Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 160
Thread: POSTING: Starter Relay Mod: Futura w/ Ford Relay
  1. #46
    apriliaforum Junkie bbluemm's Avatar
    Southern Ca.
    Big thanks to Motech, stopped by my local Autozone, picked up a relay, had it installed and working in less than an hour. Cost was $11.99 plus tax.....My stock relay was still in pretty good shape as I didn't notice a huge diference in cranking speed, but with 44K miles on the clock, and trip to Salt Lake upcoming, I don't have to worry about getting stranded by the stock unit's expected failure. Nice work Motech.
  2. #47
    Feb 2008
    Hey Motech, please check your PM's
  3. #48
    Aug 2006
    Santa Cruz, CA
    Quote Originally Posted by bbluemm View Post
    Thanks Bbluemm.
    Quote Originally Posted by noskills View Post
    Checked and replied.
    Please note new post below.
  4. #49
    Aug 2006
    Santa Cruz, CA
    UPDATE: Airtex Relay Failure
    Important Note:
    I had a problem with the cheap Chinese Airtex brand I originally installed. It stuck closed once and caused the starter to continue cranking after the engine started. I replaced it with a relay from the Ford dealer, Ford part number E9TZ-11450-5 I highly recommend installing the Ford part in place of any cheap Asian part from the chain stores to avoid the problem I encountered.
    Also note this Ford unit has no "I" terminal, so installation will be even simpler.
  5. #50
    Now that is weird. How did you know the starter was still spinning?
  6. #51
    Aug 2006
    Santa Cruz, CA
    Stalled it on a second gear takeoff from a light, restarted while still rolling and took off all embarrassed. I noticed volt meter stuck low around 11 volts, heard a whining when I stopped at the next light. When I turned off key, starter was cranking engine. Fock! Had to pull into a parking lot, remove seat and whack relay with Leatherman to stop it. (disconnecting primary connector did not stop it, that's how I know it was a defective relay) Cranked for well over two minutes before I got it to quit.
    On the bright side, it validated the deep reserve cranking amps of my 4-year old Interstate battery.
  7. #52
    One of those instances where it would be nice to have a master battery switch between the relay and the starter. if this ever happens again I think it would probably be better to leave the engine running until you had the seat off and were ready to disconnect the cable. You definitely want to turn it off before disconnecting though as you can damage the electrical system if you disconnect with the engine running.
  8. #53
    Aug 2006
    Santa Cruz, CA
    It did happen one more time before I replaced it. This time, thumbing the starter button made it quit.
    Why didn't I try that the first time?
  9. #54
    Dec 2003
    Mtn. Home, AR
    Could you have a bad starter button.
    upload gambar
    2016 Kawasaki Versys 1000
    2002 Aprilia Futura - sold
    2014 Kawasaki 750 Brute Force
  10. #55
    PA USA
    Hmm, will the key pull out in the on position? Kinda need it to get under the seat.
  11. #56
    Aug 2006
    Santa Cruz, CA
    Quote Originally Posted by woodman View Post
    No, disconnecting the relay primary plug would have stopped the starter if that were the case.
    I just got silly and installed a cut-rate relay. To make matters worse, I documented it in public too. Never again will I use that brand for anything.
  12. #57
    Dec 2003
    Mtn. Home, AR
    Thanks for posting this. I am going to install a ford solenoid so now I will make sure it is really Ford.
    upload gambar
  13. #58
    Jun 2006
    Columbus, GA
    What brand? ?
    Part #? ?
    How much? $35
    See the bold
    Cored OE Racing Cans‡Map2‡Pazzo Shorty Knock-offs‡15-40‡AF1 Link Plates‡Aprilia Sliders
    Laminar Windscreen‡Lowered Pegs‡LED City and Tag Lights
    ProTaper Universal Low‡Clear Signal Lenses
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
  14. #59
    Aug 2006
    Santa Cruz, CA
    Woodman, my god man, that avatar...
  15. #60
    Dec 2003
    Mtn. Home, AR
    Yes, thats a world class ass.
    upload gambar
