Results 46 to 60 of 74
Thread: Service Question Compendium
  1. #46
    apriliaforum newb rsvikingo69's Avatar
    Aug 2014
    Italia - Pordenone
  2. #47
    apriliaforum expert g00gl3it's Avatar
    May 2012
    Pocatello, ID
    A few more manuals here, too, with some other stuff. I re-scanned one manual as to make it OCR (text searchable) capable. Cuz I'm lazy like that.
    https://www.dropbox.com/sh/h2jiz7mie...Q7QncvDma?dl=0
    2009 Aprilia Tuono - Ginger
    2006 Honda 599 - Wanda
    2007 Honda CB900F (click for pics -sold)
    2006 Honda VTX 1300C (sold)
    YouTube Channel
  3. #48
    apriliaforum expert SolexFWD's Avatar
    Oct 2012
    Queensland - The Deep North
    Thanks for putting these up guys, they are invaluable.
    The high resolution zoom-able wiring diagram, schematic, electrical drawing, PDF posted by rsvikingo69 is a little hidden here, but probably the most useful document on this forum, for electrical fault finding, electrical problem solving.
  4. #49
    Nov 2006
    Elk GRove, CA.
    I am Interested in a quick tutorial on dropping the radiator coolant and replacing with water wetter. Any help would be appreciated.
    Thanks.
    SAL.
  5. #50
    May 2012
    Pocatello, ID
    Quote Originally Posted by sal View Post
    Thanks.
    SAL.
    Sal, I actually took some video of this but have yet to put it together and throw it on my Youtube account. I'll see if I can get something together tonight or tomorrow.
    YouTube Channel
  6. #51
    Nov 2006
    Elk GRove, CA.
    any luck putting together a video on this g00gl3it?
    Thanks.
    Sal.
  7. #52
    May 2012
    Pocatello, ID
    Sorry for the delay, Sal, it's up now (currently processing, so give it a bit if it doesn't show right away).
    YouTube Channel
  8. #53
    Nov 2006
    Elk GRove, CA.
    I can find video on completely draining coolant from system. Any help would be appreciated.
    SAL.
  9. #54
    May 2012
    Pocatello, ID
    SAL.
    I took some video on doing that as well, haha. But have yet had time to put the video together. But there are a few threads on here that talk about how to do it.
    YouTube Channel
  10. #55
    Mar 2015
    Herts, UK
    with the vacuum hoses splitting, should I buy just OEM replacements? I'd rather replace them with something a bit more industrial.
  11. #56
    apriliaforum Member poppy510's Avatar
    Nov 2014
    California
    I bought tygon fuel line from a lawnmower and small engine repair shop.
  12. #57
    Mar 2015
    Herts, UK
    interesting idea! thanks!
  13. #58
    Jun 2009
    This is great!
    I have an RSV. I can't imagine things being that much different tho, right?
  14. #59
    Nov 2015
    Yorkshire england
    Superb info
  15. #60
    Aug 2015
    illinois
    SAL.
    It was too easy draining the coolant. At the thermostat remove the clamps and slide the hose back. A screw for air bleed is at top of radiator. This screw is not installed until you re fill and when coolant comes out of them. Radiator also has a drain screw. Use tiny amount of teflon thread sealant on the screws. One quart of coolant is needed (add one quart of distilled water to mix it)
    Although the over flow reservoir has to be removed, the process is so easy you will think you're not finished when you are. Mine never burped either.
