View Poll Results: Have you experienced charging problems?
Voters
73. You may not vote on this poll
  • No - I have had no charging problems
    12 16.44%
  • Yes - My Regulator/Rectifier broke down
    18 24.66%
  • Yes - My connectors burnt
    22 30.14%
  • Yes - My wiring was bad
    5 6.85%
  • Yes - My stator failed
    1 1.37%
  • Yes - Have replaced my Regulator/Rectifier at leas twice
    6 8.22%
  • Yes - Several times with different failed components
    7 9.59%
  • Yes - Due to other problems
    2 2.74%
Results 1 to 15 of 28
Thread: Poll for Charging Problems
    Sweden, Linköping
    Haven´t seen much polls around so I start one here.
    This one is about charging problems
    Carthage, NC
    I voted "No, No problems", but I did the wiring, soldered connectors, and later added a new rectifier simply as a precaution, not because I actually needed it at the time.
    Ron
    MSgt USMC (Retired!)
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    apriliaforum expert MartDude's Avatar
    Nov 2008
    Shropshire, UK
    As Meanstrk, above
    It flies sideways through time
    It's an electric line
    To your zodiac sign
    I've got a Yellow Machine
    2002 Futura, Silver - now sold
    1996 Moto Guzzi California 1100i
    2005 Moto Guzzi California EV
    Calis are Cool!
    WV... Northern Panhandle
    I replaced the reg/rec as stock was charging at 11.7-ish.
    Melted a brown connector long after that..... I melted a Posi-Lock as well.
    02 aprilia Futura
    15 aprilia Caponord 1200
    apriliaforum expert Dr_Jakob's Avatar
    Apr 2007
    Mengeš, Slovenia
    I checked No.#2, but I also wanted No.#6
    I am not here. What is "here"? Isn't "here" just "there" without a "t" ?
    Brum
    3 recs on two bikes in 7 years
    apriliaforum Junkie Teulu's Avatar
    May 2008
    Cymru (Wales)
    As some of the others I cut out the brown connector and fitted Bikpaintr's rectifier as a precaution so don't know if I would have had problems.
    "Too old to rock'n'roll too young to die"
    apriliaforum prov-nov Picky's Avatar
    Nov 2008
    White Plains, NY
    I checked #2. (though my connectors were also burnt #3)
    The stock rec fried my dash & killed a brand new YTZ14S battery.
    After new JohnB's rec, & posi-lock connectors, bike starts right up, (once even after sitting for 4 weeks).
    Looks like, need to change posi locks after reading rdb's post.
    Still looking for a dash, though.
    apriliaforum expert Shippers's Avatar
    Dec 2006
    Fife Scotland
    Now the problem for me with this poll is it only allows me to hit one choice. With my two bikes I could hit about 4 I reckon
    2,3,4,+6
    Mark
    Honi soit qui mal y pense
    apriliaforum expert flying fox's Avatar
    Apr 2008
    Stockton-on-Tees,UK
    2,3,4 + 6
    04 Silver,FPR Mod,Derestrict Airbox,Mille Boot,Reg/Rec Mod.,05 Map,Heated Grips,Smoked Screen,Beftura Forks,Scottoiler,Stone Chips,Scratches...
    The Art of Bodge-It Never Fails.
    apriliaforum expert FUN DOG's Avatar
    Sep 2005
    Georgia, U.S.A.
    Battery would go dead because it wasn't getting enough charge while riding. Cut out the white and brown connectors, hardwired and ran some extra wires up to the negative battery post and haven't had a problem since (over 3 years). Stator and rectifier still stock.
    So I voted "bad wiring."
    apriliaforum expert Katch's Avatar
    circa...Washington D.C.
    This poll isn't helping. So far, five people said they never had a charging issue; however, some (all?) of the five did the mod preemptively. I'd like to know if the charging system was flawless on anyone's Futura while bone stock.
    "7. I will never stop thanking Ducati for their refusal to sign me in 2009" --- Max Biaggi
    '02 Falco
    Renegade high-mount, OZ wheels, JCG custom paint, PC III, 48 psi RSV chip, painted Mille swinger, Works Performance shock, Evo airbox/K&N, oversize intake, Jet Hot coated pipes, Heli-bars, MPL clutch slave, braided lines, alarm, Pazzo's, Puig screen, carbon stuff...many more...
    '03 Futura
    Ash Black, BEF Exhaust, H-Pipe, Heli-bars, heated grips, tinted screen, alarm, 3 power outlets (2 Powerlet & Gerbing), charging LED, John's regulator, carbon hugger, Vista Cruise, MPL clutch slave, Falco forks, 320mm rotors, Pazzo's, Stebel TM80 horn, Tutoro chain oiler, K&N filter
    apriliaforum expert Twinz's Avatar
    Aug 2008
    Montpelier, VT
    I checked #3, burnt connectors but that only happened after I replaced the OEM rectifier w/John's and had soldered the connectors. It was the white connector that burned, only one contact on the rectifier side. I resoldered that connector and have had no problems since.
    Twinz - John
    Montpelier, VT
    New old man wheels: 2002 Porsche 911 Carrera Cabriolet
    Gone but not forgotten:
    '04 RST 1000 Futura
    '94 R1100RS
    '84 R100CS
    '76 R75/6 w/S fairing
    '80 Guzzi V50 II
    '73 Guzzi V7 Sport
    apriliaforum expert 01Futuraman's Avatar
    May 2008
    NC
    +1 what he said
    my starter relay died so I just replaced the rectifier when I replaced the realy per the suggestion of many on the forum, haven't had any issues since
    Mods:rectifier replacement, soldered wires, derestricted airbox, QDC replacement with metal one, capped holes on fuel plate, basically just the standard stuff we have to do to be safe and keep them running well
    Road: 01 Aprilia Futura
    Track: 05 Triumph Daytona 650
    Dirt: 06 Honda CRF230F
    apriliaforum Junkie Brian_M's Avatar
    Jan 2008
    Oregon
    Yes, on my first Futura my rectifier broke down in the middle of a trip home. I broke down about 50 miles from home in the middle of nowhere with no cell phone service for about 20 miles in either direction. Thankfully I hitched a ride from a guy who took me to where I could get a signal on my phone. I called a friend and he came with a trailer and picked me up. My stock regulator took a shit after about 35k miles. I replaced it with Rick's reg/rec. Didn't have any problems after that. My brown connector had been removed & the wires soldered, not sure at what mileage but it wasn't there when I bought the bike with 27k on it.
    2002 Futura - Staintune's, Pazzo levers, Eagle Screens smoked windscreen, MPL Tuning Clutch slave cylinder, Mille Air boot, Derestricted, Graphite grey metallic paint
    July 2008 3000 mile trip
