Results 1 to 15 of 18
Thread: Evo6 full system and side stand
    Jun 2009
    Sydney Aust
    Hi does any one know what modifications are required to the side stand to fit an EVO6 full system.
    Without modifications does the side stand fully retract and does it still touch the collector.
    apriliaforum expert GreaseSnake's Avatar
    Dec 2008
    (Sweden, Europe) OK, US
    I don't know wich sidestand your bike is fitted with, but mine has the "euro-spec" and there is no clearance issue on my 2008 T-F fitted with EVO6.
    So from my knowledge, it works fine.
    Not a whole lot of air inbetween, but clearence is clearence
    (2000Mille, 2008 Tuono Factory, 2007 Tuono R, 2007 Tuono Factory, 2014 Tuono V4R aprc abs, 2000 RS250 MK2, 2008 RXV450) Current. ??? ...coming 2020.
    Apr 2007
    Croatia
    Mine is also OK.
    It's ?06 Tuono.
    Dec 2008
    Quote Originally Posted by Davor41 View Post
    Mine is also OK.
    It's ?06 Tuono.
    Have you changed scilensers? Mine differs quite from yours in length
    (click for larger image)
    Jun 2009
    Sydney Aust
    okay sweet, i just ordered one and cant wait to put it on. Did you notice much difference putting on the full system? How does it sound?
    I had Akra slip ons before and they werent that loud- hoping these will sound nice and deep.
    Westminster, CA - USA
    Mine is also OK.
    It's ?06 Tuono.
    That's not an EVO-6 pipe.
    Dec 2008
    Quote Originally Posted by marke75 View Post
    The sound is deep enough, starting the bike outside makes the windows tremble..
    Havn't tried stock or anything else in that matter, had th Evo6 mounted since the bike was new
    Apr 2007
    Croatia
    hmmm.
    well, that's how i bought it.
    so what is it?
    it has no homologation marks (it's not street legal) and the pipe is bigger in diameter on inlet side to the muffler than the standard pipe.
    I tought it is evo 6.
    Now as i look closer it looks more like Aprilia Akrapovic RSVR Full System -#8796999 (8796999)
    Dec 2008
    That's my guess too.
    You see the difference to my system.
    apriliaforum expert kostas's Avatar
    Jun 2006
    greece
    any way back to our subject it has to pull the side stand a bit out as when you will fit the evo 6 the stand will knock on the pipe my dealer made it to me so i have no clue what he add it to the stand maybe a spacer or so..... good luck and post some pics with the final result
    Apr 2007
    Croatia
    Grease - yes i can see the difference, both in pipes and scilensers.
    My guess is it is Akrapovic RSVR Full System.
    My frend (ex owner) bought the pipes the directly form Akrapovic factory (that's the good thing when you are in Croatia, Akrapovic is just behind the corner ) and they had no Aprilia markings as they were not bought from Aprilia dealer.
    So my mistake, apologies to Mark, thanks to Amauri (once again)
    Dec 2008
    Quote Originally Posted by kostas View Post
    No such difficulties on my bike, yes it's tight but there is a mm or two in between.
    May differ from bike to bike/system to system perhaps
    Jun 2009
    Sydney Aust
    GreaseSnake do you have yours set up with a power commander or are you using evo6 mapping. Should i have mined tuned using my pc3 or use the evo 6 map?
    Dec 2008
    Hi; Have no PC3, ordered the bike with EVO6 from new so according to the retailer the mapping is made for the system. (aprilia map)
    Will try my Motty AFR-tuner with individual cylinder mapping later on this season.
    I would say a PC3 will be a good idea since no engine is the other one alike. A custom tuned pc3 is never wrong. (My opinion).
    Edit: Have you by the way removed the inlet restrictor, in front of the airbox? Recommended!
    apriliaforum expert pizzadude's Avatar
    Sep 2005
    Lancaster, PA
    Davor41 - I hope you didn't pay EVO-6 prices for your cans. EVO-6's are easily twice the price here in the US.
    2007 Tuono Factory
    Mods Thus Far:
    Woodcraft Frame sliders, Look, MV Front & Rear axle sliders, at, Evoluzione Plate Relo, the,
    Decals by CKruzel, Money, Clear Signal Lens, I, 42/15 cogs, Wasted, Cored Exhaust-Map 2, Pirelli DCIII's
