Also below... i have terrible luck with clutches. (Ripped up engine and transmission type of bad luck). Here is a tool i made to lock the primary without removing the clutch! I dont get why it doesnt go here in the first place. on the left is the aprilia tool intended location. I just used the little gear section of that locking tool.
    Now, after cleaning threads on block, and making tools, i can finally begin the actual job! Feedback is appreciated, im pretty much making this up as i go.
  1. RSV4 Factory torque specs not in the shop manual!
    By rsv4mark in forum 2010-2019 RSV4 - All Variants
    Last Post: 05-28-2016, 02:37 PM
  2. ducati motor in the T? project ( i know)
    By isxaari in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 04-20-2007, 10:08 PM
  3. :: Buying/Selling Stuff, Belongs In The BUYing/SELLing Section! (New Rules; Read FYI)
    By DRT-Tuning in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 11-30-2004, 02:54 PM
  4. How easy is it to check and adjust the Valve timing in the 04 RSV?
    Last Post: 10-04-2004, 03:16 PM
  5. FYI , There is road test in the current Cycle World
    By CharleeTho in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-14-2002, 10:27 AM
