Results 1 to 15 of 22
Thread: Half Shell removal and install
    apriliaforum expert soyrico's Avatar
    Sep 2007
    Hollister California
    I'm in the process of removing the crank case half shells. I don't have the spacial tool to remove the bearings. Can I use anything else to improvise? The manual says to apply heat to case. Anything very importent I should concider before removing and installing?
    A man who dares to waste one hour of time has not discovered the value of life. - Charles Darwin
    http://www.panoramio.com/user/249951
    http://www.panoramio.com/photo/6895299
    2016 RSV4 RF
    2007
    RXV 4.5
    Sep 2009
    Moscow, Russia
    my guess is you will need a baking owen for cooking cases at 200C before pressing bearings out, also thermogloves to handle all that and they should slide out with not much force...
    Westminster, CA - USA
    I don't use heat, just the two special tools.
    Also very important to mark the location on the case where the two halves split so you can put it back in the same orientation.
    Sep 2009
    Moscow, Russia
    but it does help a lot, at least in my car background some bearings are heat pressed and I had even to use torch to set them free, they will either fall out or slide of something with no external force
    Sep 2007
    Thanks guys. I'll have the half shells installed by my local shop since I don't have the tool.
    2016 RSV4 RF
    2007
    RXV 4.5
    Quote Originally Posted by soyrico View Post
    Please make sure they understand that the half shells must be aligned exactly as they came out when pressed back in.
    Sep 2007
    Can someone put the first 'Warning' note in layman's terms for me?
    2016 RSV4 RF
    2007
    RXV 4.5
    Sep 2007
    Well I got the half shells done but this doesn't look right. The yellow arrow points to the original manufacture marks where the shells were aligned. The red is were there at now. I have to ask why is this important. The shells have oil ports around the bearing and if I blow air in the oil passage it blows freely.
    I will take it back tomorrow to have them done correct.
    2016 RSV4 RF
    2007
    RXV 4.5
    Please excuse the rough sketch, I hope you can see what I'm trying to explain.
    The up/down load of the pistons/rods must be in the middle of the bearing shell, not where the two halves split.
    Probably not the end of the world if they are not perfectly aligned, since the load on the main bearings is absorbed by the rotating crank and divided by two rods/pistons.
    But when I see worn main bearings, they always show more wear in the area opposite the cylinders.
    Sep 2007
    As always you make perfectly good logical sense. Thank you!
    2016 RSV4 RF
    2007
    RXV 4.5
    Sep 2009
    Moscow, Russia
    Thats exactly why all car crank and rod journal bearings are locked ehactly 90 dergees opposite to the piston, so all load is as Amauri explained above, and that makes perfect sense
    apriliaforum expert Danneh's Avatar
    Sep 2009
    Sweden
    how to get main bearings out?
    How to get main plain bearings out of case halves? have special tools and rubber mallet.
    Stuck as sheep. tried to heat case half and cool the tool - nothing!
    Is there any trick to this?
    Sep 2009
    Carlsbad Ca.
    Heat case to 250F using electrical oven. No hotter or you'll warp it. Once you drift the bearings out, Cool it down s l o w l y. (Put it back in the oven and turn it off.) This will reduce warping.
    Never tried using heat.
    I just use a hydraulic shop press, nothing fancy just an H press common to most repair shops.
    Sep 2009
    Sweden
    Gonna try with the press later today
    So you are saying the half shells are made from aluminum..? They are magnetic however.
