Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 83
Thread: Picked up my new V7 Classic today!
  1. #31
    Gone, but not forgotten naimchase's Avatar
    Jun 2004
    Atlanta
    That's really cute.
    The last experience I had with a small block was my wife-at-the-time's V50 in 1980.
    It was really pretty and easy to ride, but sort of blew up on a long trip.
    Are the new V7s a lot different?
    The Pontificating Poodle
    03 Tuono, 01 Mille/now Tuono, Enjoy City
  2. #32
    apriliaforum expert abouc's Avatar
    May 2008
    Michigan - Grand Rapids area
    Quote Originally Posted by styx View Post
    ...it's a piece of piss to strip down and rebuild.
    Do you have to freeze the piss into pissicles first?
    2013 Triumph Bonneville SE
    2012 Triumph Tiger 800
    2002 Moto Guzzi V11 Le Mans
    1999 Honda XR70r
    Quote Originally Posted by fwagman View Post
    Use your bum hole as a guide ....... if it's tightening, you are getting out of your comfort zone so back off.
    I fart in the face of his 'Double Overhead Cam'!
  3. #33
    Quote Originally Posted by naimchase View Post
    That's really cute.
    What did it do? Drop a valve? this was the most common issue with the early smallblocks. One has to remember that the V35/50 was designed to be price competitive with Japanese machines of the time. Interestingly in your pic you show it's direct competition, the CX 500 Honda. When the V50 was launched in the UK it was actually CHEAPER than a CX!!!! Unfortunately corners were cut. one of those corners was the valves. They use very thin stems and while they are *adequate* they were only barely so.
    The exhaust valves in any engine are the hottest part there is. Even if an engine is in good tune the necks of the exhaust valves will be glowing dull red in service. The gasses exiting past the valve are only slightly cooler than an oxy torch and the only way valves can dump heat is through the seat when they are closed and through the stem/guide interface. Once the mixture gets too lean or the ignition timing gets out and it is very esy to over-stress the neck of a valve.
    Most engines have valves that are built very conservatively. alas with the early smallblocks this isn't the case. Poor tuning or simply letting the heads get oily and dirty, (Dirty fins can't dump heat nearly as effctively as clean ones and smallblocks were a bit under-finned anyway.) will result in valves shedding their heads. This is the reason why it is VITAL to check your valve clearances religiously at 5,000km intervals on an early smallblock. As soon as you notice the gaps start to close you whip the heads off, (Takes about 15 minutes each side! As Styx sez they are didiculously easy to do the top end on.) and replace the valves. They aren't very expensive whereas a barrel and piston kit is!!!!
    The later, Baby Breva and later, smallblocks seem not to have this problem and I can only assume it is down to superior materials being used in the valves as nothing else in the motor has changed since Jesus was in nappies! As I've said before the ONLY modification I dvise, and I advise it strongly, for the modern 750 Smallblocks is fitting a Guzzitech sump extension. They do run very hot and will drink their oil VERY quickly if run hard in hot weather. they also run hot generally so use a top of the range full ester synthetic oil in 'em unless you want problems down the track.
    Pete
    Professional Goat Burster.
  4. #34
    May 2007
    Hesperia, CA
    Gotta say DJ, never thought I'd see you on one of those, hope you enjoy it as much as I enjoyed the 45,000 miles I put on my Le Mans II.
    One bonus, that hopefully you won't get too involved in, it's a piece of piss to strip down and rebuild.
    Welllllll, that is some verbiage.
    I helped a past girlfriend replace a rear oil seal on her V50 that was weeping onto the rear brake disc. we just lifted the frame off the drivetrain and got to the seal. not very difficult at all. It was one of the first home repairs she ever did and it was not a problem for her. at all.
    DM
    #1 Forum Magic Missile Caster
    1972 Laverda SF 750
    2007 Moto Guzzi Griso 1100
  5. #35
    Jun 2004
    Atlanta
    Pete
    Indeed it did.
    I checked valve clearance on both bikes 300 miles into the trip with both in tolerance.
    1000 miles later the V50 puffed a gout of smoke from the left cylinder which had me pushing it for miles to the next service station. A U-Haul ride to the nearest dealer had it getting a new top end from a fellow TZ pilot while that wife and I rode two-up up Mount Washington.
    I always liked that V50.
    But it's a good thing there were no bridges to throw it over on that long push.
  6. #36
    Mar 2009
    Roseberry Creek, Oztralia
    Wow, three pages on a small block - must be a record.
