Results 1 to 13 of 13
Thread: Intermittent speedo
    apriliaforum expert Twinz's Avatar
    Aug 2008
    Montpelier, VT
    Intermittent speedo
    I just returned from a 4,000 mile trip down south. The Futura was great, other than wearing out a brand new Metzeler Z6 rear tire in 3,500 miles and needing to replace a headlight bulb. We did run in heavy rain for three days and that's when the speedometer started to act out...intermittently it would drop to zero, sometimes stay there and sometimes start working again (I lost 50 miles on one tank of gas to speedo [and odometer] not working). I thought it was moisture related, but yesterday it worked pretty well in the rain all day. I did a search and found few posts about the speedo cutting out. Does anyone have any info? I think the sensor is okay...would moisture bother it? I did clean and treat (w/Stabilant) the connection by the tank last winter...any other places to look for weak connections?
    I was VERY happy my coil waterproofing last winter seemed to work fine...no EFI lights and she ran strong through the rain (unlike last year's trip)! I'll post some pix when I get a chance to look at them.
    Twinz - John
    Montpelier, VT
    New old man wheels: 2002 Porsche 911 Carrera Cabriolet
    Gone but not forgotten:
    '04 RST 1000 Futura
    '94 R1100RS
    '84 R100CS
    '76 R75/6 w/S fairing
    '80 Guzzi V50 II
    '73 Guzzi V7 Sport
    Jun 2006
    Columbus, GA
    If everything else on the dash is working well, I'd start with the sensor.
    Cored OE Racing Cans‡Map2‡Pazzo Shorty Knock-offs‡15-40‡AF1 Link Plates‡Aprilia Sliders
    Laminar Windscreen‡Lowered Pegs‡LED City and Tag Lights
    ProTaper Universal Low‡Clear Signal Lenses
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Mar 2009
    north east Scotland
    Mine only did it a couple of times usually not long after i had adjusted the chain,when it played up i slackend of the wheel and cleaned the sensor of grease and crap ,she worked fine after that both times .
    The "real fast coulor Blue" (not flashy red all show and no go) metal fuel connectors,Bikpaintr rectifier 14.5v stock brown connector
    Sweden, Link๖ping
    I would start looking for a replacement dash...
    Had your problem, first very intermittently and then more and more.
    Did troubleshooting of sensor and wiring and no faults.
    Changed dash and it was cured.
    Probably a bad solder somewhere on the board but to find it
    Mods: Modified ึhlins fork from mille R, EBC 320mm brake discs, HEL front brakelines, Carbon RS 250 front fender, Wiring mod for charging. Engine related:05 map, Iridium plugs, tuneboy, derestriced intake, old mille airboot, staintunes exhaust. Lambda bung hardbrazed in the "breadbox". ึhlins mille R rear shock with 110N/mm spring and the integrated hydraulic preload adjuster. LED Voltmeter installed inside the dash for monitoring charging. Duc 999 radial m/c for brake and clutch.
    Aug 2008
    Montpelier, VT
    Yikes...I certainly don't want to change the dash!! I'll try cleaning the sensor first and keep my fingers crossed! Thanks, guys.
    Twinz - John
    Montpelier, VT
    '04 RST 1000 Futura
    '94 R1100RS
    '84 R100CS
    '80 Guzzi V50 II
    '73 Guzzi V7 Sport
    apriliaforum expert Pars's Avatar
    Dec 2007
    Flanders
    Mine died too this weekend. But only the speedo. The odo gives correct mileage. The speedo needle randomly turns all directions.
    All of this started after i opened the dash for removing the white dust/powder that came out of the speedo needles hole. First thought was the needle had come loose from its axle but nope.
    Anyone with some good advice?
    2010 Black Tuono 1000R
    2013 Kymco Xciting 400i
    2002 Stream Silver Futura: Falco Showa forks, 320mm rotors , wiring mod, new rectifier, FPR mod, BEF's, custom LED dash with integrated voltmeter, warning lights, HID lights, own design topcase rack, brass fuel couplings
    2005 black/bronze Falco: JCE carbon mufflers, Discacciati cast iron brake discs, wiring mod, Mille shock, warning lights, own design bag rack, HID light, Tomasselli adjustable clipons, mini-LED turn signal lights, Gabro dual map chip
    Past:
    1995 Honda VFR750FS
    1978 Zundapp KS50
    apriliaforum Junkie colo_heff's Avatar
    Jun 2005
    Denver, CO
    Wish I could help but ummm ... (view attached pic)... once the sun melted it off I was off and running without a hitch all day...
    Aug 2008
    Montpelier, VT
    Intermittent speedo - Update
    Yesterday, while the rear wheel was off getting a new sneaker (Pirelli Angel ST), I removed and cleaned the sensor. That seemed to fix the intermittent speedo problem. I went for a 100 mile loop today to scrub the new tire, and the speedo never wavered!
    Twinz - John
    Montpelier, VT
    '04 RST 1000 Futura
    '94 R1100RS
    '84 R100CS
    '80 Guzzi V50 II
    '73 Guzzi V7 Sport
    Jun 2006
    Columbus, GA
    Good, added to the 1000cc FAQ sticky.
    Reply more here if needed.
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Oct 2009
    Grantham, Lincs
    Not a big fan of stupid questions but since I've been searching the forum/workshop manual and can't find which one it's, could someone let me know where is the speed sensor?!? I must be going nuts...
    PA USA
    well, not in that pict. If you look at the back of the hub, there's a wire that runs over the back end of the chain guard and into the the center of the hub. this is the actual sensor. There's one screw/bolt holding it in to the casting. It just pulls out iirc.
    what the sensor sees is a ring built into the inner seal of the king bearing that we've been talkin about.
    #19 in this http://www.af1racing.com/store/Scrip...idCategory=488 is what holds the cable at the back of the swinarm
    Oct 2009
    Grantham, Lincs
    Thanks a lot RAS.
    Apr 2019
    Maryville,TN
    I have a speedo that works good (well, about 3-5mph low) when its cooler and when I ride home in the hotter part of the day it reads about half the actual speed. Pulled the sensor and it was super greasy and covered in thick grease. I hope cleaning it good helps behave and perform as intended.
