Results 31 to 45 of 46
Thread: Cleaning of the stepper motor
  1. #31
    Sweden, Linköping
    Quote Originally Posted by mini_me View Post
    Officially, according the manual, you need to reset the IAC in the ECU.
    I too battled the high idle situation for a while. I have swapped IAC 3 times with resetting the IAC. Every time the idle went back to normal directly after a swap.
    There is no reference to reset in the futura manual. Could be linked to which efi system is used.
  2. #32
    Jul 2012
    Chorley, Lancashire
    Just clarify the reset of the stepper motor....
    you will need an ODBII cable and the TuneEcu software. Once the ignition is on kill on so bike would start you go to the "Tests" screen in this screen you will see "Adjust IACV" click on this... You will see two boxes you can then Adjust AICV Value ... DONT LEFT CLICK.
    right click over the adjusting icons then "Reset" will appear. Left click that and it should reset to -1
    there should be no need to do this as the AICV self rights whenever you turn the ignition on and off.
    Blips of throttle are ness between each change you make so after non running ignition on changes starting the bike will be needed. Changes are best done to an engine at operating temps 74-78degC the bike will then be on RUNNING map not on the warm up control.
    Me n' Mine:-
    2006 Caponord ETV 1000 "Twiki"
    2004 Tuono Racing Rep, Full Carbon with SBK 2-2 Akro's
    2002 ZX636 A1P Ninja list of mods is endless
    "Made in Italy....Perfected in my Garage"
    I've never questioned why I ride, it's as basic as breathing.
  3. #33
    Apr 2016
    Brooklyn, NY
    Thought I might resurrect this thread instead of starting a new one.
    I took out my stepper motor today as I've been struggling with a very high idle speed (2-2.5k in neutral, just under that in gear). I did have oil in the airbox, and the white plunger did seem rather dirty. My question is do I grease it at all before reinstalling, or just keep it dry?
    I also noticed that where the outlet ports are in the valve, there are 2 raised spots on the plunger as seen below. I assume this is normal?
  4. #34
    Sweden, Linköping
    Plunger should be smooth. I don't grease it at installation.
    Do a vacuum balance check afterwards as the plunger can influence it.
  5. #35
    apriliaforum newb dabore's Avatar
    Mar 2015
    Holland
    I got an EFI error 44. Stepper motor kaput. Searching on the net I found out that any car stepper motor fits, all made in mexico, all have they own brand sticker. I went out and got my for 5 $/€, originally for a peugot 205. Its a perfect fit, I used the plunger from the broken stepper and put everything back in place. Key on and the ECU will do the rest.
  6. #36
    May 2016
    Costa Rica
    Quote Originally Posted by br3ttw1lls View Post
    I too have the same raised areas on my plunger, and had the high idle problem. I figured it was not sealing properly and letting in too much air. I looked at spinning the plunger 180 degrees, but it is keyed in the motor. So I installed the motor 180 degrees out of the normal position. This allows the "good" side of the plunger to line up with the ports. The only difference is that the connector plugs in from the back now. This has cured all idle issues, and saved me the big expense of a new motor just to get a good plunger.
  7. #37
    Apr 2009
    Thumbs up Variable Idle
    Quote Originally Posted by Tuzo View Post
    IAC (stepper motor)
    symtoms:
    -low variable idling which is even worse with the clutch in while in gear at a stop sign and stalling when coming to a stop (I had to immediately put it in neutral at a stop sign or light).
    temporary non-fixes:
    -adjusting your PC map (this works somewhat but it is not the true fix)
    -hand cleaning the stepper motor (lasts about two days)
    Fix: replace it with a used or new one (I picked up a used one on eBay and it worked good and even better when I zeroed out the PC entries I had used previously) or the above entry if you have an ultrasonic cleaner (did you use normal tap water?) above.
    Before you gio much further I had similar idle issues on my 2003 ETV100 Capo. All were cured by installing new vacuum hoses. The one fitted were probably original and essential wooden, stiff and garbage. New hoses and darn near perfect idle.
    Try that if you wish.
    PTC
  8. #38
    May 2017
    Czech Republic
    Has anyone tried a BMW IAC? from photos 7676317 looks about right:
    it comes from some k1200r and f800 models it appears. it is not cheap as a new part either around 120, but it pops up on ebay and other used parts dealers a bit more often and not too bad used.
    seems like BMW f800 has the same issues when it dies: http://f800riders.org/forum/showthread.php/50935-Idle-Control-Idle-Actuator-Air-Bleed-Circuit
  9. #39
    PA USA
  10. #40
    May 2017
    Czech Republic
    sorry if this double posts....
    looks like the f800 bmw and potentially the k1200 use a similar valve:
    http://www.bmw-etk.info/parts-catalo...05/13717676317
    looks to be the following part 13 71 7676317
    i have yet been able to track down the exact years and all the models it appears in. but i have had an easier time tracking this down used. found one for 35 dollars used. really tempted to try just to see if it is another source of the piston atleast.
  11. #41
    Jun 2016
    Los Angeles
    I got a prefect idle by replacing all vacuum hoses, including the ones to the slipper clutch, and also all the connecting barbs, clamps and the one-way valves.
    Remapping and bumping up the long term fuel trim was the thing that eliminated the slow loping idle that sometimes appeared, that everyone said was "normal" for the Rotax.
    2001 Moto Guzzi V11 Sport, 2002 Aprilia Caponord, 1983 Moto Guzzi 850 LeMans III (sold), 1983 Yamaha 650 Turbo (sold), 1972 Honda CB750 (sold), 1981 Moto Guzzi V50 III (totaled), several Vespas and one Lambretta
  12. #42
    May 2016
    Costa Rica
    There should be a bunch of K1200 steppers around. I think BMW recalled them and replaced them with a new air box too. I saw this a while back, but there was nothing here in Costa Rica to compare it to.
  13. #43
    apriliaforum newb Tahlia Muller's Avatar
    Jun 2018
    USA
    Clean it with some electrical or carb degreaser (from halfords) and a cloth or soft brush.
    It is simple to tell if the stepper is working properly. Unscrew from the plenum but leave plugged in. Turn on the ignition - the stepper motor will move through its phases and be fully extended. When you turn of the ignition you will see the stepper motor reset to fully closed. If it is moving freely then it is very likely its working fine and your issue is not the stepper.
    Hope this helps
    Commercial Cleaning Brisbane
  14. #44
    PA USA
    [QUOTE=Tahlia Muller;4442794]Clean it with some electrical or carb degreaser (from halfords) and a cloth or soft brush.
    [FONT=&amp]Hope this helps
    Yer 1st post - better late than never.
  15. #45
    May 2015
    The Netherlands
    Did somebody actually used a BMW steppenmotor as a replacement for an Aprilia one? Since I have some trouble with various idle speeds,
    I suspect mine is not that fresh anymore. To my suprise, a new BMW steppenmotor a the local BMW dealer costs €99,-.
