Page 9 of 9 FirstFirst ... 789
Results 121 to 135 of 135
Thread: Oil Jet - Difficulty Finding Neutral
  1. #121
    Feb 2010
    Does this mod work on earlier models too? Mine is a 2000. Ever since I put a Barnett in, neutral is nearly impossible to get when your stopped. It improved slightly when I put the stock springs back in.
    I also don't feel the pulsing of the vacuum slipper like I did when I test rode a new one long ago. I seem to have some vacuum at the hose, and the diaphragm passed a suction test.
  2. #122
    apriliaforum expert theknurl's Avatar
    Mar 2007
    Palos Verdes Est. SoCal
    Wink oil jet
    1st welcome to the forum
    i don't know about the 1st gen clutch....
    early 2nd gen had #60 oil jets leading to too much oil on the plates; ie increasing drag
    make sure your plates and discs are smooth and flat
    a bent or warped plate, or discs with too much 'fuzz' on them will cause drag too
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    email/PayPal theknurl@yahoo.com
    Skype theknurl
    ph. 310-414-7247 PST, GMT -8
  3. #123
    Feb 2010
    I spent the last 3 months working with my new Barnett clutch. It dragged bad making shifting notchy and was impossible to get into neutral from a stop. It worked fine before with the oem clutch. I bought the bike used and the clutch wore out 1500 miles later.
    It was the friggin' oil jet! I changed it from a 75 to a 40 and it's cured. Thanks for the advice!
    I found the jet is a bitch to get out and only a needle can get behind it. I got it out with a wet/dry vac by reducing the end to the size of a vacuum tube. You could hear it get sucked in and then removed it from the filter. That tip will save someome an hour of frustration.
  4. #124
    apriliaforum Junkie Oberon's Avatar
    Nov 2004
    Switzerland
    Stamp on oil jet
    Hello
    I just want to add a photo, where you can see the stamp on the oil jet.
    This one is taken of the original oil jet from my 2004 Factory.
    It's a #60 which is clearly visible.
    Regards
    René
  5. #125
    apriliaforum expert EditTim's Avatar
    Jan 2004
    Columbus, OH
    Just ordered up two for both my bikes. I couldn't get them out w/o drilling them out with a reverse thread bit, thereby destroying them, even just to check to see what was in the T.
    #60 was in the Futura (04)
    #40 was in the T Factory (07.5)
    Now both have new #40's.
    Fast, easy job with the reverse bit.
    I've got the Fut apart right now (forks/exhaust), so won't be able to test anytime soon...
    Tim
    '07 Tuono Factory
    Leo Vince cans, 15/42, CF bits, Rizoma bars, bar ends, & mirrors, Austin Racing rear sets w/ GP shift, Factory Pro Evo shift star kit, radial clutch/brake, CRG levers, Evotech hangers, Powerbronze, billet sidestand, 6k HID, AF1 link plates, lightened flywheel, Öhlins TTX, BSTs, Bazzaz Fi-TC
    '04 Futura in Gloss Black
    Factory Pro shift kit, 15/43, GP shift, CRG's, Evo clutch slave, Bef semi-full (ceramic coated), Wilbers shock, 6k HID, Mille fork lowers DLC coated w/ Öhlins and 4-pad calipers, radial clutch/brake, lightened flywheel
  6. #126
    bay area
    I replaced mine with the #40. I wasnt sure what I had in there because im the second owner but changed it anyways. For some reason it still feels the same. I need to down shift to 1st make full stop then shift up to second then down to neutral. I hope AF1 sent me the right one. The part# looks right tho
  7. #127
    apriliaforum Member Wera_832's Avatar
    Oct 2013
    Burlington, NC
    After battling this same issue for years , I hope this will be the answer - I will find out this weekend !
  8. #128
    Oct 2013
    Burlington, NC
    SO, I just got done putting the #40 in and nopticed something very strange after pulling the bolt out - I had not oil jet at all in there ! I thought I was dreaming ,but ,nope - no jet to remove ! The #40 went right in -anyone else have this happen ?
  9. #129
    Nov 2011
    devil's elbow, oz
    Same issue for me Wera,I've got a 2008 tuono r.Started with an Evo clutch slave.Then did the Factory Pro shift Star,still no joy,notchy shifts,hard to find neutral.12 months later did the #40 jet mod,removed the bolt wtf!!,no jet.Thought i was the only one this has happened to.First ride was amazing,light clutch,easy neutral,positive shifts.Occasionally hard to get neutral from 1st but never a problem tapping down from 2nd
  10. #130
    apriliaforum Member Debonair's Avatar
    Apr 2014
    California
    I'm checking everything on my 09 RSVR and found I already had a #40 jet in it. I had ordered a new one just in case so now the used one is up for grabs.
  11. #131
    apriliaforum Junkie catch2otwo's Avatar
    Jan 2008
    san fran
    Turns out my bike already had the 40 jet in there (2008 non factory). I have my used jet as well as a new #40 available. $5 bucks shipped for either one.
    07.5 Tuono
  12. #132
    Jun 2006
    Columbus, GA
    I still maintain that I'd like to be a bit arduous to find N on one side, keeping it not so easy to find on the other side, like when going from 1st to 2nd. But that's just me.
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
  13. #133
    apriliaforum Junkie Cyber's Avatar
    3rd rock out
    has anyone tried a smaller jet them a #40? is so did it improve find neutral better then a #40
  14. #134
    Jul 2014
    Earth
    Quote Originally Posted by Cyber View Post
    yup.. thinking the same
  15. #135
    Dec 2015
    United Kingdom
    I thought that after 2006 they all came with the 40 jet already fitted?
