Results 16 to 30 of 45
Thread: Cleaning of the stepper motor
    Sweden, Linköping
    Sorry,
    For the TPS to be set to zero you need to go to a workshop with the Axone tool or if you know someone who has the tuneboy cable.
    It can not be done otherwise.
    apriliaforum Member Smok3's Avatar
    Dec 2007
    Romania,Bucharest
    Sorry,
    Grrrrr service again
    are not good mechanic in Romania from Aprilia
    ...in service do not know guys from Aprilia the oil to change by the book last time had 4L of oil in engine,not all related to the air box,and I came home with 2 screws and lost on the way.
    That prefer to do my own thing to the engine and ask the forum here.
    Thanks again I see it as a follow up to solve
    -2001 RST Futura wearing Black.
    -Devil Magnum Exhaust ,Metal fuel line disconnect,Wiring mod done and waterproof conectors Reg/Rec Mod,Hepco-becker,Aftermarket Sliders,Onboard voltmeter,K&N inside but with the stok air box,HID = 1 X 35 W Low,2 x 55 W High,Saito heated grips,12 V Socket, SOLD @ 73 k KM and 11 k Mile
    - buy Honda VFR800 Vtec,Full Givi,touring windshield.....and that's all for now
    %@*#&! hank's Avatar
    Earth
    Now a sticky in the 1000cc FAQ section
    Aug 2006
    Santa Cruz, CA
    Idle Air Control Valves (IAC) are often referred to as "stepper" motors due to the scope patterns they produce when activated. The patterns resemble the side view of a stairway. As Deefred's pictures show, they incorporate a plunger attached to a worm gear, which is moved in and out of a bore via DC motors and a rotary gear.
    Cleaning the IAC--any IAC--is usually a final attempt to salvage a malfunctioning unit. Sometimes it works, but it's always temporary; most time it does not. If the plunger and bore have become dirty enough to jam up and prevent the motor from smoothly moving the plunger in and out of the bore, the motor is usually compromised and needs to be replaced.
    Most IAC cleaning is futile, but since our bikes utilize a separate bore housing that allows total exposure of the plunger, it is not as tricky to service as most other types, and less likely to suffer additional damage from cleaning. This should be considered maintenance. If an IAC truly is binding, or not opening and closing as designed, additional troubleshooting is highly recommended.
    Commanding the IAC to close until the worm gear, plunger and spring are ejected is not a wise idea. As Deefred noted, it could easily result in loss of critical parts. It is also very easy to damage fragile threads of the worm or rotary gears upon reassembly, and these Aprilia IAC units are not so cheap. Cleaning inside the rotary gear/motor area is not a good idea either as solvents can seep into and damage weakened motor/circuits. A shot of WD40 won't hurt, but that's about all I would be comfortable with.
    Our Aprilias are built with GM style IAC valves that utilize a very common electrical connector that is found on Ducati, Moto Guzzi, Triumph, Harley Davidson, Buell, etc... and many automotive applications like Isuzu, GM, Saturn, Chrysler, Jeep, Saab and others. Therefore, there are remote testers available to fit this IAC that some skilled automotive diagnosticians will have in their toolboxes. This tester bypasses the ECU and plugs directly into the IAC, which then can be opened and closed using a hand-held controller, raising and lowering the idle speed at will. If you ever doubt your IAC integrity, seek out someone who has this tester. It takes a LOT of guesswork out of IAC diagnostics, and it has the added benefit of allowing you to custom taylor your idle speed at a fixed rate during tuning for more precise throttle body synchronization.
    BTW, I have never met a motorbike technician who has this tool, and those who have seen me use mine get pretty excited.
    IAC cleaning can be misleading. If you do it and still have your symptom, does that mean the IAC is bad? Or is the computer sending a wrong signal? If so, why? What inputs are fooling the computer? Or is there an open or shorted circuit somewhere between IAC and ECU, battery or ground? Did my cleaning wreck my IAC? (happens a lot) What's really going on here?
