Page 96 of 97 FirstFirst ... 468694959697 LastLast
Results 1,426 to 1,440 of 1448
Thread: XV Tuner ECU Tool
  1. #1426
    apriliaforum expert levisik's Avatar
    Sep 2014
    Poland
    great, thanks !
    2006 Aprilia SXV 450
    Tuneboy Cable available in Poland
  2. #1427
    apriliaforum Junkie undergrounder's Avatar
    May 2015
    holland
    What is the difference between fuel offset and the injection quantity offset?
    I know the last one Resets after key cycle and that the fuel offset changes fuel on the whole map but I'm curious about what the quantity settings does
    My bike is my gym, my wheelchair and my church all in one. I'd like to ride my bike all day long but I've got this thing called a job that keeps getting in the way.
  3. #1428
    Feb 2009
    Tri-Cities, Washington
    The injection quantity self resetting value is a fixed value offset that can be manipulated for test runs. It is different than the fuel offset setting by how it is applied; the quantity trim value is fixed (if you set it to 100, 100 is added to each cell) while the fuel offset value is a percentage (if you set it to 2%, each cell is adjusted to 102% of its original value).
  4. #1429
    apriliaforum Junkie SXV_Jack's Avatar
    Jul 2018
    germania magna
    Is idle co and fuel offset overlapping in a certain area?
    some maps have idle co range 500-1500 or 500-3000
    ... but what range have fuel offset 0- torque limiters ?
  5. #1430
    Feb 2009
    Fuel offset is applied over the entire table. +3 IdleCO and +3 fuel offset at 1500 rpm would be +6%.
  6. #1431
    Jul 2018
    germania magna
    ...and @ 1499 3% ?
  7. #1432
    Feb 2009
    Fuel offset is applied from 0 to redline rpm.
    IdleCO is applied at whatever window the map defines as the IdleCO range. Typical ranges are 500-1500 (worthless, since idle is at 2000) and 500-3000, but with the editing package you can set your own range.
    The correction is additive whenever the engine rpm is in the overlap area.
  8. #1433
    Jul 2018
    germania magna
    How much fuel offset is possible to do with XV Tuner ?
  9. #1434
    Feb 2009
    V2 is supposed to be +/- 5.5% in 0.8% steps.
  10. #1435
    Jul 2018
    germania magna
    ok ... but why do i have 10,1% fuel offset ... is this made by axone ?
  11. #1436
    Feb 2009
    I do not know what the limitations are with Axone, but I do know that TuneEdit has no limits on adjustments and will allow the value to be increased beyond usable limits. Tech bulletin 007-2009 deals with the parameters and indicates that all settings above +5% are treated as +5% and all values below -5% are treated as -5%. That would mean that your correction setting of +10% is being used by the ecu as +5%, regardless of what you see.
  12. #1437
    Jul 2018
    germania magna
    you mean the sxv ecu will not make more than 5 % (+/-5% is the adjusting limit area from the ecu self ).
    okay thanks sxvinwa
    btw ... xv tuner shows the name of the map as 14028 ... but sure is this not that inside the map are the data from oem map 14028 is - right ?
    maybe its the alice map whats become the file name 14028 ???
  13. #1438
    Feb 2009
    Something is lost in translation and I don’t understand what you are asking / saying in the last part of that post.
  14. #1439
    Jul 2018
    germania magna
    i mean ... in my screenshot of xv tuner shows the current map ... but i can not be sure that this is the oem map
    maybe it is "edited".
  15. #1440
    Feb 2009
    I would like to be able to say that if it has an OEM map number, it is an OEM map. The editable version would show up as 41028. Unfortunately that would only be guaranteed if it were done with the XV Tuner package. The only way to know for sure would be to read the map from the ecu and have somebody compare them.
