Results 1 to 2 of 2
Thread: Brake light switch??
    Gcookie
    Guest
    Picked up a used Futura and the front brake lever was loose. Every time I went over a bump the brake light was going on. Looked at the switch. Is there suppose to be a rubber nipple on it? I fixed it by gluing a piece of rubber on the brake lever (to closed the gap). It seems to work fine now but hate to jury something up. Do I need a new brake light switch?
    buck000
    Guest
    From www.rst1000.org/wrenching.html :
    <blockquote><strong><em>Quote:</em></strong><hr><strong>Brake light comes on while covering the front brake, or stays on after release</strong>
    Very common problem, no OEM solution (a replacement switch will be just as twitchy. The solution is to build up the thickness of the tang that presses the switch. One very easy fix is to remove the lever, and wrap the tang in a bunch of electrical tape.[/quote]
  1. Brake light does not work
    By Georjetset in forum Aprilia and Piaggio 500cc
    Last Post: 03-26-2007, 03:32 PM
  2. Front Brake Light Switch Needed
    By Crackers in forum RS50 Technical
    Last Post: 01-17-2007, 08:07 PM
  3. rear brake and brake light
    By rs--Rich--50 in forum RS125 Euro-archive
    Last Post: 06-22-2005, 07:43 PM
  4. Front Brake Light Switch
    By James_3 in forum RS50 Technical
    Last Post: 01-16-2005, 07:21 PM
  5. Rear brake light
    By athai1 in forum Pegaso 650 Cube and IE
    Last Post: 12-29-2004, 07:35 AM
