Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 139
Thread: How-To proceedures
  1. #76
    apriliaforum expert Markee's Avatar
    Feb 2008
    Melbourne, Australia
    How-To proceedures
    It's like when people run the breather to a catch bottle that's sealed and then wonder why the air box is full of oil. Your catch bottle is an extension of the breather system make sure it can vent also!!!!
    '09 MXV450
    Quote Originally Posted by Alice Racing View Post
    The motor and maps are race orientated, and want gunning !!
  2. #77
    Nov 2008
    Western Australia
    Quote Originally Posted by Markee View Post
    Which is the crazy thing about the catch can system...
    Being vented to atmosphere you can still put fluids on the track...
  3. #78
    apriliaforum expert swerver's Avatar
    Jun 2011
    London
    Quote Originally Posted by Allen Noland View Post
    AMEN! Funny how engines need to breath too. My sister's boyfriend had a modded, turbocharged, lowered, blacked out Ford Escort that he was absolutely in love with. After one of his "improvements", it started pumping oil up the dipstick tube with enough pressure to blow the dipstick out and cover the engine compartment with most of the engine oil. Instead of fixing the crankcase breather issue he had created, his solution was to throw the dipstick away, drill a hole in the oil fill cap and run a hose (braided stainless of course) from the dipstick tube to the oil fill cap. Eventually the fuel vapors contaminated the oil and it put a rod through the side of the block.
    comedy gold
  4. #79
    May 2015
    SF Bay Area
    Oil change linky no worky. Tried finding it elsewhere with no luck. Anybody have a link that works? Thanks, and hello!
  5. #80
    Jun 2011
    London
    Quote Originally Posted by Mantisfists View Post
    It's at the top of this thread:
    http://www.apriliaforum.com/forums/s...=1#post2282705
    If you mean how to reset the dash display, you can find that here:
    http://slorider.com/Aprilia/tech/Display/
  6. #81
    Feb 2009
    Tri-Cities, Washington
    I think he was talking about the link to irie's info not working. I added it here for download, as long as irie doesn't have a problem with me doing so:
    proper oil change procedure.pdf
  7. #82
    May 2015
    SF Bay Area
    Quote Originally Posted by SXVINWA View Post
    This
    Thank you, exactly what I was looking for.
  8. #83
    Feb 2009
    Sensor location and other tidbits of info from Aprilia:
    aprilia_sxv_ppt.pdf (20 MB file)
  9. #84
    May 2008
    GREECE
    I am starting to loose my patience with Noale. The pdf you uploaded, writes 15hours intervals for fluid change.
    My manual (ed. 3 of 2008), states FAR less: 3hours
    What the fuck?
  10. #85
  11. #86
    Westminster, CA - USA
    Quote Originally Posted by bros400pgm View Post
    I suggest you read the manuals but don't take everything as absolute.
    Most who have owned these bikes and have learned to work on them, have developed their own service procedures based on experience. Using common sense can sometimes be much better than the manual.
  12. #87
    May 2008
    GREECE
    What most surprises me is that someone finally replied. Kudos Amauri.
    I tend to change the gearbox at 3hours, after a talk we had with Hinson (he supplied me th BTL slipper), so i change the engine oil at the same time. On a friends SXV, we change them at 5 hour intervals and that is the top i think i can go with such engine on track. Silkolene pro4 15w-50 are used on my engine, 10W-60 motorex in his.
  13. #88
    apriliaforum newb Mischief24's Avatar
    Nov 2015
    Iowa
    Hi, I'm a noob. I'm changing my front and rear sprockets today with a new ek 3d chain. I can not find the torque specs for the rear sprocket bolts, I think the axle is 127Nm and called the "Wheel shaft nut"? Found at http://slorider.com/Aprilia/ Any tips on installing a new chain, where should the chain adjusters be set at for a new chain. 07 SXV 450
    Thank you
  14. #89
    Feb 2009
    Rear sprocket bolts should be torqued to 35Nm (26 ftlb). You are correct with 127Nm for the axle nut. The chain adjusters should be adjusted to give the specified 20-25mm chain slack.
  15. #90
    Nov 2015
    Iowa
    Thanks SXVINWA. Is there a manual that is not on the slorider website? or is that torque spec the norm for rear sprocket bolts? I'm telling ya I searched for a couple hours before asking.
