Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 94
Thread: can you replace the airbox with a filter?
    37 miles E. of ATX, TX USA.
    Oh and yes, when you remove the cover the filter is still bolted in place. This alone giving 5 bhp is pretty sweet.
    To really make a Mana run without a turbo as in the link above one would need to switch to individual throttle bodies, or at least a much larget single throttle body and adapt a PCIIIusb or PCV to the Mana, easy enough to do really. If the bike was selling in any sort of actual quantities I would have done this already. As it is right now there are like 3-5 people in the whole country who seem to be interested in getting more power out of a Mana.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    May 2006
    I will have to count myself in on the power increase. I am ordering a second air filter cover to play with and wouldn't mind playing with a PCIII. What are your thoughts on NOS, for the drag strip. Maybe a stepped injection over 2-4 seconds.
    Jan 2009
    gone
    Kinda forgot about this, thanks for the reminder. I painted the cover semi flat black just because i like it better. I removed the cover & pried the metal emblem off with just my finger nails. it just popped off nicely. Next I cut the plastic leaving a band for the s.s.screw. I used baby powder on the adhesive so it is no longer sticky. You can run without the emblem or run with it slightly raised,( the wife won't notice it) or if it is raining just screw it down.
    the only cost will be the stainless screw.
    apriliaforum expert JodyH's Avatar
    Jun 2007
    New Mexico, USA
    I like the black cover.
    I'll be doing that tonight.
    "Nihilists! Fuck me. I mean, say what you want about the tenets of National Socialism, Dude, at least it's an ethos. "
    Aug 2009
    Shadyman, thanks for the pictures. Nice work. I will be rigging up something very similar.
    Sep 2008
    Belgium
    Better airflow, security and aerodynamics of the aprilia aibox...
    I'll receive it tomorrow...
    dnafilter for Mana
    The DNA High performance air filters
    The DNA High performance air filter is a high quality next generation multilayer cotton gauze oil impregnated air filter.
    The filter media is made of 4 layers of high quality nafta surgical cotton gauze specialy designed by our R&D department.
    The cotton is sandwiched between two layers of epoxy coated Marine grade aluminum wire mesh, designed to last a lifetime.
    The 4 layers of cotton and the two layers of wire mesh are pleated by state of art electronically controlled pleating machines to assure a very high quality of the final filtration media.
    The result of the special design and the Hi Tec manufacturing process is a filtration media that has very high flow rates, low restriction, superior dust holding capability, smoothens out the air flow stream and lasts a lifetime.
    The oil that we use to impregnate the cotton is a very special grade developed by our R&D department after intense testing and produced by one of the world's best Oil Companies. This special oil is a very critical part of the filter and has the capability to produce a static charge to the cotton media and attract the entire dust particles that flow towards the filter, even the very fine ones.
    The High Performance!
    The High Performance of the DNA air filter is a must for all of our designs and our R&D team uses up to date Hi Tec equipment to achieve the best performance.
    Our R&D department is equipped with the latest Dynojet motorcycle & automotive dyno's and sophisticated air flow measuring equipment. Every single filter is tested and checked that it meets the High Performance standards that DNA has established.
    As a final result the customer receives the best performance air filter money can buy!
    The Long Life
    We at DNA proudly introduce a filter that can last the life of the vehicle.
    High quality materials, Hi Tec manufacturing process, designs that meet OEM quality levels and very strict quality control, is the secret behind the DNA Air Filters and the factor that allows us to give a Lifetime Warranty!
    Taking Care of the Filter
    The DNA Air Filter will serve you for many years and needs very little care using the DNA Service kit.
    When the filter is dirty simply follow the instructions that you can find in the service kit, allow the filter to dry, reoil and you are ready to use your filter again, like new!
    Taking Care of the Environment
    DNA brings "Taking care of the environment" one step ahead, by designing, producing and marketing a filter that you will never need to throw away.
    Using cotton instead of paper, we provide work to the cotton industry and on the other side no trees have to be sacrificed for paper to be produced.
    DNA Air Filter owners do not produce unnecessary waste as paper filter owners have to do every time the life of the paper filter ends.
    Even the box is designed and manufactured of top quality material allowing you to keep it in your garage and use it as a storage box.
    apriliaforum Junkie SilverFoxUno's Avatar
    Sep 2008
    Pacific North Wet, USA
    I've done a little research at K&N and it appears that an MG-0001 may fit the Mana. I am about to pull the trigger to purchase one and see...
    Jim
    "That's not flying...that's falling with style!"
    2008 NA850 Mana
    2003 VFR800 Intercepter
    Jan 2009
    gone
    I'm not a big fan of oiled filters. I purchased one for my pickup & it eventually coated the mass airflow sensor causing all kinds of trouble codes & drivability problems. Also in the instructions that came with the filter it said not to be hasty in cleaning it, as it is more efficient a little dirty.WTF. When K&N claims they flow more air, it's compared to a dirty paper filter, not a clean paper filter. No shit! Just my opinion.
    Oct 2009
    Thumbs up beltup
    Hi to the lords of the Mana. Anybody have any information on the Drive Belt replacement,apparantly Dealers can hire the tools from Aprilia . ? what is the life expectancy of the belt also the approx cost of having it replaced. Never had a bike that aroused such interest and yet do not see many on the road. Got to say after 28 bikes in 12 years its the dogs dangly bits . Cheers jimmyg
    May 2008
    The best replacement is every 12000 miles. Mine is going to get its second belt in the next few months.
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    Austin, Texas USA
    We now stock the aforementioned DNA filter:
    http://www.af1racing.com/store/Scrip...idproduct=7909
    9900 North Interstate 35
    Austin, Texas 78753
    direct:512-459-3966 fax:512-482-8319
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
    Sep 2008
    Funny, Steve...it looks just like the K&N MG-0001 filter I put in my Mana. BTW, the K&N was a perfect fit.
    Jim
    2008 NA850 Mana
    apriliaforum Junkie Motopsycho's Avatar
    Jun 2009
    Ocala Fla.
    count me in with Cochise on the power adders..... so thats 2 already on the east coast. Now this blog is getting some meat to it. Can't wait to try the air filter hop up!
    Aug 2008
    Tennessee
    I like the looks of this from Vance and Hines, but I doubt they would make one for a low production bike like the Mana.
    apriliaforum Junkie groovymaster's Avatar
    Apr 2008
    Seattle, USA
    I cut small slits on the bottom of the airbox cover. Definitely gets more air and it's rather unlikely that water will get to the filter. Rode it in the rain and had no problem. Then I decided I didn't like the big bulky airbox hiding the trellis frame so I replaced it with a K&N filter that I had. The K&N has a chrome cover and work fine in the rain.
