Results 1 to 7 of 7
Thread: Best roller weights for Leovince zx...
    Nov 2003
    essex
    I have a aprilia sr 50 ditech which has been fully derestricted and i also have a Leovince zx sports exhaust which i have taken the restrictor out of. I was just wondering what would be the best roller weights for the leovince zx. I would like good acceleration aswell as good top end. What are the standard ones like with the leovince zx?
    Cheers
    Nov 2003
    essex
    One other thing...
    Also does anybody know the weight of the sr 50 ditech standard rollers?
    apriliaforum prov-nov NATO-ohjus's Avatar
    Nov 2003
    Espoo, Finland
    org weights are 7,7gr and i dont know which are best with zx, usually lighter but in ditech maybe heavier are better like paul(?) does have.
    apriliaforum Member PAUL's Avatar
    The Netherlands
    if your scooter is completely stock with a ZX exhausts it would be good to drive around with weights of around 6,5 grams. I have driven around for a while with 6,3 gram weights and they were perfect. The reason why i drive with 8,5 gram weights is because of the Multivar. With the multivar you should increase your weight with about 1 gram. this would mean 7,7+1,0=8,7. I drive around with 8,5 because its better... that's the reason why mine are soooo heavy :P
    2002 SR50 Ditech
    Leovince ZX
    Malossi Multivar 8,5 gram weights
    Yellow spring
    Malossi Delta Clutch
    Red clutch springs
    Malossi Kevlar Belt
    top speed: 115km/h (on speedo)
    Nov 2003
    essex
    With 6.5 gram rollers in my ditech, roughly what will my top end be?
    The Netherlands
    that's impossible to say. Every scooter is different, so telling you what top end you'd get is impossible. The top speed i reached with a stock setup and only a LeovinceZX with 6,3gram rollers was 105km/h on the speedo..
    2002 SR50 Ditech
    Leovince ZX
    Yellow spring
    Red clutch springs
    Malossi Kevlar Belt
    apriliaforum prov-nov M|t3k's Avatar
    Maribor/Slovenia
    I have now on stock ditech and leo zx 8,8 g rollers and it goes 95km/h on speedo.
    with 6,6g it went only 80km/h....
    Ride or die
  1. Variator, roller weights and contra spring mechanics for dummies! Learn how it works
    Last Post: 05-31-2019, 09:05 PM
  2. How to Choose the Proper Roller Weights
    By muchacho in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-19-2011, 07:04 AM
  3. Beedspeed roller weights
    By brunstei in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 04-08-2006, 01:32 AM
  4. why do I have a melted kevlar belt and roller weights
    By Darien Long in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 12-06-2004, 10:33 AM
  5. Malossi Multivar and extra Roller Weights!!!
    By baamonde1 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-09-2003, 10:03 AM
