Results 1 to 15 of 17
Thread: SC300 Died - No Start and Warning Light Illuminated
    Sep 2005
    London, ON
    All,
    SC300 died on the way back from running some errands this afternoon. Engine Oil Pressure / EI Control Warning light is illuminated, voltage is fine, but won't fire/turn over. Cursory check of plugs / connections etc. all seemed OK. Of course my 1yr warranty expired at the end of last month. Is there anyway to look at error codes without the Axone tool?
    Thanks,
    Phil Gicante
    Current
    2010 Aprilia SportyCity Cube 300 - Black
    Previous
    2009 Ducati Monster 696+ - White
    2006 Aprilia Orange SR50R Factory Ditech- Morini
    Clearwater, Fl
    Quote Originally Posted by pgicante View Post
    All,
    Thanks,
    You say it won't fire/turn over so I am confused a bit. Are you saying the the starter does not crank the bike at all (does not turn over) or the bike does crank on the starter (turns over) but is not getting any spark? Could be a blown fuse or a faulty brake switch or a defective starter.
    More details please.
    May 2010
    Is the oil level too low? ...it won't start if it is.
    '09 SC 250
    203cc Injector (Scarabeo 500)
    Akrapovic slip-on
    Michelin Power Pure
    May 2012
    Placentia, CA
    there was a fuel pump recall. did your replace yours yet?
    Sep 2005
    London, ON
    Thanks all for the quick replies. Sorry for the confusion - the starter doesn't crank the bike at all. Oil level is fine but I didn't receive any recall notice from my dealer regarding the fuel pump.
    Phil Gicante
    Current
    Previous
    Clearwater, Fl
    Lets start with the obvious that just about everyone here has overlooked from time to time, myself included. Is the engine kill switch flipped to the kill position?
    apriliaforum Junkie Aprilionare's Avatar
    Mar 2009
    Check for spark
    If you find yourself in a fair fight, your tactics suck.
    Sep 2005
    London, ON
    Rockynv,
    That was the first thing I checked . All good there...
    Aprilionare,
    Its not even cranking...
    Regards,
    Phil Gicante
    Current
    Previous
    Mar 2009
    the cap for the spark plug may be loose and not touching. It is a common problem with SC250, but easy fix.
    May 2012
    Placentia, CA
    i hope you get it resolved, but let us know what was wrong after you repair ir.... would love to have future reference for anyone seaching the forum with the same issues
    Sep 2005
    London, ON
    Quote Originally Posted by mreric View Post
    Thanks - was away all week for business so haven't had a chance to do any further investigation / troubleshooting. I may call the dealer (its about 100km away) and see if they can walk through any basic checks over the phone...
    Thanks,
    Phil Gicante
    Current
    Previous
    Sep 2005
    London, ON
    All,
    Dealer couldn't provide much help over the phone (indicated they would need to run the AXONE tool/diagnostic software). I remembered that I have the gold CAA membership which includes 200km distance for a tow - so the bike was put on a flat bed to the dealer last night.
    Running my VIN, the dealer did indicated that the fuel pump recall affected my bike, so that is the 1st thing they will do.
    More to come.
    Regards,
    Phil Gicante
    Current
    Previous
    Clearwater, Fl
    Hopefully it is just a simple safety switch or faulty fuse holding you back.
    May 2012
    San Francisco
    Thanks,
    I just had this problem with my 200. The wiring harness popped off the kill switch. You can take the plastic off to the left of the throttle (two philips screws) and push it back on. My dealer told me this is a super common problem.
    Good luck.
    Yes the EFI pump wont have any cranking effect at all With no crank Some type of Switch isnt doing its job or such and yer locked out of starting even w an efi bike or if your transponder is not talking to the bike? why I hate going to dealer type setup youre likely to never find out exactly
