Results 16 to 30 of 60
Thread: Ohlins Shock Install / Linkage Mod
    apriliaforum Junkie SD Rider's Avatar
    Nov 2007
    San Diego, California
    Quote Originally Posted by The Fixer View Post
    Thanks Guys. I'll get a photo of the preload adjuster and post it later. Not as convenient as a remote hydraulic adjuster,but it really is quick and easy. Adjustment from the left leaves the hot pipes on the right so it's still possible to do with the engine hot without getting burned. Rebound damping on the bottom of the shock is actually more difficult to get to but still easy enough.
    Excellent work, pictures and write-up. BTW, I highly recommend wrapping the exhaust pipes that run near the shock with 1 inch header wrap. I ordered 15 feet and it was just enough. This helps prevent heat transfer to the shock, reduces fade, and will make it last longer.
    See my thread http://www.apriliaforum.com/forums/s...d.php?t=172060
    Connecticut
    Glad to see you finally have a decent rear shock but that blue spring will cost you serious Ohlins bling points. By the way its Wilbers not Wilburs. Its a shock company not the owner of a talking horse.
    John B.
    Apr 2005
    Quote Originally Posted by bikpaintr View Post
    Duly noted. I'll make the proper spelling corrections, but I wont paint my spring. My apologies to the horse and the Germans.
    ďThe roadís what counts...donít worry about where itís goiní."
    - Sam Shepard
    -Neil Peart
    Jul 2004
    Phila, PA
    Well Done! The dogbone spacers are neat. What sizes did you use?
    JBC
    Apr 2005
    Quote Originally Posted by JBC View Post
    Don't remember the exact thickness. Pretty sure the spacers were around 0.075" thick. PM Kzmille and he'll set you up based on your measurements. He doesn't charge much. The center hole of the shim fits perfectly over the middle spacer so they fit and feel like a factory part. A worthwhle mod.
    - Sam Shepard
    -Neil Peart
    Nov 2007
    Help me to understand why these shims are necessary. The light bulb isn't coming on.
    Apr 2005
    Basically just to take the slop and lateral play out and stop the rubbing of the side plates. Read more here...
    http://www.apriliaforum.com/forums/s...d.php?t=177271
    - Sam Shepard
    -Neil Peart
    apriliaforum expert spaz_666's Avatar
    May 2007
    Chicago 'burbs
    Great work, Mike & excellent write-up!
    -joe
    "It's all in the reflexes."
    -Jack Burton
    Carthage, NC
    I just pulled the trigger on a Penske shock for mine, so I'll see how that does. My guy actually recommended the Penske over the Ohlins, which was what I called him about to begin with.
    Ron
    MSgt USMC (Retired!)
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    Jan 2005
    Annapolis, Maryland USA
    Hi Ron,
    Let us know how it installs and rides! Don't forget photos, if there is anything interesting to see.
    Carthage, NC
    It's got to ride better than this 35K worn out stocker......
    Forks will be next, but I will just revalve the stock forks rather than go with some other forks.
    Ron
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    Apr 2005
    Did you have to send them your old one first? Teachers did and it ended up messing up 2 OEM shocks. I don't know if it was the shop he was using or Penske's fault. I don't know if he ever got it straightened out. I'd like to hear the whole story. Maybe he'll chime in here...
    Otherwise I've had people tell me that Penske is the best shock as well. It's a lot easier to get answers about tuning and support from Penske than from Ohlins...that's for sure. Nice that it's more "local" as well.
    35k on the stocker? No wonder you're always scraping hardparts in those photos!
    - Sam Shepard
    -Neil Peart
    Carthage, NC
    Naw. The shock is still on the bike and Penske has specs for a shock for it. The biggest variable is the spring.
    Ron
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    apriliaforum expert teachers's Avatar
    Apr 2005
    Montrose, PA
    Mike: I have to set up some Q&A for an online class, grade 5 accounting finals, and create another final exam. When I get done with that, I'll be back.
    Ron is correct: Penske does list the RST in their current catalog. That was not the case in Dec. '07 (according to the dealership near Reading, PA where Penske has a shop and employed Bill Himmelsbach Jr.).
    I did see the Penske catalog recently and the Futura was listed. Ron will probably not have the issues I faced.
    IBA #28362
    2004 Futura - Silver
    Tigcraft Slip Ons - Jet-Hot coated exhaust & AF1 H-Pipe - PC III - Destricted w/ Mille Boot & Evoluzione Air Filter - Colder Fuel QD - Borella Regulator - Heli Bars - Geelong CF tank protector - Throttlemeisters - Headlight Mod & HID x3 - RaceTech fork parts - Zumo 550 - ne-oublie's Pivot Covers - R&G Sliders - PC-8 fuse box - SmartTire TPMS - some goodies for the FAMSA tank bag - provisions for Gerbings - a voltmeter waiting to be installed - new Pirelli Stradas waiting to be installed
    Me and my RST:
    Apr 2005
    What spring are you getting? Like I said, Traxxion recommended that I go with 115.
    - Sam Shepard
    -Neil Peart
