Results 1 to 3 of 3
Thread: Alloy rear sprockets
    redlionfalco
    Guest
    I've just replaced my original chain and sprockets with a steel front 15 tooth (which I had before), 41 tooth alloy rear and x-ring chain. The mileage at the change was 14250 miles, so I thought that was pretty good seing as they still had a bit life in them, but as I was about to escape for a 4 day mega blast I thought it prudent to change them before I left. Having now put on a further 1400 miles I am a wee bit alarmed that the rear sprocket is showing visible signs of wear (teeth begining to hook). I understand that an alloy sprocket is not going to be as hard wearing as a steel one but the question is - is this the norm for alloy rear sprockets or should I be complaining to Talon about it. After all the OEM Afam rear steel spocket was showing about the same wear after more than 14000 miles. I am thinking it would be a good idea to replace the alloy rear with a steel one before it shags the new chain.
    cplus
    Guest
    I replaced my stock sprockets ~2500 miles ago. I took a look at how they were holding up last weekend while washing the bike. The rear (alloy) still looks great, almost new. In the past, I ran an alloy rear sprocket on my YZF1000 and it held up fine for well over 6000 miles. I might not be the hardest rider in the world, but an alloy sprocket should last more than 1400 miles.
    exducman
    Guest
    alloy/steel/titanium rear sprocket
    I love my stealth rear sprocket, alloy carrier, steel teeth, ti pinned.
    Light, durable & trick looking!
    :smokin:
  1. BMW /Aprilia G series...
    By olie in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-14-2006, 06:49 AM
  2. An update on my clutch and rear brake
    By Gorf in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-28-2006, 08:28 PM
  3. Dropping the front and rasing the rear?
    By chris123 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-28-2006, 07:46 PM
  4. Pilot Power, Diablo (Corsa), or BT014
    By kimmyhendrix in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-31-2005, 10:49 AM
  5. Ramblings about Chains, sprockets and gear ratio's
    By Chuck B in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-11-2004, 06:57 PM
