Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: Aprilia Pegaso 650 Strada/Trail TIPs
    Apr 2009
    Specifications of Strada and Trail. Differences between both were marked as Italic
    Strada:--
    ENGINE
    Type 659 cc, liquid cooled, single cylinder, 4-stroke
    Bore x stroke (mm) 100 mm x 84 mm
    Compression ratio 10:1
    Valves Single overhead cam with chain timing drive, 4 valves per cylinder
    Fuel system Integrated electronic engine management system. Electronic fuel injection. 44 mm throttle body
    Ignition Electronic
    Power 50 hp (37.3 kW) @ 6250 rpm
    Torque 61.3 Nm (45.2 ft. lbs) @ 5200 rpm
    Lubrication system Dry sump with oil pump
    TRANSMISSION
    Clutch Multiple disk in oil bath. Cable control
    Gearbox 5 speed
    Ratios 1e 12/30, 2nd 16/26, 3th 20/23, 4th 22/20, 5th 26/20
    Primary drive 36/75
    Final drive Chain, 15/44
    Starting system Electronic
    CHASSIS
    Frame Steel, open cradle, single spar frame.
    Front suspension 45 mm fork, 140 mm travel
    Rear suspension High strength steel swingarm. Aprilia Progressive System (APS) rising rate linkages. Sachs hydraulic monoshock with adjustable rebound and preload, 130 mm travel
    WHEELS
    Wheels Alloy wheels with split spokes.
    Front wheel 17 x 3.5
    Rear wheel 17 x 4.5
    Front tyre 110/70-17
    Back tyre 160/60-17
    Front brakes single 320 mm floating disc with 4-piston calipers
    Rear brakes single 240 mm disc with 1-piston calipers
    DIMENSIONS
    Overall length 2160 mm (85 inches)
    Overall width 810 mm (31.9 inches)
    Seat height 780 mm (30.7 inches)
    Wheelbase 1479 mm (58.2 inches)
    Ground clearance 250 mm (9.8 inches)
    Fuel capacity - reserve 16 l (4.2 gallon US) - 3.5 l (0.9 gallon US)
    Dry weight 168 kg (370.4 pounds)
    Trail:--
    ENGINE
    Ignition Electronic
    TRANSMISSION
    Gearbox 5 speed
    Primary drive 36/75
    CHASSIS
    Front suspension 45 mm fork, 170 mm travel
    Rear suspension High strength steel swingarm. Aprilia Progressive System (APS) rising rate linkages. Sachs hydraulic monoshock with adjustable rebound and preload, 170 mm travel
    WHEELS
    Wheels Aluminium spoked
    Front wheel 2.15 x 19
    Rear wheel 3.00 x 17
    Front tyre 100/90-19
    Back tyre 130/80-17
    Front brakes single 300 mm floating disc with 2-piston calipers
    DIMENSIONS
    Seat height 820 mm (32.3 inches)
    Ground clearance 270 mm (10.6 inches)
    Pegaso's Service Code = 25973
    Aprilia models service manual link :--
    http://www.serviceaprilia.com/public...-Trail-Factory
    Wiring Diagram :-
    http://www.apriliaforum.com/forums/s...d.php?t=146974
    GIVI Top Box Rack = SR79
    BMW F650 Handguard = 71607682222
    K&N Filter P/N = AL-6505
    NGK Iridium Spark Plug = CR7EIX or CR8EIX
    Denso Iridium Spark Plug = IU22
    Airbox/Snorkel mod, step by step pictorial guide :-
    http://www.apriliaforum.com/forums/s...ghlight=airbox
    Here is how to block off the Secondary Air System (SAS) :--
    http://www.apriliaforum.com/forums/s...d.php?t=163157
    Here is the pictorial guide to work on the meter, efforts by Cupid Stunt :--
    http://www.apriliaforum.com/forums/s...d.php?t=178985
    Here is how to change CO, efforts by Elvis :--
    http://www.apriliaforum.com/forums/s...d.php?t=201505
    Stage 2 Air Box Mod, by Elvis :--
    http://www.apriliaforum.com/forums/s...d.php?t=198714
    Radiator Stone Guard :--
    http://www.apriliaforum.com/forums/s...light=radiator
    Lambda Sensor Function and Loop Mod, efforts by Factory660 :-
    http://www.apriliaforum.com/forums/s...d.php?t=210169
    TPS Adjustment guide, by Factory660 :-
    http://www.apriliaforum.com/forums/s...45#post2596945
    Replacing the stock Aprilia Fuel pump with one from BMW F650GS, by Frodo :-
    http://www.apriliaforum.com/forums/s...d.php?t=222937
    Ignition Switch Wiring Problem and Solution, by Geonapa :-
    http://www.apriliaforum.com/forums/s...-wires-problem
    Preparations for Valve clearance checks, by Dartist :-
    http://www.apriliaforum.com/forums/s...ut-practically
    Torben4180's New Fuel Pump Mod :--
    http://www.apriliaforum.com/forums/s...-Fuel-Pump-Mod
    apriliaforum expert fedro69's Avatar
    Apr 2008
    Hamburg
    sorry, but both of them have a 1-piston calipers on the rear brake...
