Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: What are the improved crank bearings?
    apriliaforum expert Switchbak's Avatar
    May 2007
    I'm sorry, I can't remember what crank bearings many say to install when the oem ones wear out.
    I think they are of better quality or something.
    apriliaforum expert deathwest's Avatar
    Feb 2005
    Switzerland
    Acutally we can't tell if there is a quality difference or if the premature wear comes from the compressor which make a pressure on the crank.
    I put SKF in mine and seems to be ok after 6000km
    2001 SR50 Ditech (Morini)
    31'220 km (engine 8070km)
    Top speed : less than 80km/h (belt needs to be replaced)
    7 gr. rollers & stock exhaust
    Castrol TTS (fully synth.)
    I use any type of fuel
    May 2007
    Quote Originally Posted by deathwest View Post
    where can i get skf?
    how much $ ?
    May 2007
    what Km do you guys change crank bearings @
    Mar 2005
    Denmark
    Quote Originally Posted by MisterSprinkles View Post
    i did it after 10000km...
    the problem is that the left one on the crank is thinner than the one on the right side.... so the one on the pull side whit all the load on is the week one and the one at the waterpumb side is the strong one.... stupid italian...
    Apr 2006
    Thats why you must go reinforced. These ones should be ok :
    http://scooter-center.com/catalog/pr...0c58b0135044e5
    Mar 2005
    Denmark
    Quote Originally Posted by Ciudale View Post
    all the load will still be on the week side (left side) whit the small bearing
    as long the ball is smaller in the left side it will fail before the right one
    the pull is not even so pretty quick you will get some slag in the left side
    no the right thing to do is to fit a big fat one in the left side maybe a needle one...there is plenty of room and metal to do it... right
    May 2007
    so should I change the crank and bearings then on my 21 000km shaft when i install my bbk?
    Mar 2005
    Denmark
    bbk is short for...???
    sorry i have been gone for some time a year or so
    Mar 2005
    Denmark
    Quote Originally Posted by Speedway View Post
    ahh sory BigBoreKit...
    try and remove the variator and see if you can feel some slag up/down or left/right... if you feel some slag then yes replace them
    Apr 2006
    In any case, thats the occasion to replace the bearings (and may be crank). You don't want to install the kit and get it downed one month later because of the old bearings...
    Mar 2005
    Denmark
    spot on...
    then why not buy a kundo crank only 1/3 the price than the malossi one..
    SKF 6204 right side
    SKF BB1-3056 left side
    Kundo Crank
    code from kunde is
    cigunal aprilla sr50 ditech "CI135800"
    Apr 2006
    Motoforce or Barikit will be fine (approx 150 bucks the crank). The must have (whatever the crank you buy) is a reinforced silver neddlecage (Malossi, Stage6, around 15 bucks).
    @Speedway : Do you have an idea of the room left in the left bearing sit ?
    Mar 2005
    Denmark
    silver neddlecage to the top under the piston...
    no thanx in my case... (bad bad) neddles WILL come flying out at some time....
    Apr 2006
    Isn't reinforced supposed to be stronger than standard ?
    Thats what I run on my Malossi 50 since 13000 kms...