    I guess I'm not comfortable with DeeFred's recommendation to tamper with a component that was not malfunctioning. I believe in the adage that you don't fix what ain't broke. But hey, as long as it's your bike, and not a friend's or customer's... Or mine!
    But if there's a definite idle control problem with the valve, and if the bore and plunger are binding, cleaning can sometimes improve IAC performance. Guesswork sucks though. It's always better to know what's really going on.
    Motech
    EDIT:
    One last thing
    The most definitive diagnosis of a failing IAC valve is also the most unsophisticated. If you have an irregular idling problem, like stuck high or surging, access and rap on your IAC valve during the idling symptom with something like the handle of a screwdriver. Rap sharply a few times, but not hard enough to damage it. If your idle controls are restored, or the symptom changes a little when you strike it, it's your IAC or the connections.
    Banned
    Mar 2010
    Australia
    RE :Cleaning of the stepper motor
    Hello,
    I don't know CO level and i never try to open this. So, i think about this is done by my mechanic but its very risky because he say that i am not sure about second time its work or not.
    Please suggest any help..
    Thanks,
    Mark
    Aug 2006
    Santa Cruz, CA
    Mark,
    Stepper motor does not control CO, so no issue there.
    If your mechanic serviced your stepper motor, it is probably failing. This is not a repair, but a process that can help delay buying a new one, and that is why the mechanic will warn you that it might not work again.
    Motech
    Nov 2009
    Woodstock, GA
    Good explanation above.
    I cleaned my IAC, due to idling issues and it lasted for about two starts - unfortunately it is bad. I had been adjusting my PCIII map to make up for idling issues and it came to the point that it was obviously something else.
    37 miles E. of ATX, TX USA.
    I use an ultrasonic cleaner for these little things, did one in 480 seconds at 45C yesterday and it came out looking and functioning new again.
    Micah Shoemaker
    9900 IH35N
    Austin, TX 78753
    micah@af1racing.com
    @ShoemakerMicah
    @AF1Racingaustin
    Nov 2009
    Woodstock, GA
    IAC (stepper motor)
    symtoms:
    -low variable idling which is even worse with the clutch in while in gear at a stop sign and stalling when coming to a stop (I had to immediately put it in neutral at a stop sign or light).
    temporary non-fixes:
    -adjusting your PC map (this works somewhat but it is not the true fix)
    -hand cleaning the stepper motor (lasts about two days)
    Fix: replace it with a used or new one (I picked up a used one on eBay and it worked good and even better when I zeroed out the PC entries I had used previously) or the above entry if you have an ultrasonic cleaner (did you use normal tap water?) above.
    Apr 2013
    Fi
    I think I may have nicked the little thing when I was cleaning the whole airbox from excess oil. How are you supposed to reassemply the whole stepper motor when I already screwed the white plunger of from the motor?
    Aug 2006
    Santa Cruz, CA
    Quote Originally Posted by GuyBrush View Post
    Once you get the threads started a couple of turns, you can reassemble it back on the airbox and the computer will take it from there when you fire it up. It does not care where it is positioned, only that actual idle speed matches commanded speed.
    Sep 2012
    Preston, CT
    I am thinking of replacing my IAC as I know it has been acting up for a while now. The dealer cleaned it, which fixed the problem for a couple of months, but the stuck high idle is back. I saw some talk of needing a computer/tuner to recalibrate the new IAC once it in installed. Is this true? It would be nice if i could just unplug and remove the old one, and just plug in the new one and be ready to go. I don't want to have to worry about taking it to the dealer for a silly thing like that. Let me know what your experiences have been.
    Sweden, Linköping
    Should not be needed. It does an auto calibration each time ignition is set to off.
    Jul 2007
    Netherlands
    Officially, according the manual, you need to reset the IAC in the ECU.
    I too battled the high idle situation for a while. I have swapped IAC 3 times with resetting the IAC. Every time the idle went back to normal directly after a swap.
    Sep 2012
    Preston, CT
    So how do I go about resetting the IAC in the ECU? I have a power commander installed on the bike. Do I use that? Do I need a special connection cable to plug directly into the bike?