    Apr 2009
    Updated rev3 today. Added Airbox and SAS mod links.
    apriliaforum prov-nov Ge0rdie's Avatar
    Apr 2010
    Newcastle Upon Tyne
    Good Info
    How many links is there in a standard chain?
    Keepin it shiny side up
    BMW R1150 GS 2001
    Suzuki DR600 1987
    Pegaso 650 2007 Black
    Speed Triple T509 1997 Black
    Yamaha MT-01 2005 Purple
    BMW R1150GSA 2002 Silver
    VOR 492E 1998 Blue
    May 2007
    Germany
    Quote Originally Posted by Ge0rdie View Post
    Good Info
    110 with 15/44 sprockets
    May 2007
    Germany
    Hi Bising
    you can add my guide "how to adjust the CO" if you want
    Apr 2009
    Updated.
    Tks.
    Apr 2009
    Corrected the links. Tks for the feedback.
    apriliaforum Junkie wuming's Avatar
    Jul 2008
    London
    Can we make this thread a "sticky" please?
    Also, I remember over the last couple of years that I've been on the forum of a few improvements that can be done (I've forgotten the posters as well as most of their modifications, sorry). Things I half remember include:
    1. An improved fixing for the radiator.
    2. Protection of some potentially exposed wires under the tank (I think Joybringer had a major problem with this?). Also the wires in the belly pan.
    3. That old favourite, the fuel pump. Any definitive, reliable replacements?
    I am looking at prepping my Peg. ready for a (potentially, hopefully!) LONG trip. So want to deal with potential weak areas before they cause problems. To date, I have had no problems with my bike, but want to do what I can to maintain it's good performance on a long overland. So if any of you remember or have suggestions/links for the above 3 (or any other good ideas) then add them to this thread; or should I start a new thread? Thanks all.
    无名-傻子老外!
    2006 Pegaso Trail Now sold
    http://wuminglondontokl.blogspot.com/
    Feb 2009
    Reading, UK
    EBC Brake Pads page - Need to select make / model from the drop down.
    http://www.brakes4u.co.uk/supersearc...id=55732&won=1
    Also lots of options here (from Google search):
    http://motorcycleproducts.co.uk/cata...42f690f85491e6
    May 2007
    Germany
    TO ALL PEGASO FACTORY OWNERS
    When ordering a rear sprocket be careful because allot of on line stores including the manufacturers list the same rear sprocket to the strada and factory although they each have a different sprocket.
    what you need is this
    the Starda have 120 inner diameter
    I wrote JT and ES JOT about it that they will change there on line catalogue but until last month when i checked they still have the Strada and factory together.
    apriliaforum Member Factory660's Avatar
    Jul 2010
    Essex, UK
    How about adding the Factory as well?
    I've added the different dimensions already.
    Factory :--
    ENGINE
    Ignition Electronic
    TRANSMISSION
    Gearbox 5 speed
    Primary drive 36/75
    CHASSIS
    Rear suspension High strength steel swingarm. Aprilia Progressive System (APS) rising rate linkages. Sachs hydraulic monoshock with adjustable rebound and preload, 130mm travel.
    WHEELS
    Wheels Aluminium spoked with Gold anodised rims
    Front wheel 3.50 x 17
    Rear wheel 4.50 x 17
    Back tyre 160/60-17
    Front brakes single 320 mm floating disc with 4 - piston radial caliper with radial master cylinder.
    DIMENSIONS
    Overall length 2173 mm (85.6 inches)
    2007 Aprilia Pegaso Factory
    Akrapovic Slip-On's
    Dynojet O2 Optimiser
    K&N Air filter
    TPS 16
    CO -3
    Pirelli Diablo's front and rear
    Jul 2008
    London
    Probably wise to add geonapa's ignition wires stuff:
    http://www.apriliaforum.com/forums/s...d.php?t=192846
    无名-傻子老外!
    apriliaforum Member geonapa's Avatar
    Feb 2009
    Cyprus
    Yea....add me up too.
    Thanks wuming.
    SUZUKI GSXR1000R K6
    YAMAHA YZF1000R
    exAPRILIA PEGASO STRADA 650
    Apr 2009
    Sticky updated. Added links :--
    Geonapa's Ignition Switch problem and solution.
    Dartist's quick guide to prepare Pegaso Valve clearance checks/adjustments.....
    Torben4180's New fuel pump mod..
