Results 1 to 13 of 13
Thread: Need a quiet exhaust
    Mar 2011
    UK
    I have a 2001 sr50 ditech with a 70 kit.
    It is important for me for the scooter to be quiet. It currently has a performance exhaust that is loud and I would like to replace it.
    I would appreciate recommendations for the quietest exhaust option. Is it the standard exhaust?
    Or perhaps something like this? http://www.adrenalin-pedstop.co.uk/p...01__03-51.aspx
    All advice appreciated.
    Dave
    apriliaforum expert fapfap's Avatar
    Oct 2010
    Houston, Texas
    The LeoVince ZX-R isn't louder than stock, if any, at all. It just changes the tone to a deeper one.
    2009 SR50 Factory - 49cc Piaggio Engine
    Engine:
    ECU derestricted (unknown map)
    AGIP City 2t oil
    +3º key
    NGK 7411 spark plug (CPR8E) .035"
    Husky W/T
    BGM PRO Evo 23mm intake manifold
    Marchald Filter
    Malossi VL13 reed
    HGT fuel reg. (~130psi)
    Transmission:
    Malossi Multivar 2000
    6.25 gr Dr. Pulley sliders
    LV red clutch springs
    Malossi green contrast spring
    Exhaust:
    LeoVince ZX-R
    Status:
    220lb rider
    58mph not tucked
    65mph tucked
    both on flats
    F/S : I have a new set of 5.0 gram sliders;
    apriliaforum expert SilverSurfer's Avatar
    Nov 2005
    Albuquerque, NM, USA
    that Tecnigas you have linked to there should do what you want. It won't have the same performance that a performance exhaust will (obviously), but is still better than stock, and should definitely be quieter. I haven't read of anyone with that exhaust on a 70cc setup, so if you do go that direction, please let us know how it goes!
    Which 70cc do you have, by the way?
    apriliaforum Junkie Sp33d-Fr34k's Avatar
    Apr 2007
    Norway
    I reccomend the ZX-R Great exhaust.
    Aprilia SR50R - Spiderman Edition
    With:
    Complete Stage6 R/T 95cc Piaggio Engine. <---- For sale in Norway
    Mar 2010
    Denmark
    Im using a Silent Pro exhaust on my 70cc Morini Ditech.
    Its running fine, but a bit noisy compared to other 70cc non injection machines with the same exhaust
    Mar 2011
    UK
    Thanks for the suggestions to date.
    The current exhaust seems to be a Leo Vince ZX. I've attached a picture. Would the ZX-R be considerably quieter than what I have now?
    I'm not sure which 70 kit it is - it was on the scooter when I bought it. Is there an easy way to tell?
    I've seen mention of replacing the packing in the exhaust - would this be an option worth considering?
    Many thanks
    Dave
    Sep 2008
    “I reject your reality, and substitute my own.” CANADA
    Quote Originally Posted by Hairsy View Post
    Many thanks
    Dave
    From what the members here that have it have reported, yes it will be quieter then the ZX.
    As for the engine, look at the Cylinder. Malossi is larger then the stock cylinder and has the word MALOSSI stamped into it. If it’s a Polini, it looks like the stock cylinder (size wise) and I believe it also had its name stamped on it.
    The packing needs to be replaced approx. every 50 hours of ridding time (according to the makers of the pipes). You can change it, but you won’t get a BIG change in the sound. The ZX-R will be your best bet to reduce the noise levels to close to stock…
    Tempus Fugit
    Mar 2011
    UK
    I made enquiries with a dealer I've used successfully in the past but they don't stock the ZX-R for this model. They have suggested the Yasuni R or Yasuni Z exhaust and tell me either will be a little quieter than the ZX-R.
    Does anyone have experience of these - is it right that they would be quieter?
    I do know that they're more expensive!
    Dave
    apriliaforum expert RushNatU's Avatar
    Jun 2010
    Indianapolis, Indiana
    02 Morini Ditech LC GP-1 50cc
    Engine Mods
    Malossi: ECU, VL12 reed cage
    Tecnigas RSII chrome
    Port & polish
    HGT Gen II Regulator black
    20mm throttle body
    Watts F602 watertrap
    NGK ZMR7AP indexed/gapped
    26mm Stage 6 R/T intake
    BGM pod filter
    Transmission/Suspension Mods
    Malossi: MHR delta clutch, MHR 1.8 springs, X special belt, red torque spring
    4.75g DP sliders
    Aprilia racing shock
    Visual Mods
    STR8 40mm riser
    KOSO dash
    Rear footpegs
    Heidenau 140/60 K62 tires
    Euro front turn signals
    STR8 led taillights
    Wish List
    Polini BBK
    Malossi Full Circle Crank
    Tail tidy
    Wave rotors
    FOR SALE:
    Malossi multivar 2000
    Red GenII regulator
    59mph (flat tucked), 65mph (downhill) GPS verified
    13000 miles
    Mar 2011
    UK
    Thank you - that helps a lot. Feel a little embarassed not to have found that with my own search.
    Dave
    Jun 2010
    No problem, google is your friend.
    Engine Mods
    Port & polish
    20mm throttle body
    BGM pod filter
    4.75g DP sliders
    Visual Mods
    STR8 40mm riser
    KOSO dash
    Rear footpegs
    STR8 led taillights
    Wish List
    Polini BBK
    Tail tidy
    Wave rotors
    FOR SALE:
    Red GenII regulator
    13000 miles
    apriliaforum Member joseverdin10's Avatar
    Feb 2010
    California
    ZX-R is definitely quieter than regular zx. I recommend it.
    Aprilia SR50 2009 R Factory Paggio engine
    Leo Vince ZX-R exhaust
    De-restricted
    6.5 Gr roller weights
    Average mph: 48 (wind, not tucked, flat road)
