Results 1 to 7 of 7
Thread: only running on one cylinder
    Jun 2007
    Seattle
    not entire sure what happened. fine one day. not the next. i know i have one coil on the way on out.
    i can't tell which cylinder isn't firing or why it isn't.
    this is a tuneboy sensor readout.
    could some give me some tests i could perform to try and figure out what's going on?
    tia
    Jun 2007
    Seattle
    also i have a set of cbr coils i plan on swapping to, but haven't gotten there yet.
    Jun 2007
    Seattle
    update. it's the rear cyclinder. just pulled the plugs after a firing it up a couple times. rear ones are soaked in unburnt fuel
    Sweden, Linköping
    Looking at the dwell times in tuneboy it should be coil nr.3
    Jun 2007
    Seattle
    coil 3 is a forward coil according to http://www.apriliaforum.com/forums/s...90&postcount=4
    Jun 2007
    Seattle
    problem found.. bad coil and bad plug wire...
    Sweden, Linköping
    so it was not coil three?
    Check the dwell time again after replacement if no. 3 is now in line with the others.
    Perhaps there is a bug in Tuneboy for coil numbering.
