Page 1 of 15 12311 ... LastLast
Results 1 to 15 of 223
Thread: Alternative Coils
    apriliaforum Member UGLY58's Avatar
    Jan 2009
    Las Vegas
    Alternative Coils
    As I still have all four original Sagem coils on my bike its only a matter of time before I need swap them out. I have read here that the Renault/Citroen coils are similar spec, and indeed look at most Renault sites and you will see that their coils fail just as readily.
    Having done some more research it seems the Renault 3.0 litre engine as fitted to a number of french cars uses them same spec coil as the Caponord. I have found a supplier in the UK who can get them at 24.99 considerably cheaper than the OEM.
    As you can see below even the LT lead connection is the same and the HT side seems almost identical as I asked the supplier to remove the rubber boot from the end.
    I am back in the UK next week and will grab 4 Coils and with FalcoJakes -1997 fiat brava HT leads (Halford HIL619) fitting should be painless.
    I will post a report,
    for US readers if this works I can get these sets delivered out to the US at local UK postage rates
    To boldly go where no brit has gone before, or is likely to afterwards !
    Ireland
    Good investigating U58! This would be great if they were the same spec, I payed 120 euro for my last one so at 25 euro that would be great. I wonder would they fail as easily as the sagem ones?
    Is it just me or are the a bit on the short side, maybe tis just the mounting bracketry making it look short?
    Brum Brum
    May 2007
    NEWPORT SHROPSHIRE UK
    This sounds like an interesting find. Do these new coils have the same primary winding specification as the Aprilia ones and more to the point who is the supplier of these coils ? I also have four Sagem coils on my 04 Capo with nearly 27000 miles on the clock and keep thinking to myself when is one going to give up on me. Steve
    Jan 2009
    Las Vegas
    Until I get the coils in my hands I can`t test them, however from what I have read on the the Clio V6 web sites they are the same spec and suffer the same failure rate.
    http://www.k-tecracing.com/show_product.asp?id=2464
    Sadly familiar:
    http://v6clio.net/forum/knowledge/kb_show.php?id=53
    However the supplier I am looking at is
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
    He has been very helpful with specs and photos hence IMO deserves the support. I am trying to get a quote for the Fiat Brava ignition leads from him to make a complete set.
    Others have them part No. 925PE0000
    http://www.gsfcarparts.com/index.asp
    http://www.aepdirect.com/index.php?o...roduct_id=5816
    Apparently the original Sagem part No. for the Clio v6 is 597094, sound familiar ?
    FINALY I found this seems the beneli owners have hit this one on the head:
    http://www.engenia.com.au/08_FuelIgn...aleoCoils.html
    Seems Valeo have bought JCI so these coils could well be the JCI ones ???
    apriliaforum expert falcojake's Avatar
    west midlands
    wow good find.
    the normal fix is the scenic coil, i have a set of these since i also have a scenic and i lost one coil at 92k miles so replaced tham all. these are not an ideal solution since they are designed to sit on the plug top without the ht lead. so to use these it would be better to do without the HT lead as someone on here did with some mitsubishi coils . also the low tension connections are not right so adaptors must be made up.
    i thought the dynatec twin pack coils would be good soloution.
    let us know what 3.0l renault the coils were from, espace? safrane? and how you get on
    May 2007
    A1 info UGLY, looks like on one of the links that they seem to think that primary and secondary values for the coil look to be the same as the Aprilia coils so this is a good findSteve
    Ireland
    I have a really silly question ive been dying to ask, excuse me if its been asked or if its very thick.
    Is it possible to approach a company who make coils (or who could) with our specs and say 'make us a coil like this crappy one from my capo/cliov6/futura but make it uncrappy and we will all buy them off ya as our ones are crappy and keep failing....'
    Would the economy of scale be too small on a run of these to make em affordable?
    Brum Brum
    Scottsdale, AZ
    Quote Originally Posted by the_toe_cutter View Post
    Why do you think the Aprilia coils are so expensive? Limited demand. Get some company to tool up for a run of 500 coils, and I'd think the retail cost per coil would give you heart failure.
    Stu
    Melbourne, Australia
    Yeah - years ago, I was told by a Yamaha executive that they had investigated building a 500cc single engine just for Speedway racing.
    (To our US friends, that's 440 yard dirt oval, no brakes, widely raced in Europe but actually invented in Australia.)
    Yamaha felt they could substantially improve on existing design in terms of weight & performance; trouble is, when they did the sums, they realised that the global annual consumption of Speedway engines would occupy their engine production line for just 12 minutes a year - and the cost per unit would be in the hundreds of thousands of dollars.
    Aut viam inveniam aut faciam
    Jan 2009
    Las Vegas
    All French v6 car engines seem to use this coil Renault, Citroen etc. I focused on the Clio V6 as it a highly tuned car with lots of enthusiastic following.
    As Stu_O says its limited demand that makes the Aprilia coil so expensive. But add a few hundred thousand car owners into the equation and they get cheaper and people start producing pattern parts for the car, as is Valeo here.
    If anyone wants to jump the gun on this a try them in the Uk before I get back there please do.
    I am going to order 4 and a set of the leads soonest will be fitting the second week in November, fingers crossed.
    apriliaforum Member caponige's Avatar
    Sep 2008
    scunthorpe , n/lincs , uk
    wow what a find , great work
    ive got a coil gone down so im reading this with great interest
    apriliaforum expert quicktoys2's Avatar
    Feb 2007
    Patras, Greece
    A few months ago replaced my last remaining Sagem coil with the newer JCI coils .... the APRiliA dealer price was just under 50 Euro ........ who the hell is charging 120Euro????
    Soto
    ___________________________________
    Rubber side down, shiny side up!!
    03 silver Caponord
    H & B crash bars
    Ermax windshield with Laminars lip
    Givi Maxia Monokey top box
    Aprilia handgaurds
    Handle bar risers
    Center stand
    Hyperpro springs - front and rear
    apriliaforum expert calgaryjeff's Avatar
    Dec 2003
    Gilbert AZ
    how come all you guys didn't make these finds a month ago before I took the plunge on 4 new coils????
    2003 CapoNord
    1985 Honda VF1000R (gone to a new home)
    IBA #23204
    Sweden, Linköping
    Quote Originally Posted by quicktoys2 View Post
    Soto
    Where can I buy them for 50 Euro?
    Ireland
    Yeah if they were 50 quid id buy a couple. It was off Ducati Dublin who do aprilia too. I would have ordered online but needed her fixed in a hurry, stung the wallet alright, at least it was jci.
    Brum Brum