    Gil
  7. #37
    Feb 2005
    West Yorkshire
    Pete, thanks for the insight into the valves.So....what's the best way to keep the fins clean?
    Aprilia V4R APRC
    BMWR1200RT
    HONDA SP2 VTR RC51 TRACK BIKE
    BMW R1200R
    MOTO GUZZI V7 CLASSIC
    YAMAHA R1 2007 STREETFIGHTER
    APRILIA RSVR
    APRILIA TUONO 2003
    KAWASAKI ZXR750 TRACK BIKE
    KAWASAKI ZX600R
    APRILIA RS250
    YAMAHA 600 TENERE DAKAR
    DUCATI DARMAH 900SD
    SUZUKI GT185
    KAWASAKI GPZ600R
    YAMAHA TY175
    YAMAHA RD350YPVS
    KAWASAKI GPZ305 AWFUL BIKE
    KAWASAKI Z550
    SUZUKI DR125
    Watch this: http://www.dailymotion.com/Omen4/vid...t-2006_extreme
  8. #38
    Quote Originally Posted by The Dr.Jon View Post
    Don't let the top end leak. Rocker cover gaskets are really cheap. Don't try and re-use them.
    Pete
  9. #39
    May 2007
    Hesperia, CA
    And they are REAL easy to replace.
    1972 Laverda SF 750
  10. #40
    Feb 2005
    West Yorkshire
    http://www.apriliaforum.com/forums/s...48&postcount=8
    Kicked the arse of a Gen 1 Tuono, a Gen 2 Tuono Factory, BMW GS 1200 and a Triumph Speed thingy, the 1050cc version.
    Loving the bike.
    Aprilia V4R APRC
    BMWR1200RT
    BMW R1200R
    APRILIA RSVR
    APRILIA TUONO 2003
    KAWASAKI ZX600R
    APRILIA RS250
    DUCATI DARMAH 900SD
    SUZUKI GT185
    KAWASAKI GPZ600R
    YAMAHA TY175
    YAMAHA RD350YPVS
    KAWASAKI Z550
    SUZUKI DR125
  11. #41
    Feb 2005
    West Yorkshire
    Took the girlfriend out for her first ride on the Guzzi yesterday, loved it! Much safer than the R1 for two up and a very pleasant afternoon out.
    Aprilia V4R APRC
    BMWR1200RT
    BMW R1200R
    APRILIA RSVR
    APRILIA TUONO 2003
    KAWASAKI ZX600R
    APRILIA RS250
    DUCATI DARMAH 900SD
    SUZUKI GT185
    KAWASAKI GPZ600R
    YAMAHA TY175
    YAMAHA RD350YPVS
    KAWASAKI Z550
    SUZUKI DR125
  12. #42
    May 2007
    Hesperia, CA
    I was in San Francisco this past weekend and I saw someone riding a V7 Classic up Franklin. Sweet! I thought of you guys.
    DM
    1972 Laverda SF 750
  13. #43
    Jun 2009
    Torpoint, Cornwall, UK
    Stunning bike
  14. #44
    Feb 2005
    West Yorkshire
    Thumbs up
    Quote Originally Posted by KernowJim View Post
    Stunning bike
    Aprilia V4R APRC
    BMWR1200RT
    BMW R1200R
    APRILIA RSVR
    APRILIA TUONO 2003
    KAWASAKI ZX600R
    APRILIA RS250
    DUCATI DARMAH 900SD
    SUZUKI GT185
    KAWASAKI GPZ600R
    YAMAHA TY175
    YAMAHA RD350YPVS
    KAWASAKI Z550
    SUZUKI DR125
  15. #45
    Feb 2005
    West Yorkshire
    First service done today at Corsa Italiano with a 1000kms under her belt and all is well. Fitted a rear rack for pillion convenience and to accommodate a tent for a trip to Olivers Mount in Scarborough that i've promised myself later this year. The rear suspension has been firmed up and instantly feels more to my liking. She's a great bike round London with a fantastic turning circle and the Mistral exhausts, with baffles still in, sound just right. Fantastico!
    Aprilia V4R APRC
    BMWR1200RT
    BMW R1200R
    APRILIA RSVR
    APRILIA TUONO 2003
    KAWASAKI ZX600R
    APRILIA RS250
    DUCATI DARMAH 900SD
    SUZUKI GT185
    KAWASAKI GPZ600R
    YAMAHA TY175
    YAMAHA RD350YPVS
    KAWASAKI Z550
    SUZUKI DR125
