Page 1 of 9 123 ... LastLast
Results 1 to 15 of 126
Thread: Clutch Slave Piston Seal
    Newnan, GA
    Anybody got a seal pn or at least the specs I'd need to get at the local auto parts store?
    Thanks!
    Bill
    '02 Rosso Flame Futura
    38K miles + 30K kms
    Jun 2006
    Columbus, GA
    I thought it was more conducive to just buy the whole slave off of ebay? Am I right?
    Cored OE Racing Cans‡Map2‡Pazzo Shorty Knock-offs‡15-40‡AF1 Link Plates‡Aprilia Sliders
    Laminar Windscreen‡Lowered Pegs‡LED City and Tag Lights
    ProTaper Universal Low‡Clear Signal Lenses
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Newnan, GA
    I know there are replacement units from evolzione and it seems like a few other manufacturers but it really is only a 10 cent o-ring and a cylinder that needs to be honed. I've gotten 28K out of the stock one and its really not pressing that I change it but I can't ride for a few weeks and am wanting to get some of these little projects done. I guess I'll just pull it apart and take it to Napa.
    Bill
    38K miles + 30K kms
    PA USA
    Quote Originally Posted by Sign Guy View Post
    The only thing that the seal in the OE slave shares with an O-ring is that it is round. It's cross-section however, is not. Af1 carries the proper seal, it's far cheaper than replacing the slave.
    The Evo slave now uses x-ring seals. Their original o-rings failed.
    You cannot use std. butyl rubber inside of brake systems. It must be EPDM. Otherwise, the brake fluid will eat it up in no time. Good luck finding EPDM O-rings at NAPA
    Newnan, GA
    That's why I asked. I'll add one to my current cart in the AF-1 online store.
    Bill
    38K miles + 30K kms
    apriliaforum Junkie djump's Avatar
    Feb 2007
    Adelaide, South Australia
    Got mine for just a few bucks from AF1 and she works a treat
    I took the road less travelled, now where the hell am I?
    apriliaforum Junkie bbluemm's Avatar
    Southern Ca.
    Thanks!
    How about ordering it from the guys who are providing you this forum?? It's like $15 bucks and they'll get it to you in about 3 days with standard shipping....
    Bruce
    Ooopss, my bad. Looks like the seals go for $23 bucks...been awhile since I replaced mine, forgot what I paid.
    Jun 2006
    Columbus, GA
    Quote Originally Posted by bbluemm View Post
    Bruce
    Nothing against AF1, but some of us gotta save where we can. I don't have to say, these bikes aren't cheap to maintain.
    Many mods
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Southern Ca.
    Ooops, my bad again!! Shit! Now I notice that he did order one from AF1, sorry Sign Guy, I should learn to read more better.
    Newnan, GA
    It's in on its way here now. Along with a few other things like side case domed decals. I loose one about every 5-6K miles. Beginning to think my cases have a smaller inset that most or the decals are mm or two too large. Next time I'll be ordering a new Strada from them. I was surprised to realize that I'm on the cusp of 10K on my first set of these! So in short....I do order from AF-1 but no offense taken, we've all jumped ahead and skipped the point of a post only to look like an ass.
    Bill
    38K miles + 30K kms
    PA USA
    Those decals are infamous for falling off. Pull off the 2 sided sticky and glue them on proper with glue meant for side moldiings, or even RTV. You'll never lose another.
    Newnan, GA
    sealant/seal orientation
    Back to the seal, I have some waterproof sealant (Dow Corning 111) that was an equivalent to what is used for the water pump seals. I used it on my Pegaso a few years back. Do you guys think it would work for the clutch seal? From what I've read I think it will be fine just wanted to see if there were any opposing views.
    Also, does the V-groove of the seal go toward the bike or away?
    Bill
    38K miles + 30K kms
    Jan 2005
    Annapolis, Maryland USA
    Without trying to be rude, your assumptions seem to exceed your knowledge.
    The seal is special and needs to be purpose made. It is specially resistant to brake fluid. Don't wast your effort trying to save a few bucks.
    Do not use any sealant material.
    The cylinder is anodized aluminum and cannot be honed. Clean it, remove nay galling and leave it alone.
    Newnan, GA
    The seal is from AF1. Every post I have read on this states that the seal should be lubed in a silicone based lube to prevent the fluid from turning black within a few days of a flush. Not sure how I am being obtuse but if I am please do explain.
    Bill
    38K miles + 30K kms
    Dow Corning 111 is a lubricant, not a sealant, and it is ideal to lubricate the slave seal or any brake or clutch hydraulic rubber seals. Use it liberally on the ID of the cylinder and the entire OD of the piston and seal. The open grooved side of the seal goes toward the inside of the cylinder. This type of seal is traditionally called a cup seal. The open side of the cup goes toward the hydraulic fluid. The pressure expands the cup against the cylinder to create a good seal.
